C63 steering wheel on manual tranny, yay or nay?
Remove airbag by inserting an L shaped T30 torx key in the two holes behind the steering wheel, loosen them both to fold out the airbag.
with the airbag folded outwards, disconnect the two large connectors in the steering column and place the airbag in a safe spot.
Unscrew the center bolt using a 8mm allen socket with an 2-3 inch extender and a socket wrench, be careful not to break the steering wheel lock, its best to use a buddy to hold the wheel steady while you loosen/tighten the bolt.
Remember the markings on the center spline and remove the wheel.
Install in reverse order.
I can wait to install it this weekend!
The C63 wheel is also about half the weight of the stock wheel
Guess it will take some time getting used to the flat bottom steering wheel while driving, but it feels really good the short time I have tried it so far, will shoot some pics when the lighting gets better..
What does the smaller diameter to do line of sight visibility of the instruments? I am 6'2" and already cannot see the 12 o'clock position on the speedo when the stock sport wheel is properly adjusted for arm comfort.
http://cgi.ebay.com/ebaymotors/Merce...Q5fAccessories
I called the local MB dealer and offered up the same part number and he said its $2,100!!
...just for the wheel....not including the air bag.I assume the original air bag module fits to be reused, based on your earlier post explaining how to swap?
I have a C300 sport automatic and no paddles on the current stock wheel.
Do you know if I can make the paddles in the AMG wheel operational to control the gears?
Maybe I am overly cautious, but this concerns me. The C63 bag likely is calibrated for a crash pulse for a platform with an 8 cylinder engine, which has an additional cylinder bank as compared to a 6. The less diminished energy of impact exiting the rear of the V8 would send more force rearward to the passenger compartment, while a 6 would provide more crush to dissipate some of the force. Therefore, that probably makes the C63 bag a more aggressive inflation to offset possibly higher chest g's. If the bag module is also smaller with a smaller bag volume, it may also be more aggressive for that reason as well. In combination, the C63 bag may not be well suited for a 6 cylinder vehicle. We need a MB restraint systems engineer to tell us if bag performance is common between a 6 and 8 cylinder model...or not.
Also, a different example may not be relevant, as the crush for a 4 or 6 may be compatible with one bag spec, but a V8 crash pulse may vary to the degree another spec is required. We would need to actually document commonality from C300/C350 to C63 to make a certain determination. I will observe from the sideline meanwhile....thanks!
And remember that the aibag units are "two stage" they are equipped with two charges (hence the two connectors), if the impact is small enough only one will discharge and if the impact is harder both charges will ignite at the same time for increased protection.
, the C63 steering wheel was installed on what car? The link on ebay sez the C63 wheel will not fit the C350 due to the neck something......anyone care to elaborate on this??
graci.
"The steering wheel has to come from Germany, 5/10 days sells for $2140.00
Air bag 2 days to get, sells for $1180.00"
I'm sure I can find better prices, but that was just quick local dealership price check.
