Is this normal for panorama roof?
Old May 6, 2009 | 10:20 PM
misterng's Avatar
2008 W204
My front screen for panorama roof doesn't close all the way in, leaving about 1/3 inch of gap, but the rear does close all the way and leave no gap. Is this normal?
FRONT
REAR
Old May 6, 2009 | 10:58 PM
451/443=EW's Avatar
C350 4Matic
Humm, dont know I'll check my car and let you know.
Old May 6, 2009 | 11:51 PM
c350driver's Avatar
C 350
I had the same thing, dealer said it was normal. Except it isnt!
What I did; opened the 'curtains' half way. Then you see the slider rail and clips that hold it in place. I saw mine were slid back from their original place. Adjusted them by hand, they close 100% again!
Just open 'm half way, and look at it with some common sense...you'll see!
Hope it helps!
Old May 7, 2009 | 09:15 AM
Moto_Guzzi's Avatar
2008 C350-Sport-AMG-Active Agility Pack(Not reliable) +Izuzu KB6 3L(It seems Reliable)+Mazda
What happens on the outside when this takes place on the inside ?
Old May 7, 2009 | 02:10 PM
misterng's Avatar
2008 W204
Hope it helps!
Thanks a lot, let me try it tonight.
By the way, has anyone noticed that we don't have the child safety locks on both rear doors? Just a square hole!
Old May 7, 2009 | 07:24 PM
Theepz's Avatar
2009 MB C350 4MATIC
Nope That's not normal! It should close 100%
Old May 8, 2009 | 01:58 PM
misterng's Avatar
2008 W204
Got it fixed. Thanks again to 451/443=EW.
Old May 11, 2009 | 05:08 PM
Wing138's Avatar
2008 C350 Iridium Silver, Pano, MM, 18" AMG & Keyless
misterng, did you fix it yourself or the dealer?
I have exactly the same problem on the front screen. Called the dealer, they need to order parts???
Old May 28, 2009 | 11:40 PM
SaffsDad's Avatar
2026 E53
My pano roof does the same thing.
I was able to slip it back in as earlier discussed, but it fails to stay in place after a single open/close cycle. I complained to my dealer, but they said this is 'normal' which I don't believe.
Not sure if anyone else has this issue as well, or if there is a TSB for this fix.
Old May 29, 2009 | 01:56 PM
misterng's Avatar
2008 W204
I did it myself. Good thing that your dealer offers to fix it for you.
Mine still stays in place after I fixed it myself, at least until now.
Old May 29, 2009 | 03:29 PM
phatboypimp's Avatar
2009 C350
I have the same problem but the "fix" is only temporary on mine.
