Can foam tire sealer and inflator used on C300?
Old Apr 13, 2009 | 05:23 AM
chris5949's Avatar
2008 C300 4MAT LX
Can foam tire sealer and inflator used on C300, will they damage pressure sensor inside the tire?
Old Apr 13, 2009 | 03:23 PM
RLE's Avatar
RLE
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
Sealer
Since a number of new cars have no spare and come with a container of sealant and all have TPMS, you can draw your own conclusion.
Old Apr 13, 2009 | 04:21 PM
Ron Jr's Avatar
2013 C300 Sport Black Darth V3.0
You can but I wouldn't. That foam is a real PITA to clean out. It also tends to clump and throw your balance off.
Old Apr 13, 2009 | 06:38 PM
CrAZyVeGAsBoY's Avatar
C300 4matic Sport, CBR 954
i agree with him
Old Apr 13, 2009 | 07:15 PM
Glyn M Ruck's Avatar
Super Moderator
It is recommended & provided by Benz with many of there cars. It's ideal for getting you out of a difficult spot especially if you are in a dangerous area or not a strong person & have difficulty changing wheels.
It's no problem for the tyre shop to clean the wheel & tyre interior & fit a tulip to plug the hole. It will do no damage to sensors.
Highly recommended.
Old Apr 13, 2009 | 11:20 PM
RLE's Avatar
RLE
sensors
...It's no problem for the tyre shop to clean the wheel & tyre interior & fit a tulip to plug the hole. It will do no damage to sensors....
__________
Hang on a minute here. Having held a sensor in my hot little hand, I observed a tiny hole to admit the pressurized air to the sensor interior. Seems to me that it could be blocked by the goop.
BTW, should you buy a twice-as-expensive Porsche 997s, you not only don't get a spare but a flat rear tire won't fit in the trunk at all. So if the spray stuff doesn't plug the hole in the tire (if it's in the sidewall, for example), the car must be flatbedded to someplace that can replace the tire.
Happened to a friend's new Boxster S.
Old Apr 14, 2009 | 05:41 PM
Super Moderator
__________
Many premium model Benz's do not come with a spare wheel but the
"TIREFIT tyre sealant with electric pump" kit. In fact in some markets even the B Class has no spare.
All of these cars have tyre pressure monitors.
The TIREFIT tyre sealant with electric pump package is available as an option for all models right down to the A Class.
If you have any doubts just buy the genuine MB article.
