Sprint Booster Purchased Questions?
Old 05-04-2009, 03:51 AM
Super Moderator
Glyn M Ruck's Avatar
Originally Posted by acr2001
You still would have the same split second lag with the SB! That was tested in the white paper. I do wish someone could figure out a true solution to the lag, that's something I would buy!
+1 - the Sprintbooster does not reduce the lag - It just accelerates harder for a given throttle input after the lag - Please read the white paper. The only solution to the lag is to reprogram the ECU.
Old 05-04-2009, 04:10 AM
W203E35's Avatar
2006 C350 Sport 6MT
So what your trying to say is it's a piece of junk?
Thanks for the WhitePaper Glyn I learned something new (other than the SB is crap)
"We call the accelerator pedal the "gas pedal", but it does not regulate gasoline, it regulates air. Technically, I suppose we should call it the "air pedal", but that doesn't sound very macho."
Old 05-04-2009, 04:23 AM
Super Moderator
An overpriced piece of junk - Enjoy stomping on the air pedal
Old 05-04-2009, 04:22 PM
timdf's Avatar
ML430, Mini Cooper S and Porsche 911 Twin Turbo
Just read the white paper...
an excellent piece of writing.
From an electronics aspect I couldn't help but wonder if the op-amps / electronics had any protection against 'load dump' which could cause a spike on the supply line and fry the amps - possibly causing them to latch up at full rail voltage (full throttle).
I also wondered how fast the engine itself can respond - certainly nowhere as fast as the butterfly opens even with no load.
Just another example of snake oil - good for some people, but doesn't stand up to scrutiny.....
Old 05-04-2009, 05:08 PM
Super Moderator
Indeed!
Quick Reply: Sprint Booster Purchased Questions?
