Retrofitting COMAND (MM) writeup.
Rating: Thread Rating: 3 votes, 5.00 average.
Old Oct 3, 2009 | 10:43 AM
  #101
Mike_2011's Avatar
2009 C300 Sport
Just Ordered the parts should be completing my retrofit in about 2 weeks.
What is the blower that I need for the US Version?
Old Oct 3, 2009 | 12:38 PM
  #102
vic viper's Avatar
S213
There is no specific blower for the US market, only difference is if you have a RHD car.
Old Oct 3, 2009 | 12:46 PM
  #103
Mike_2011's Avatar
2009 C300 Sport
Alright so if I don't have RHD car then I order the original part # you posted right?
Old Oct 3, 2009 | 05:28 PM
  #104
vic viper's Avatar
S213
correct
Old Oct 17, 2009 | 06:47 AM
  #105
Davide's Avatar
W204-C18K and Lamborghini Gallardo
What is this cabel for? A2118200088 Antenna adapter cable, i have retrofitted comand, but i have this cable left-over.. where should it go?
Old Oct 17, 2009 | 09:17 AM
  #106
vic viper's Avatar
S213
Det är adapterkabeln mellan GPS-antennen och huvudenheten, antennen är nummerändrad så det kan hända att den antennen du använt passar direkt utan kabeln.
Old Oct 17, 2009 | 10:12 AM
  #107
Davide's Avatar
Okej Min antenn passade rätt i utan adaptern!
Tack VIC,
lämmnar in bilen nästa fredag o hoppas på att merca klarar att fixa varför comanden startar om när man öppnar/stänger framdörrarna..
MVH
David
Old Oct 21, 2009 | 04:39 PM
  #108
Mike_2011's Avatar
2009 C300 Sport
Cant Find this 14 pink pin
locate a large 14-pin pink connector, remove and disconnect the red/blue line placed in cavity 6, replace with retrofit harness wire, assemble in reverse order.
Where is this exactly dont see any 14 pin pink conector on the sam module
Old Oct 21, 2009 | 05:22 PM
  #109
vic viper's Avatar
S213
Have you removed the entire front SAM module?, its four screws, two of wich are tricky to loosen.
The pink connector is plugged in "under" the SAM module.
Old Oct 21, 2009 | 05:49 PM
  #110
Mike_2011's Avatar
2009 C300 Sport
Yeah I pulled out the Black housing with cables and there are no conections under there
If that blue/red cable is not installed it the system wont work right?
Old Oct 22, 2009 | 01:50 AM
  #111
Mike_2011's Avatar
2009 C300 Sport
Here are some pics of my progress If you could tell me where exactly it is thanks
Retrofitting COMAND (MM) writeup.-7127_165776737679_505532679_3415121_4991495_n.jpg
Retrofitting COMAND (MM) writeup.-7635_165776642679_505532679_3415120_6197979_n.jpg
Old Oct 22, 2009 | 05:55 AM
  #112
vic viper's Avatar
S213
The SAM module must be accessed through the engine bay, its just under the lower left corner of the windshield.
Remove the cover, loosen four torx screws and lift it straight up.
Old Nov 1, 2009 | 05:07 AM
  #113
Mike_2011's Avatar
2009 C300 Sport
Ok I made everything work except I cant hear any audio? Whats the problem?
Old Nov 1, 2009 | 05:47 AM
  #114
vic viper's Avatar
S213
HU is setup for 810 sound system, enter engineering mode and change.
Old Nov 2, 2009 | 02:57 PM
  #115
deusexisagod's Avatar
w204 c220 cdi
hi
Everything exept h/k audio works as if the option was factory fitted,
h/k sound system is a pretty extensive and pricey retrofit.
In addition to Audio 20, the COMAND has:
DVD-changer
40gb harddrive with 6gb available for MP3.s
Voice control
Memory card option
DVD and harddrive based navigation.
7" flip up screen
Hello Vic.
I am from Europe and i have a c220 cdi w204 model 2007 and from stock i have the Audio 20.
