Garage Door Opener
Old Sep 18, 2009 | 11:09 PM
Mike_2011's Avatar
2009 C300 Sport
Garage Door Opener
Is there anyway to add this?
Old Sep 19, 2009 | 12:35 AM
AL_ATC's Avatar
08 W204
Any luck with the rolling code opener?
Old Sep 19, 2009 | 02:06 AM
joshg1001's Avatar
2017 E300
are you asking about adding homelink buttons to the car? I thought they were standard, at least on US spec cars
Old Sep 19, 2009 | 03:32 AM
AL_ATC's Avatar
08 W204
any help with setting up with rolling code opener?
Old Sep 19, 2009 | 03:33 AM
Mike_2011's Avatar
2009 C300 Sport
Yeah the garage door openers on the Mirror.
Old Sep 19, 2009 | 01:00 PM
Sincity's Avatar
On my '86 190e, I took one from a 1st gen SLK and mounted it under the dash.
Old Sep 19, 2009 | 02:26 PM
Peabody's Avatar
It's in your owner manual, it's something like press the training button on the door motor inside the garage, and then use the button on the mirror. I had to look it up today because I was wondering why I was so retarded as to not be able to program mine, and it turns out my garage remote is like 420 Mhz and the built-in opener only goes from 230-370 Mhz or something.
Old Sep 19, 2009 | 06:22 PM
joshg1001's Avatar
2017 E300
is he asking how to set it up, or how to add it (actual buttons) to the car
Old Sep 20, 2009 | 02:00 AM
AL_ATC's Avatar
08 W204
how to set it up, tired to follow the mauual but still not working !?
Old Sep 20, 2009 | 02:33 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
some rolling code garage door opener will not work.
I have the homelink setup on W203 and my sister's W208, but I couldn't get it to work on w204 or the Odyssey we had. I gave up and just leave a garage door remote in the car.
Old Jun 2, 2010 | 08:04 AM
jay-q's Avatar
2010 C300
homelink rearview mirror plug and play
in response to the OP..... i was successful last night in installing a homelink, auto-dimming rearview mirror into a base C300 (no P1 or P2).
the mirror i replaced was a manual dimming mirror w/o homelink.... the old manual mirror has the identical wiring harness as the new homelink/auto-dimming mirror..... it is just a matter of removing and unplugging the old mirror and then installing and plugging in the new one.... the hands-free bluetooth was unaffected by this mod
the mirror is held by a spring into the car, a tip i found was that you can compress the spring with a c-clamp which engages a smaller clip that holds the spring while its compressed to ease in installation (this will make more sense when you see the part)
anyhow, for those c300 base model owners looking to add homelink..... i was able to find a part of off LKQ from ebay for ~$80..... the mirror i transplanted came from an '08 (no compass)..... and it was successfully installed in my 2010 c300.... i tried to do a lot of research on the internet (there isn't much), but after much planning, it took less than 30 minutes to install..... hardest part was figuring out how to disassemble the overhead control unit, turns out it swings away on a hinge to reveal all the wiring... had i known that in the beginning the mirror would've took less than 10 minutes to install....
-J
