Easy H7 foglight bulb change - w/pics
Rating: Thread Rating: 9 votes, 5.00 average.
Old Feb 24, 2011 | 05:34 PM
Antimage's Avatar
2008 C300 4matic
Going to pmall later today to get a pair. Which store is it?
Old Feb 24, 2011 | 09:26 PM
kaku's Avatar
2009 C300S 6mt
Originally Posted by ashriad
Apparently the fog lights works fine when I turn them on using the light switch but when I take the car out from a dark area (garage) into the daylight, the driver side fog light does not work. Am I missing something? Any ideas?
could it be the auto-corner fog light that turns on each individual side as you're turning?
Old Feb 25, 2011 | 01:50 AM
jon3sh's Avatar
2010 C300 4Matic
I bought a pair from Crappy Tire instead they sell Eurolite H7 bulbs there. One I got is Eurolite H7XB Plasma its brighter than the yellowish stock bulbs. Just wondering if I should return it and go to P Mall and get eurolite h7 5000k cuz mine doesnt say 5000k.
Old Feb 25, 2011 | 11:38 AM
Antimage's Avatar
2008 C300 4matic
As someone with no car-modding experience, I would like to emphasize that you should take EXTRA CARE in removing/inserting the lightbulb. Having nails help - I accidentally broke a bulb replacing mine and will have to go back and get another pair tomorrow. The 5000K ones at pmall are $22.
Old Feb 25, 2011 | 03:29 PM
jon3sh's Avatar
2010 C300 4Matic
Do you still remeber the store's name? Yah bulb sitting pretty tight but I use butter knife and took my time prying one side then the other.
Old Feb 25, 2011 | 03:38 PM
Antimage's Avatar
2008 C300 4matic
it's called auto sports. store # 58 somewhere i think on hollywood ave. it's near the north east side of the mall.
Old Mar 6, 2011 | 11:29 AM
  #32
BullyDogIVK's Avatar
2008 c300 luxury
Is it different to change the bulb for the luxury model? My fog light panel is different..thanks
Old Mar 6, 2011 | 02:39 PM
  #33
dewydang's Avatar
C300
i Believe the luxury model bulb is an H11. i could be wrong though
Old Nov 24, 2012 | 03:42 PM
  #34
Capo31's Avatar
2009 C300 4matic Sport
Awesome worked like a charm..... now I have my super bright... PIAA lights!.. thank you
Old Nov 25, 2012 | 10:45 PM
  #35
glj12's Avatar
C300 Sport
The luxury is still an H7 I believe.
Regardless, how in the world would you even change the luxury H7s without taking off the entire grill? I see no way of entry to the bulb via the wheel wells...
Old Mar 12, 2013 | 09:45 PM
  #36
sharkey_lsu's Avatar
2013 C63 AMG
I have purchased and installed the Phillips Diamond Vision bulbs and the color temperature is perfect but I wish the bulb wasnt so blue during the day, looks a little cheap to me. Other than HID foglight conversion, is there a bulb that has the same pure white color as the Diamond Visions but without the ugly blue bulb? I have seen chrome coated amber bulbs and would think there should be something out there like that for H7s.
Old Mar 23, 2013 | 08:18 PM
  #37
RavenMDX's Avatar
2009 C300 4Matic Sport + Premium 2
Thanks for this DYI. I went ahead and replaced the fog lights with GE nighthawks.
I did noticed however that the driver side glass fog light housing cover is worn out compared to the passenger side. Can this be replaced as a DYI?
Thanks again
Old Mar 23, 2013 | 08:28 PM
  #38
glj12's Avatar
C300 Sport
Thanks again
You would need to replace the entire fog light assembly, which goes for about $90. It's a pain to install without the car being jacked-up by the way.
Also, be sure to get the correct fogs if you do decide to go this route -- the ones on eBay may say Sport (if that's what you need), but they are indeed Luxury.
Maybe you could use a restoration kit or something?
Old Mar 23, 2013 | 09:14 PM
  #39
RavenMDX's Avatar
yikes thanks for the info. I guess eBay should be avoided for this part. Before I head over to the stealership, I'll try a restoration kit since the glass is not broken but is filled with micro pitting. Strange that the passenger side looks nothing like the driver side.
Cheers
Old Apr 1, 2014 | 11:59 AM
  #40
dolphinman's Avatar
W205 (2021) C300 - Selenite Grey (Prem Pkg. - Pano roof & Burmester sound) RWD
Thank you mistersir! That really helped me out. Thanks for taking the time to post pics and clear instructions.
Old Aug 3, 2020 | 10:43 PM
  #41
Nicholi2007's Avatar
2015 C400 Tenorite Gray
Originally Posted by mistersir
Hey there.
So I went out got myself some white foglight bulbs to replace those ugly yellow ones. I went with the Eurolite Xenon Fusion. It's a 55W bulb with a color temp of 5000K.
It was very easy to do and took less than 10 mins. Here are step by step instructions with pics:
1) Open box containing lightbulbs
2) Undo 3 screws using a Torx 15 screwdriver (Pic 002)
3) Remove mesh foglight panel. This should just fall out when you've removed the screws.
4) Reach in and give the bulb housing a good turn (clockwise for passenger side and counter-clockwise for driver side). I found that you may need to use either your left or right hand to get good leverage on turning the housing. It can be a bit tight.
5) Carefully remove the bulb from the foglight assembly. What I did was use a paper towel to protect the bumper as well as prevent the new bulb from getting dirty. (Pic 003)
6) Disconnect the bulb housing from the wire. (Just pinch both sides of housing to release the clips)
7) Slowly and carefully pry the bulb from the grey housing and reinsert the new bulb.
8) Reinstall by connecting the housing back to the wire, and then reinserting the bulb into the fog light assembly. Make sure you line up the grey tabs to fit into the fog light assembly slots. (Tip: Mark one of the grey tabs with a pencil so you know where it goes when you reinstall) Press all the way in and give it a good turn until you can't turn anymore. Verify your work by making sure all 3 tabs are fitted into the slots. A flashlight really helps. (Pic 004)
9) Reinstall mesh covers. Don't tighten the screws too much otherwise you may break the cover.
That's it, your done. No more ugly yellow lights.
I also included two pics. Pic 005 shows with the Eurolite bulb passenger side and stock bulb on the driver side. (My camera sucks so the pics don't do it justice. Believe me, they do look good, and the light is bright white).
Pic 006 is a close up of the Eurolite bulb in action.
These instructions don't say how to align and and then turn for re-install. Can you be more specific?
Old Aug 4, 2020 | 12:58 AM
  #42
aaronBLUEeyes's Avatar
‘17 C43 AMG, ‘10 C300 4MATIC Sport (previous)
i have a set of LEDs I'm gunna try and install, hopefully, no error codes!
You have already rated this thread Rating: Thread Rating: 9 votes, 5.00 average.
