Retrofit wiper (rain) sensor
Looks like the windshield is the same independently if the car had the rain sensor or not. This should make retrofitting reasonable. The question would be more about version coding if this too is controlled by SCN codes but a good workshop should be able to do it.
but i have a 4matic as well... you'll definitely get more drivetrain loss - less power to the wheels, and yes worse mpg. i think the best ive average after 12000 miles and 15 months of ownership is around 22mpg
Tks!
My 221 has done 39 mpg at its best. That is reasonably slow but constant speed at a highway. The average is better with the 204 but I'd expect much better than that from a 221. The 212 beats the 204 easily but it isn't a 4Matic.
Changing the light sensor to a combined light/rain sensor should not be that bad as such. I did not check the plug you mentioned, the problem with missing wires is usually that one may need to dismantle a lot of panels to get missing wires in place.
