Tired of the damn OEM door pins!!
Old 09-12-2010, 12:34 PM
  #51
kaku's Avatar
2009 C300S 6mt
looks clean.
did you remove the rears and just covered it with a cap? if so, how'd you remove the rears?
Old 09-12-2010, 12:39 PM
  #52
2xk818's Avatar
c350
Originally Posted by kaku
looks clean.
what u do is you pull off the stock pin and then just put pressure on the pin thats inside the door and it will just detach from the clip and partially hang in the door. you dont need to remove it because it will not interfere with any of the other door components including the window.
Old 09-13-2010, 03:42 PM
  #53
tehc300's Avatar
C300
nice job! After 2 broken rear doorpins on mine I decided to just plug it up. Haven't messed with the front pins but I'll get to it some day haha.
Old 09-14-2010, 01:14 AM
  #54
2xk818's Avatar
c350
after you do it let me know how you did it cuz i was a bit sceptic about messing with the front ones considering they are different from the back ones.
Old 09-14-2010, 08:29 PM
  #55
Peabody's Avatar
The front pins should just unscrew.
Quick Reply: Tired of the damn OEM door pins!!
