Eyelid lights, what are they good for?!
Old Apr 18, 2009 | 10:12 PM
aowhaus's Avatar
2008 C300 Sport 4matic
There has been great success in the LED eyelid light group buy, and it seems like there are a lot of people on that quest on the perfectly white lights for the eyelids.
I myself have switched my bulbs to the Polarg bulbs and have been satisfied with the color, but I realized that these eyelid lights don't really go on often.
After seeing reflections of my car in various weather and lighting conditions I don't think that they even go on when I drive. The only time I see them on would be when I unlock my car at night.
Are there any other time, or when they are supposed to be on, when the eyelid lights should be on? Are there any adjustments to have them on in other conditions or settings?
Old Apr 18, 2009 | 10:19 PM
C300Kid's Avatar
2015 Carrara White Metallic Porsche Cayman
They're on every time your headlights are on..at least mine are
Old Apr 18, 2009 | 11:46 PM
kit0515's Avatar
C350 4Matic
they are more for looks then lighting =\, cant really compare a 100lumen light to 2000lumen headlights....
Old Apr 19, 2009 | 12:30 AM
mat2hu's Avatar
C350
those lights are always on while you are driving... you probably didn't see it at a good angle. you can't have any other lights on unless the eyelids turn on first. unless if you high beam some1
Old Apr 19, 2009 | 02:58 PM
Devastator187's Avatar
2008 Sport C-300, 2003 Accord Coupe V6
they're basically your parking lights.
Old Apr 19, 2009 | 03:34 PM
TB5...'s Avatar
2009 C300 4Matic
yea when you sit somewhere for a while your head lights will turn off and your eyelids will both stay on...
you can also turn either the left or right eyelid on when u park your car using the dial on the left side of your steering wheel.
Old Apr 19, 2009 | 05:50 PM
aranu's Avatar
C230 2009 , E320 1996, C230 Coupe 2002
When you turn your lights on it will always turn on [two green lights on your dash will appear] however at night it turns on automatically. at least for the canadian edition
Old Apr 19, 2009 | 06:43 PM
palladiumw204's Avatar
C350 4matic coupe
I have my eyelids on all the time with my fogs...
Old Apr 19, 2009 | 09:14 PM
len56's Avatar
C350
i thought they were the DRLs... where are the DRLs then? (canadian)
are they in with the main headlights? and on C350's here in canada, they are WHITE. even blu-ish white.
Old Apr 19, 2009 | 09:28 PM
micropower99's Avatar
2008 Mercedes C300 4Matic
Mine was yellowish so I changed to the PIAA to make my eyelid lights whiter. Also, our DRL's in canada IS our headlights. (Thus, they can't be turned off)
Old Apr 19, 2009 | 10:09 PM
len56's Avatar
C350
So the headlights are always on? (are the fogs on too? that always looks good)
And I see lots of C350's with bluish headlights, the whole thing, including the eyelids. I don't think they are modded....theres so many of them.
and can the dealers swap them for you? I'm no good at DIY
im researching the car.
Old Apr 19, 2009 | 11:43 PM
Azn_C300's Avatar
Mercedes C300 Sport, BMW 745Li, VW Mk6 Golf TDI
I use them for DRL and just keep them on all day.
Old Apr 20, 2009 | 09:16 AM
aprince2die4's Avatar
08-C350 black/black
wouldnt the taillights stay on all day too if you use the eyelids for DRL?
Old Apr 20, 2009 | 09:28 AM
TB5...'s Avatar
2009 C300 4Matic
fogs are not always on... you have to put them on manually...
however if the fogs are not turned on... when you make a left turn the left fog will turn on for a few seconds... and vice versa.
my eyelids are a bit yellowish although it does look nice with the HID's... i will still be swapping them out once the group buy LED's come in.
Old Apr 20, 2009 | 12:35 PM
Azn_C300's Avatar
yeah. Not a big deal for me though.
Old Apr 20, 2009 | 01:04 PM
Krytech's Avatar
2014 Ghibli S Q4 & 2008 C350
There is a setting in the car where you can enable or disable the DRL feature. With DRL your headlights are always on, but not your fogs and not the eyelids. If you have your light switch in A (automatic) then your eyelids will turn on at night along with your tails and side markers. Fogs always have to be turned on manually unless you MacGyver them.
And the eyelids are very easy to do yourself. There is at least one DIY here for it. If you can change a lightbulb you can do this.
Old Apr 20, 2009 | 03:37 PM
flagman's Avatar
2016 C450 AMG, 2012 C350 4Matic Sport
My eyelids look pretty white, but not bluish white. In fact you would almost think they were white LED's. Of course, they are brand new and will probably get a bit dimmer/more yellow over time.
I have no problem with the stock bulbs and can't see myself changing them (especially since it seems you need the hands of a 5 year old to get in there).
In Canada, the DRL's are the low beam headlights, either halogen or HID depending on the model. Doesn't matter what position you leave the headlight switch in, the low beams are on whenever the engine is running. DRL enable/disable setting is locked out in Canada since DRL are required by law.
If you leave your switch on A, and have enabled exterior surround lighting, when you turn off your car at night, the eyelids, fogs and tail lights stay on for about 30 seconds. They also turn on when you unlock the car. Cool feature.
Old Apr 20, 2009 | 03:39 PM
kit0515's Avatar
C350 4Matic
what do you mean by "MacGyver" them.
Old Apr 20, 2009 | 03:42 PM
TB5...'s Avatar
2009 C300 4Matic
i believe he means... when one uses a paperclip and a stick of gum to rewire the way the lights behave.
Old Apr 20, 2009 | 04:08 PM
Krytech's Avatar
LOL, guess I probably dated myself a bit with that one.
Old Apr 20, 2009 | 04:22 PM
kit0515's Avatar
C350 4Matic
hahaha, any pics?
