Ipod interface cable UPDATE.
So, there's a new ipod interface cable. It has a black tip vs the old one with the white tip.
The part # for the NEW cable is B6 782 4532.
If I bought the cable, would it be hard to install it myself? I think the cable cost $50.
Is there any instructions on how to do this? I tried searching but had no luck.
Thanks.
Thanks.
Do you know how to install the new cable? If its easy to install the new cable, I dont mind paying $50 for the new cable and installin it myself.
C350
The person I spoke to @ Mercedes suggested for me to buy it and install it myself so I don't think it should be too hard to do. But when I pick up the part I will make sure to ask him for the instructions and then I will post it here.
C350
The updated cable with black connector will charge your Iphone / Ipod Touch / Ipod classic and 4th generation Nano. Currently I have the white connector and I am unable to charge my Iphone or 4th Gen Nano.
2007 Avalanche LT, 2009 C300
That would be great post a step by step.
Here ya go!
Scroll down to the "W204 new C Class"
http://www.mercupgrades.com/IPOD+Ret...rticle-35.html
Sorry. Forgot the link
Why not just get this and save the installation time and money?
Scosche Charging Adapter for iPod touch 2G, iPod nano 4G, iPhone 3G (Black)
http://www.amazon.com/dp/B001HN6CVA?...6N0JVSC93F441&
In one of the threads, someone stated that this device hinders the sound quality.
The cable is $50. If its an easy installation, I would rather buy a cable for $50 vs getting an adaptor around $30.
2009 C350
There's also a black socket thing that holds the cable in place on the wall of the glove box that you need to loosen to take the cable out, but it should pop right out with a firm push.
The only harder part is probably to open the side panel, which is not that hard either.
Based on this useful info I picked up this new cable, and as far as I can tell it also charges old iPods. Dealer told me so and I hooked up my wife's old Nano (first gen) and it charged without any problems (I know it did because it had a flat battery).
Did u install the NEW cable yourself? If so, do you have any instructions with pics on how to do it?
2009 C300 Sport 4Matic, 1999 Jeep Grand Cherokee Laredo
I can charge my iPhone with the white cable, is that because I have a First Generation iPhone? I am about to upgrade to the 3G S, I'm assuming it won't charge this?
Yes. Your Iphone must be the first gen. I cant charge my Itouch with the white tip cable. Thats why I'm trying find out the instructions to installing the black tip cable.
If you prefer to buy a cable over an adapter then that is fine, but don't do it because of sound quality.
Assuming we are talking about the same cable (for use with option 518 - Media Interface), then this is really zero effort. Open the glove compartiment, feel around the top left for the connector and plug it in. Obviously if you have the old cable installed, plug it out first. Can't take more than 20 seconds.
I'm going to call BS on that one. The audio would be going out via a straight digital connection which couldn't be degraded (unless it is completely dropping in and out). These adapters just have a few resisters in them to drop the voltage down from the previously supported firewire equivalent to 5V (equal to USB).
If you prefer to buy a cable over an adapter then that is fine, but don't do it because of sound quality.![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
http://www.griffintechnology.com/pro...-usb-converter
I took a look at the ipod cable in my glovebox lastnight. It looks like I have to remove the glove box in order to access the cable plug. The cable goes through a gorment. I didnt see any ethernet like connector for the ipod cable.
Griffin also makes a converter, which may be better. I don't have either so I can't comment.