I want to retrofit a comand.I want the 7" inch display with navigation/dvd/HDD/changer.I don't want the SAT RADIO or something else...because it will not work in my country(Romania).I want to buy them from ebay but i didn't understand that the part you listed works on my car and if they are what i need.Please help me because i don't want to throw the money away.And if i go to a Mercedes Benz dealer in my country they will definitely send me away .
This is what i found on ebay:
monitor number / unit number: A 204 820 46 97 9F45 / A 204 870 34 96
And i olso found something Model: NTG4...what's this?!
Thanks.
Old Nov 17, 2009 | 07:12 PM
  #116
waleed's Avatar
C280 2008
Thumbs up
Great Vic Viper i just did as you explain in the first post i buy the HU from ebay used and order the rest from Mercedes Benz in oxford and follow your steps but the last one with SCN coding i did not i have no access.
But when i was working i disconnect the battery when i connect again after i finish steps all things works fine but the navi menu not in my IC (i don't care there are no maps for my country) and also i found something i can't know is it for missing SCN coding or for d/c the battery long time that my service B remaining Km is missing just days remaining shows.
What i can do to let the service remaining KM appears in the IC
please advise
ps. it takes about 7 hours from start till end
Old Nov 17, 2009 | 11:19 PM
  #117
Mike_2011's Avatar
2009 C300 Sport
So I just finished installing the US maps and when am outside I don't see my position at all the GPS antenna is connected and all but I cant seem to locate me do I have to activate something in the Engineering Menu for it to work?
Old Nov 18, 2009 | 04:12 AM
  #118
vic viper's Avatar
S213
It should work from the getgo.
Are you sure you connected the GPS antenna in the correct port? its easy to mix them up
Old Nov 18, 2009 | 08:05 PM
  #119
Nuru's Avatar
S350 BT 4MATIC
If the GPS is connected correctly, does it not show you where you are but somewhere else?
If that is the case then you probably will have to go into the dealer to have them configure the MOS Ring, COMAND, and SCN code a few things. The main thing is to get the COMAND in a state where it is stable.
Old Nov 19, 2009 | 09:17 AM
  #120
mirage15's Avatar
c300 4matic
Are you getting a GPS signal at all? When you are in the Nav screen you should get "bars" that indicate the GPS signal strength. There is also a place in ENG that gives a decimal read out of signal strength... I dont remember where it is off of the top of my head though. As Vic said, it is very easy to mix up with Sirius and GPS ports.
Old Nov 21, 2009 | 11:19 AM
  #121
Nuru's Avatar
S350 BT 4MATIC
Just so you know your connections are correct, here is a pic of the back of a Comand with all the connections identified.
https://mbworld.org/forums/3464171-post17.html
Sirius audio is coming in through the MOS ring. If you have an installation error, it may be between the Blue tooth and the GPS, or the AM/FM and the GPS/Blue Tooth - don't imagine that could be the case.
Old Nov 21, 2009 | 12:02 PM
  #122
Mike_2011's Avatar
2009 C300 Sport
Yup got the GPS working now. But am only getting about 5-8 satellites from the 12 is that normal?
Old Nov 25, 2009 | 06:35 PM
  #123
Nuru's Avatar
S350 BT 4MATIC
Yes that is fine.
Old Jan 24, 2010 | 02:29 PM
  #124
w204 c220 cdi
Hi.
I have a question.....i have read the WIS document regarding the retrofit and i didn't understand about the FRONT SAM MODULE ...in the wis document it shows the SAM under the hood near the engine...vic didn't mentioned anything about this SAM module...and i have i wiring diagram... i am talking about N10/1 conector from the APS wiring harness...
Old Jan 25, 2010 | 02:12 PM
  #125
vic viper's Avatar
S213
Originally Posted by deusexisagod
Hi.
Read again: "The SAM module must be removed by loosening four torx screws, then pull the entire SAM unit up, then locate a large 14-pin pink connector, remove and disconnect the red/blue line placed in cavity 6, replace with retrofit harness wire, assemble in reverse order."
Just missed out taking pictures of this.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
