Replacing mirror housing tweeters.
Old Jun 9, 2009 | 10:39 AM
vic viper's Avatar
S213
But I have the Audio 20 system as well, the h/k tweeters is a bolt on modification.
Subs are a bit more difficult as youll need some kind of converter to transform high pass signal to low pass or get a amplifier that accepts high pass.
Old Jun 10, 2009 | 01:33 AM
justthinking's Avatar
2008 C300 Sport, 2010 RX350 AWD
I called my dealer (Beshoff Motors) today and ask about the tweeter and was quoted $60 a piece and has to be special ordered..
I thought the price was a bit high so I called 3 other dealers around the area..
Smythe European quoted me $85 a piece, Fletcher Jones quoted me $72 and Autobahn Motors quoted me $65..
Even w/ my 10% off coupon..we are looking at about $120 fo the pair of tweeters after tax..
vic viper, do you think the price is simply too high??
Old Jun 10, 2009 | 04:58 AM
vic viper's Avatar
S213
Sounds very strange, just rechecked the price and they cost 206 SEK wich is around $26
Old Jun 10, 2009 | 10:26 AM
Royce118's Avatar
15 E200CGI SPORT
very nice mod.. vic any idea what other speakers can be changed to h/k besides the tweeter?
Old Jun 10, 2009 | 11:03 AM
vic viper's Avatar
S213
Actually looks like the rear door speakers are different with h/k system, the part number is A2048203002 , I have to check this out at work tomorrow
Old Jun 10, 2009 | 01:29 PM
aranu's Avatar
C230 2009 , E320 1996, C230 Coupe 2002
Gonna go get a Can Price check on this item today! I'm guessing its a simple install. Probably try to do it myself. Thanks for the DIY
Old Jun 11, 2009 | 12:30 AM
  #32
Royce118's Avatar
15 E200CGI SPORT
thx for the part number vic.. will check with my dealer about the speakers as soon as possible..
Old Jun 11, 2009 | 12:39 AM
  #33
whkento's Avatar
'15 C200 AMG line, '08 C300 Sport Avantgarde, '07 Jeep Grand Cherokee Ltd, '02 CLK 200 (gone)
Cool--thanks, Vic!
Old Jun 11, 2009 | 05:27 AM
  #34
whn's Avatar
whn
E92 335i
Ordered mine today cost in Finland 31 eur
Vic, dealer said to me that it looks like front speakers would also be just simple bolt on upgrade to HK L7 front speakers. Could you please recheck that? 116 eur in Finland by piece :p
Old Jun 11, 2009 | 05:53 AM
  #35
Royce118's Avatar
15 E200CGI SPORT
$110 per piece in Brunei..
Old Jun 11, 2009 | 06:25 AM
  #36
vic viper's Avatar
S213
I am looking into this, at first I thought that the front speakers were the same, but when looking closer I see that they probably arnt, I must remove my doorpanel to check it out, will most likely replace those speakers as well.
Old Jun 11, 2009 | 06:47 AM
  #37
vic viper's Avatar
S213
h/k front door speakers: A2048202102, rear door speakers: A2048203002
Old Jun 11, 2009 | 11:26 AM
  #38
Royce118's Avatar
15 E200CGI SPORT
what are the prices for the front and rear speakers?
Old Jun 11, 2009 | 11:32 AM
  #39
whn's Avatar
whn
E92 335i
So the HK front door speakers are just bolt on right?
What about HK front center speaker on the dash also available for retrofit?
Old Jun 11, 2009 | 11:34 AM
  #40
whn's Avatar
whn
E92 335i
116 eur for one front speaker in Finland. Dont know the cost of rear speaker.
Old Jun 11, 2009 | 12:18 PM
  #41
vic viper's Avatar
S213
They are around $125 a piece both front and rear.
@whn, yes it is possible to fit the center speaker but it wont do any good as you cant connect it to anything.
That speaker is powered from the h/k amp, in the Audio 20 system there is no speaker there at all.
Old Jun 11, 2009 | 01:12 PM
  #42
whn's Avatar
whn
E92 335i
but I got Comand APS as factory option, not audio 20
But I think there is no speaker there anyway or is the center speaker included to Comand APS package?
Old Jun 11, 2009 | 01:50 PM
  #43
vic viper's Avatar
S213
No, the center speaker is only there if you have 810 sound system or UMI
Old Jun 11, 2009 | 07:58 PM
  #44
I believe if you have Tele-Aid, you will also get the extra 80mm center speaker..
vic viper, are you intended to replace the rest of the speakers w/ HK Logic 7 speakers??
I assume door panels would have to come out to replace the door speakers??
One more question, is it possible to re-flash the audio 20 HU w/ star-diagnose system and re-store all factory settings?
A few weeks back I accidentally changed the setting from engineering menu and flattend the equalizer setting..
The original volume for one of the filter is 2,300Hz and I can only change to either 2,000Hz or 3,000Hz from manual input..
There is no factory reset option inside engineering menu so I did rest from regular menu and even unplug the battery..
However, HU still retained all the memory thus I am thinking about ask my dealer for a favor and re-flash the HU..
Old Jun 11, 2009 | 09:47 PM
  #45
Royce118's Avatar
15 E200CGI SPORT
Vic, thanks alot for the help... Really appreciate it. Im gonna check the prices with my dealer.
Old Jun 12, 2009 | 01:21 AM
  #46
vic viper's Avatar
S213
Yes, I am going to replace the door speakers as well, will do a DIY when it happens.
Yes it is possible to upgrade the HU software, but I do not know if that resets all the settings, the SDS is cache storing all user settings wich are later transfered into the HU again after completed update, this is an automated process and dont know if it is possible to skip this part.
Old Jun 12, 2009 | 07:15 AM
  #47
ctgilles's Avatar
S204 C220 CDI, VW Scirocco III 1.4TSI 160
I paid (per piece) €18 + 21% VAT. I was quite surprised though that the part numbers start with 212 isn't that the new E-class?
Old Jun 12, 2009 | 07:26 AM
  #48
Royce118's Avatar
15 E200CGI SPORT
keep us updated with the DIY =p
Old Jun 13, 2009 | 08:08 AM
  #49
Mongkol's Avatar
W204
What exactly is the impedance of the tweeter (and other speakers)?
Do you also know the power (watt/ peak or RMS) supplied from the comand unit to the speakers?
I also want to change the speakers as the factory default are so poor but
I am concerning about the suitable speaker power requirement.
I still dont want to put an amp as i think it will be more difficult to do so.
thanks
Old Jun 13, 2009 | 09:13 AM
  #50
vic viper's Avatar
S213
Impedance is 4 Ohms, but I do not know the output power from HU or sound system amp.
