Problems Starting My Car
Old Apr 19, 2009 | 03:30 PM
AMGTTV8's Avatar
2026 AMG GT63 Pro
Over the past few weeks I've noticed that my car doesn't always start on the first turn of the key. Even if I make a solid connection with position three and retry several times following, it won't let me start it.
In order to be able to start the car when this does occur, I have to take the key out and start all over again.
Has anyone had any issues similar to this and if so, what the remedy was?
I know that it is not a battery issue, as the battery in the key fob isn't needed to start the car...any ideas what this might be a result of?
Am scared to go through an electrical nightmare.
Thanks,
Chris
Old Apr 19, 2009 | 03:34 PM
jamaicakevkev's Avatar
2007 Avalanche LT, 2009 C300
I have noticed this problem... even had to turn the key and hold like a normal key to start a few times... concerned but more concerned about the 7 speed transmission... seems more complicated than need be...
Old Apr 19, 2009 | 03:36 PM
TB5...'s Avatar
2009 C300 4Matic
yea it's happened to me once or twice...
i assumed i put the key in and turned it too fast... but i don't really know... hasn't been too big of an issue as yet. :\
Old Apr 19, 2009 | 03:40 PM
AMGTTV8's Avatar
2026 AMG GT63 Pro
happy but sad to hear that more people are having the same problem within less than a minute of posting...
i hate to say it, but recently, i have had about a 66% running average of it happening when I get in...
really annoying, because the car clearly recognizes the key fob.
Old Apr 19, 2009 | 06:53 PM
Glyn M Ruck's Avatar
Super Moderator
EIS playing up - It certainly semi recognises the key or it would not turn. Nevertheless - make sure the key IR window is clean - both key & socket.
Old Apr 19, 2009 | 07:08 PM
nyca's Avatar
Did you trying switching to the second key?
Old Apr 19, 2009 | 07:52 PM
AMGTTV8's Avatar
2026 AMG GT63 Pro
trust me - it's clean...the car is barely a month old...
havent tried the second key yet, but the 1 i'm using should be working.
Old Apr 19, 2009 | 08:05 PM
nyca's Avatar
Well, your car is under warranty. Try the second key for a week, and if it starts consistently, you'll have to return to the dealer for a new key. If the second key works intermittently also, then you can report your results to the dealer and they can take it from there.
Old Apr 19, 2009 | 08:30 PM
AMGTTV8's Avatar
2026 AMG GT63 Pro
I like your thinking...
Old Apr 19, 2009 | 09:10 PM
woofwoofz's Avatar
2009 C300 4Matic Sport...2012 C350 4Matic
What about the battery in the key? Try a fresh one.
Old Apr 19, 2009 | 09:26 PM
nyca's Avatar
no, the key battery should have nothing to do with starting the car:
http://www4.mercedes-benz.com/e/cars...html#d13e40605
Old Apr 20, 2009 | 02:36 AM
CrAZyVeGAsBoY's Avatar
C300 4matic Sport, CBR 954
this man is right on the money on both accounts, its either that key or something with ur car.
Old Apr 20, 2009 | 11:41 AM
Star & Laurel's Avatar
C 350 Obsidian Black
Replying to an earlier statement. 204's are the first cars to get a new style ignition switch. Traditionally / earlier cars the ignition will not turn if the wrong key is in the vehicle. 204's no longer have that locking mechanism, so even if you put in the wrong key it will still turn in the ignition. I believe if you use the wrong key it will say unauthorized key on the gauge cluster, which isn't the case with what others are experiencing here. Just throwing it out there for information.
Old Apr 20, 2009 | 12:35 PM
dfranjko's Avatar
Current: Accord EXLV6 w/Navi Previous: 2008 C300 Sport 4MATIC
I didn't have this issue with my C300. However, I have a 2008 Grand Cherokee, which has the same type of electronic key as MB do (the great minds at Chrysler incorporated this on 2008 and newer Chrysler vehicles). I have the same issue with it. When it does happen, it takes like 3 turns to get it to start up. It's been to the dealership 4 times already, they replaced all the control modules associated with it, still doing it. As a matter of fact, Chrysler's engineering dept worked with the service tech on the 4th visit when they thought they fixed it the last time. AFter that, I met with a regional rep, he said that other vehicles do this and it's normal. Additionally, I've had a couple other issues and had my attorney send a lemon law complaint to Chrysler and will see where that gets me. Keep me posted on whether MB is able to fix this or not. Sounds like Chrysler is aware of the problem but has no clue on how to fix it.
Old Apr 20, 2009 | 01:48 PM
Egonvdv's Avatar
EQE SUV AMG-line 350+
I had the same problem.
only i just needed to turn the key all the way back & then try again
(ie no need to take key out)
they fixed it & said it had something to do with the anti theft system ("start blocking" system)
however i still hav the problem sometimes, when i turn of the engine but leave the key in
and then try to start again..
Old Apr 20, 2009 | 03:01 PM
jaseng's Avatar
2015 C300 4Matic (W205)
i have experience the same problem twice in the last week. Never had the problem prior and have had the car for 10 months . . .
Old Apr 22, 2009 | 02:58 PM
numero uno's Avatar
2010 GLK350 AWD 2008 C300 AWD (traded).
Try turning the key all the way to the right and then release the pressure on your key and see if it "kicks off". My car seems to start immediately after I release the key. I just wait until I hear the engine crank over and then let go of the key. Starts every time. Worth a quick try.
Old Apr 22, 2009 | 04:25 PM
AMGTTV8's Avatar
2026 AMG GT63 Pro
trust me, I know how it's supposed to work...this isn't an issue of determining whether or not something is off, it has already been determined that something isn't working properly.
The question is what, and if someone has had any successful resolution to the problem.
Thank you for advising me on how to turn my key though!
FYI: Touching the key to position 3 is enough, it is not necessary to hold it there until the engine turns-over.
Old Apr 23, 2009 | 09:49 AM
tanktube67's Avatar
2008 Black Out C350 Saks Edition / 87 VW GTI
I believe is the ignition switch, take it to MB dealer for warranty
Old Apr 23, 2009 | 08:15 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
+1
if you don't get any indication that the engine is cranking then it's the problem with the ignition switch. this was fairly common with the W203 and other MBs since they started using these infared keys.
Old Jun 8, 2009 | 09:53 AM
vapsmythe's Avatar
C230k
I had a similar problem a few years ago, changed my fob batteries, used my second fob, all to no avail. Shortly thereafter my car battery died. After it was replaced, the problem was solved. I'm not sure there was a connection, but you might want to test your battery.
Good luck!
Old Jun 8, 2009 | 12:26 PM
Egonvdv's Avatar
Starting to happen more & more.
i have a feeling it's the (warmer) temp that makes it worse.
garage tried to fix it twice no, and they don't really know what causes it...
Old Jun 8, 2009 | 07:00 PM
Super Moderator
Mercedes is aware of this problem. It's a problem with the front SAM that requires redesign
Old Jun 8, 2009 | 07:57 PM
coolvi's Avatar
2016 C63, 2009 C3004M
Exactly what happened to me once. Had to re-insert the key and re-do it in slow(er) motion. Almost like it takes a second or two for the key to send proper codes to unlock the entire vehicle or something.
Old Jun 9, 2009 | 09:20 AM
Egonvdv's Avatar
sam........?????
