Help with X-pipe.
Old May 2, 2009 | 02:58 AM
.Simplex's Avatar
C350
Help with X-pipe.
anyone know which shop in the bayarea that can help me get the x-pipe? lmk thanks! give me name of the shop or address please.
Old May 2, 2009 | 04:36 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
not from NorCal, sorry. LOL ...SoCal FTW!
all muffler shop should do if they carry Magnaflow products.
Old May 2, 2009 | 11:25 AM
Azn_C300's Avatar
Mercedes C300 Sport, BMW 745Li, VW Mk6 Golf TDI
Emmanuel's Mufflers in Alameda
http://www.emmanuelsmufflers.com/
http://www.yelp.com/biz/emmanuels-mu...uels%20muffler
Old May 2, 2009 | 11:54 AM
.Simplex's Avatar
C350
^great you know the shop or been there before? They do a good job right?
Old May 2, 2009 | 11:57 AM
Azn_C300's Avatar
Yeah, I've been there before for some tweaking. Clean work. I know of another shop in Marin and another in Burlingame if those are closer.
Old May 2, 2009 | 12:09 PM
.Simplex's Avatar
C350
Yeah the one in burlingame is closer. They do it good to right? So I'm just gong to say install x pipe to my car?
Old May 2, 2009 | 12:19 PM
Azn_C300's Avatar
Actually, now that I think about it, the one in Burlingame might not do exhaust work...only body work. You can call to find out (http://www.garageincusa.com/). One of the forum members here is the owners cousin. I've heard good things about them, but haven't had any personal work done with them.
The one in Marin is Johnny Franklin's Muffler (415) 457-5112. They worked on a couple of my friends (CLK500 and SLK55) exhaust setup and turned out great.
Out of all of them, I'd still recommend the one in Alameda, although it's a bit more of a drive for you.
And yeah, all you basically have to say is you want an X-pipe to replace your stock resonator. They'll either do a custom pipe for you if they have some on hand or sell you a magnaflow or flowmaster x-pipe. You'll want 2.25 sized pipes. If you wanted to save some scratch, buy an x-pipe online yourself and take it to them so it'll only be labor, but you'll probably only end up saving $20 maybe.
Old May 2, 2009 | 12:23 PM
.Simplex's Avatar
C350
Yeah asloing as they do a good job ;D! You know where I can find that black plastic piece on the bumper incase I want to make it 4 exhaust?
Old May 2, 2009 | 12:37 PM
Azn_C300's Avatar
They have the carbon fiber ones on ebay. If you wanted to keep it black, you can buy one through the dealership (expensive), or wait for a c63 owner to part out his if he's switching to carbon. I'll be parting out my quad diffuser fairly soon as soon as I get my carbon fiber one if you're willing to wait.
Old May 2, 2009 | 12:45 PM
.Simplex's Avatar
C350
okay great, how much you selling it for? easy to install right? what shop you got your exhaust done from?
Old May 27, 2009 | 03:54 PM
tehc300's Avatar
C300
You can goto Golden Auto Muffler here in S.F
They've done a lot of fab/weld work for some of my customers along with myself.
Old May 27, 2009 | 03:58 PM
.Simplex's Avatar
C350
if i get an x pipe what are the side effects ? i heard it can lower your HP and the sound will start to change after awhile.
Old May 27, 2009 | 04:14 PM
tehc300's Avatar
C300
Mm I wouldn't say it lowers your hp and if it did it would be to minimal to notice, but I can say the sound will change. There's a couple of sound clips somewhere on the forum with those that have 350's with the X-pipes installed.
Some sound real similar to the g35 sounds but I could be wrong.
Old May 27, 2009 | 04:49 PM
StickyZ's Avatar
W204
your cutting out about an 18" length of baffled resonator and replacing it with hollow stainless pipe...THATS IT. it doesn't reduce back pressure, your losing ZERO hp or low end torque. it is strictly for sound and if you add a more free flowing exhaust or headers down the road this is probably a mod you'd do anyway to help with air flow.
the primary function of the resonator is to absorb/reduce vibrations that would otherwise transfer into sound. that sound 99% of MB buyers wouldn't want...we do. its almost like a cosmetic mod but for sound rather than looks. it is NOT a performance mod. nothing will change, your warranty won't be voided (every dealership is different, some make break *****) but make sure if your having it fabricated you use stainless steel. otherwise, it will eventually rust at the welds and fall off. the OEM resonator can always be reconnected if need be.
Old May 27, 2009 | 07:18 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
The X-pipe increases the exhaust velocity which increases the flow slightly improving high end power. you loose a very slight low end tq in return, but hardly noticed.
Old May 27, 2009 | 07:54 PM
GHAZAN's Avatar
MBUSA
+1... back pressure/low-end loss is more noticeable than the top-end gain, but they are both marginal at best.
Old May 27, 2009 | 07:58 PM
Azn_C300's Avatar
Loss in low end torque is more noticeable in beginning till your ECU adapts. I wasn't too pleased with it as well, but it got better over time.
Old May 27, 2009 | 08:53 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
very true. the ecu is smart enough to adapt. which i'm loving the extra power on top which when on the freeway it pulls without sweat.
