"ESP Not Available"
Old Apr 19, 2009 | 05:50 PM
akbro93704's Avatar
2014 C250 sport
"ESP Not Available"
Last night when I started my car and drove off, an error message popped up saying "ESP Not Available, See Operator's Manual". The yellow triangle for ESP is on too. I figured it was just a one time thing, but all day today it keeps popping up as well. Sometimes while I'm driving, it goes away, but then it will notify me again.
Anyone else had this problem?
Old Apr 19, 2009 | 08:00 PM
mikestyle's Avatar
C300 6speed
luck you, i hate traction control
Old Apr 19, 2009 | 08:50 PM
akbro93704's Avatar
2014 C250 sport
haha.
Actually, it says "ESP Inoperable", not "Not Available". My mistake.
Old Apr 19, 2009 | 10:24 PM
len56's Avatar
C350
Check with your dealer, it could be a serious problem. Like it cant control the brakes or something...
Old Apr 19, 2009 | 11:12 PM
RLE's Avatar
RLE
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
Not available
Yup. Saw it twice in the first year. Gone after a restart and has not re-occured in the last six months or so. Might have been something about ABS at the same time which is of no concern. Even if ABS is offline, braking is normal.
A transient hiccup, methinks.
Old Apr 20, 2009 | 02:10 AM
CrAZyVeGAsBoY's Avatar
C300 4matic Sport, CBR 954
either way seems like it could be a serious issue, u may want to check it out at the dealership.
Old Apr 20, 2009 | 02:26 PM
C300PO's Avatar
C300 Sport
Had this exact same error...called dealer they said bring it in. They had to reset something in the "steering angle". Hasn't happened since. The SA did say it is a problem that needed attention. It seemed to be a software problem...
Fixed now though...definitely bring it in...
Old Apr 20, 2009 | 08:22 PM
delirium's Avatar
C350
I have had that happen once, but it never returned.
Old Apr 20, 2009 | 08:30 PM
Glyn M Ruck's Avatar
Super Moderator
Yes - It could be the steering angle sensor out of whack
Get the car onto a nice smooth piece of cement and turn the steering from lock to lock 5 times. This will reset the sensor if it is that causing the problem.
Old Apr 21, 2009 | 04:24 AM
C300PO's Avatar
C300 Sport
Good to know if this happens again Glyn...thanks...
Old Apr 22, 2009 | 12:11 AM
akbro93704's Avatar
2014 C250 sport
Cool, I'll have to try that.
ALSO...I tried to use my cruise control tonight, and it says "Cruise Control inoperative" when I try and use it...I guess this is all tied in to one system?
Old Apr 22, 2009 | 04:41 AM
Super Moderator
Yes they are all interlinked. Might also be a speed sensor - You need to get hold of an OBDII scanner & download the stored codes. That should tell you. Even if you buy a $50 little gem from Kragens/PartsAmerica - You should carry one in your car.
The cheapest model you don't have to look up code meanings
What I use:
The cheap one is just fine to carry in your car.
Old Apr 22, 2009 | 09:03 PM
akbro93704's Avatar
2014 C250 sport
What I use:
Well thanks....I should really get one.
As of an hour ago, my cars back to normal, no errors or anything. Cruise control is working. We'll see if that lasts though. thanks
Old Jan 22, 2013 | 03:05 AM
kpm's Avatar
kpm
C220 CDI 2007 W204, ML 320 CDI 2008 4 MATIC W164
ESP NOT Available
HI I have followed your old posts - I have a W204 C220 CDI 2007 model. My car is out of warranty, and I have it serviced regularly. Tyres are ok still, although not new - Now I also got this ESP Not Available, See Owners Manual message on the dash screen!
Then if I stop, turn of the car, remove the key and start again it is gone. After driving 5 or 6 minutes, the Same msg comes back on and the yellow triangle with the exclamation mark comes on - and the car is slowed down and has no power !!!
First it did this once or twice a day - now today it did it almost 20 times!!!
What can this be? Anyone pls HELP!
Old Jan 22, 2013 | 07:40 AM
Super Moderator
Have you done a Steering Angle Sensor reset? Have you read Codes?
Old Jan 22, 2013 | 11:46 AM
kpm's Avatar
kpm
ESP Not Available
Hi there - yeah I tried the steering Angle reset without any luck, so I took it to Merc dealership. They did a Lab diagnostics and found that the "brake line switch" was malfunctioning and the left engine boost pipe was collapsed!
Guess that figures huh!
Thanks for the reply and help guys !
Old Jan 23, 2013 | 07:16 AM
Super Moderator
Wow - The brake light "switch" is part of the ABS unit. I wonder what they did about that?
Anyway ~ pleased it's fixed.
Old Aug 8, 2014 | 05:55 AM
GouwsJR's Avatar
2008 C220 CDI
Jan
I also had the ESP problem frequently, this happened as soon as the car accelerates and it made a feint sucking sound, I took it to two dealers and they only reset fault values, it worked for a short while but the ESP problem came back I took my MB 220 CDI to a local ex MB mechanic and found that the boost pipe was torn, after replacing the pipe the problem was solved
Old Sep 30, 2015 | 10:33 PM
95_993's Avatar
G63
"ESP Not Available"
This worked for me!!!! Thanks Glyn
Old Oct 1, 2015 | 04:54 PM
Josh Walraven's Avatar
2008 c300
my steering wheel is turning key is good just want crank whT TO DO?
Old Feb 9, 2022 | 03:20 PM
zireeni's Avatar
E320 2003
It works
thank you this solved the ESP not available error !
