Meisterschaft exhaust installed doubts
thanks hope anyone could help
Your MB has built in sound dampening in the body to lower outside noise. Most of the sound coming in is from the spare tire well which is closest to the exhaust and only a thin piece of plastic. As suggested, give it a few hundred miles to break in to eventually settle on the final tone.
http://www.secondskinaudio.com/
Planning ahead plays a huge part in this task, so spend time there. Basically use a piece of paper to make a sample cutout of the shape you want. Do this for the whole area to be covered, then cut the shapes out of the damplifier material to get a precise fit. More surface area you cover, the better. Remember, this (along with Dynamat) are vibration reduction material, which is one aspect of the noise. Luxury Liner Pro is a dense foam material that blocks out the rest of the road noise and is laid out on top with aluminum tape covering the edges.
https://mbworld.org/forums/c-class-w...d-you-use.html
