Switching to a Quieter Tires?
2008 C350 Sport, 2007 ML320 CDI
I have an 08 C350 Sport with Michelin OEM tires. My only complaint about this car is the ROAD NOISE on the highway. On some surfaces, it's ridiculous - especially from the rear 40-series tires. I'm thinking about cutting my losses and trying a "quieter" tire. I know I'm running the risk of finding out that this is simply a lack of noise deadening in the car, and not so much a tire issue.
So I'm wondering if anyone has successfully quieted the tire roar with a different brand of tire?
I think it's more the car than the tire...your money may be better spent getting the MB mat for the trunk.
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
Noise
I suggest travelling on the same noisy road surface with another prestige vehicle ( say a mates) & compare the noise levels.
C350
the OEM michelins are considered very quiet tires... I have the same ones. one huge reason for road noise is the gigantic side mirrors on our cars.. lol. The car is pretty quiet though, just turn up the music a bit and u won't hear a thing. With mercedes its you get what you pay for. you want quiet, get an E class or S class which is like you hear absolutely nothing!
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Fit non directional tyres - Michelin PS2 or Pilot Exalto PE2 (not old PS1 or Primacy or heaven forbid Conti SC2/3 which start noisy & become worse with wear) - rotate wheels corner to corner every 8000 miles to change direction of rotation or across the same axle if staggered. Maintain correct tyre pressures & watch castor bushes & alignment to ensure no feathering or cupping of tread which causes air pumping noise. Yokohama AVS db2 is another known quiet tyre on these cars. Fit Dynamat to badly damped trunk area. Maintain this regimen & you will be delighted.
Thanks for all the advice. I think all try the Dynamat solution first. I can't do tire rotations as I have the sport package, staggered wheel sizes, etc. I was just in our neighbor's new BMW 335d. I thought it would have more road noise, since BMW insists on runflats for just about everything - it was quieter on just about every road surface. It's not the side mirrors - they've never bothered me. This noise is primarily coming from the rear of the car. So, I think I'll go for the Dynamat and see what happens. Thanks again for the advice!
Super Moderator
You can rotate with staggered - Just swap across the same axle e.g. swap fronts with each other. Then each will be rolling opposite direction to what it was.
I was running Falkens on the A3 and they were noisy as hell so when I got the C200 and wanted to upgrade to 18" I was wary about what tyre I was gonig to run. I eventually chose PZero Rosso and couldn't be happier. Don't know what I will put on when they wear as it will be an expensive exercise. I ended up going with Toyo Teo's for the A3 and they are real quiet as well.
2009 C300 Sport 6MT
Cheaper insulation is duct insulation wrap called Frost King available at Home Depot or Lowes. Corvette people use it to bring down the noise. Reflectix (also in these stores) is another cheap alternative.
Waiting for W204 Facelift
I have factory installed 17'' Michelin Primary Sport tires....I like them and I will replace with same Michelin soon . searahing pricing in the market Michelin is more expensive maybe only Bridgestone Potenza compare it
Super Moderator
What is a Primacy Sport??? there is no such tyre in the Michelin Range - Primacy are touring tyres.
I pulled up trunk floor cover - have not done that in almost two years of leasing it. I was stunned to see bare metal with no sound insulation! My '99 E-Class seemed to have styrofoam and other substances molded everywhere. I just assumed this would be the same. So I think I'll try the DynaMat option - it's worth a try as I'd really like to keep this car - it's been a bulletproof tank.
C350
no, stock 17" OEM Michelin's are Pilot HX MXM4 tires... for any1 who has these, DO NOT BUY THEM AGAIN!! very expensive and rated very poorly. you could get much better tires in every aspect for the same price.
Super Moderator
Super Moderator
