(NEWB) Question on HID's?
Old Dec 27, 2009 | 06:39 PM
ShaiMalka's Avatar
ccoupe
I was wondering if someone has the time to explain how to change the eyelids,lowbeams and fogs to hid's. I wanted to go 8000k for all but i was wondering if someone could let me know what brand to use which bulbs etc. I want to do this the cheapest way possible so please help! RHANK YOU SO MUCH IN ADVANCED!
-Shai
Old Dec 27, 2009 | 06:54 PM
snarlingchicken's Avatar
2009 C350
Eyelids can't be HIDs. They can be either something like PolarGs which are halogen bulbs, or LEDs (SMDs). But on a more...related note, all of the how to's can be found here. https://mbworld.org/forums/c-class-w...-together.html
Philips has always been kind. But I see people using DDM, Promax, or other brands.
Old Dec 27, 2009 | 07:54 PM
Richard2011's Avatar
2015 BMW M235i 6MT
DDM HID kit seems to be the most common and reliable on this forum. I have a DDM kit myself, and it works flawlessly. Never had a problem with the kit itself. DDM's error cancellors are required. Low beams and fogs are H7 on the sports model. There are no guides for the low beams, but there is a guide that uses a custom bulb holder for fogs in the previously linked thread. The install is pretty straightforward, and the online instructions on DDM's site were very useful when installing mine.
Eyelids use 194 bulbs. Some use LEDs, but there have been reports of the LEDs burning the eyelids. Most replace the eyelid bulbs with Polarg M4 bulbs. Google it, and you can buy in bundles on ebay. 2 bulbs are needed for each eyelid, and there is a DIY in the previously linked thread.
Did I miss anything? Haha.
Old Dec 27, 2009 | 08:09 PM
2009 C350
I've been using these LEDs http://store.ijdmtoy.com/Canbus-Euro..._t10_sku26.htm for about three weeks now. They STAY white and there have been no adverse effects to the car that I have noticed. Probably thanks to the load resistors. I'll snap some pictures when I get the chance.
I have a few ones from the install but they look a bit more blue than they actually are.
Old Dec 27, 2009 | 09:49 PM
ShaiMalka's Avatar
ccoupe
So with these you change the bulbs inside with the error free bulbs but how many do you need?
Old Dec 27, 2009 | 09:56 PM
2009 C350
You need to order two sets of LEDs. Each set comes with two bulbs (LEDs) and each eyelid housing uses two of them. So four total.
Old Dec 28, 2009 | 02:34 AM
ShaiMalka's Avatar
ccoupe
i see for the eyelids it uses a t10 bulb i want to change out my sidemarker aswell can someone varify which one it is? Also I see you have the bright LED has anyone used that blue led for the eyelid? And its simple to install corrrect? Thanks
Old Dec 28, 2009 | 02:50 AM
2009 C350
T10 is a type of SMD. What you're looking for is the W5W, which, the one that I linked you, is. But there is a different LED that has one LED on either side of the PCB, and that's two bucks cheaper, so that can be used for your sidemarkers if needed. That's what I plan on doing at least.
Old Dec 28, 2009 | 03:17 AM
e1000's Avatar
a quarter mile at a time
FYI, you lose a LOT of light output at 8000K.
Old Dec 28, 2009 | 11:22 PM
d.smooth's Avatar
2008 C300 4Matic
Hi
I'm new here too and had a similar question about HID's. Don't mean to hijack your thread or anything but I did a search and couldn't find anything and didn't see the point in starting a new thread.
Anyway, my question was whether it was possible to do a HID retrofit with the stock C300 HID's and if so would how extensive of a job it would be and if the dealer would be able to do it or any competent indie shop for that matter?
Old Dec 29, 2009 | 01:27 PM
2009 C350
You can either do a simple bulb swap (where you can use a brand like luminics or philips) or get an HID kit. A lot of people do either one and most "Competent Indie Shops" should be able to do it.
Old Dec 29, 2009 | 03:44 PM
2015 BMW M235i 6MT
He's not talking about a simple bulb swap or HID conversion. He's talking about retrofitting projectors on a C300 that already has bixenons. I don't really see a point in that. It wouldn't be a HUGE improvement.
Old Dec 29, 2009 | 03:45 PM
2009 C350
Oh. o_o. Yeah I'm with Richard then. It wouldn't be a huge improvement at all. My sister has the C350 without P2 but with aftermarket bulbs and I have a C350 with P2. Comparing em side by side you can barely notice the difference.
Old Jan 3, 2010 | 04:51 PM
d.smooth's Avatar
2008 C300 4Matic
Actually I don't already have bi-xenons, I have the halogens. I made the mistake of not getting them to begin with and I'm really regretting it right now. Sorry if I wasn't clear before, what I meant was if it was possible to get my halogens swapped for the OEM bixenons. thanks in advance.
Old Jan 3, 2010 | 05:09 PM
2015 BMW M235i 6MT
You'd have to buy the whole headlight assembly. I saw the number $1,500 while researching it. I can't remember if it's for the whole set or each headlight. I think each headlight. Expensive.
Old Jan 3, 2010 | 06:00 PM
Asianguy's Avatar
C300 Sports 4-Matic
You can also just buy Philips Crystal Vision 4300 Super WHite Halogen Replacement Bulbs for both Lower beam and Fogs Lights (H7 for Sports)
For the Eyelid and Side Marker, either go with Led w/w capacitor or M4 Polarg 194.
Old Jan 3, 2010 | 06:04 PM
2009 C350
Yeah. What he said. Luminics also makes a decent H7 bulb. The Titanium white ones. Good color & output.
I suggest LEDs. I bought polarG's this weekend at an asian market for 6 bucks. Plopped em into my sidemarkers. They're okay, but LEDs would look much better.
Old Jan 3, 2010 | 07:57 PM
2015 BMW M235i 6MT
Polargs at an Asian market? I've heard of people getting them from Chinatown, but never an Asian market. I'll have to look for them next time I'm at one!
Old Jan 3, 2010 | 08:06 PM
2009 C350
I've been seeing them wherever I go. To be exact I bought mine in a little stationery store inside an asian market. Places I've seen PolarG's at are....Mitsuwa, KTown Galleria, Fancy Plus, and this one other asian market that I can't recall. Most Korean/Japanese places carry them in random shops, thinking maybe a car modder will come along into a stationery store/gift shop looking for them. I guess they're right? Chances are, if you find a place that's Asian that sells asian car air fresheners, PolarGs will be somewhere in that area. Haha. No guarantees though. In LA it's pretty wide in terms of ethnic diversity.
Old Jan 3, 2010 | 10:06 PM
d.smooth's Avatar
2008 C300 4Matic
If the difference in light output between the super white halogens and real OEM bi-xenons is negligible then I'd be willing to give it a try.
The reason I wanted to swap for the OEM bi xenons was because in my experience bulb swaps and plug n play kits usually don't do anything in terms of light output but at the same time are incredibly blinding to the people in front of me.
Old Jan 3, 2010 | 10:26 PM
e1000's Avatar
As far as light output:
Any tinted halogen bulb will actually produce less lumens than a non-tinted halogen bulb at the same wattage level. Also, don't believe anything that says a 55w bulb outputs an equvalent of anything other than a 55w bulb using the same technology.
Xenon, or HID lighting will produce roughly 3x the light output at 35w that a 55w halogen bulb will. It's important to remember, that to truly take advantage of all the extra light output a properly engineered reflector or even better, a projector is used with a xenon bulb. Putting a xenon kit into a halogen reflector housing can have very mixed results and can sometimes end up with uneven lighting, hot spots, and other undesirable lighting effects.
Old Jan 3, 2010 | 10:44 PM
Asianguy's Avatar
C300 Sports 4-Matic
This was my post on another thread w/ pictures of H7 Super White Philips Crystal Vision on Lower beam and H7 with Polarg M4 194 on Side Markers:
https://mbworld.org/forums/c-class-w...ch-pics-5.html
Old Jan 3, 2010 | 11:22 PM
Royce118's Avatar
15 E200CGI SPORT
Just curious, do you notice any loss of light output with the Crystal Vision. I like the colour of the Diamond Vision on mine but I do notice a slight loss of light output when it rains. I'll switch them if light output is about the same as stock.
Old Jan 4, 2010 | 09:00 PM
charliele729's Avatar
09' E350 AMG Sport, 09' C300, 03' Honda S2K
I have put the CV in my fogs as they do look nicer, but the stock halogens do light the ground more. It is also more distinctive if you have xenons because of the different color in light.
Old Jan 4, 2010 | 10:22 PM
Royce118's Avatar
15 E200CGI SPORT
So that means that the CV doesn't light up the ground as much as the stock halogens? Don't have xenons so yea..
