Black vinyl for chrome window trim...pre-cut?
Old Mar 13, 2010 | 02:58 PM
NJBNZ's Avatar
'09 C300 4Matic Sport
I've seen some guys wrap their chrome window trim in the black or cf vinyl trim...do these strips come pre-cut or do you just buy the material and cut it yourself?
Also has anybody used this material to wrap the door pillars? I'm sick of always having to wipe off fingerprints on the glossy black surface.
Thanks...
Old Mar 13, 2010 | 03:56 PM
Azn_C300's Avatar
Mercedes C300 Sport, BMW 745Li, VW Mk6 Golf TDI
I'm sure I can come up with a precut for you if interested. But you might as well just buy a sheet and cut your own strip.
Old Mar 13, 2010 | 04:09 PM
alexlev's Avatar
C204
Someone mentioned that the bottom chrome trim slides out . . Is that so & how do I go about pulling them out?
I made cut outs for the bottom piece a few weeks back but the edges are beginning to peel. If there was only a way I could get the vinyl to wrap around the edge.
NJBNZ, I purchased vinyl from stickercity and just cut it myself. Fairly easy task overall.
Old Mar 14, 2010 | 04:01 AM
ShaiMalka's Avatar
ccoupe
Some might laugh, but I went and bought myself some black electrical tape... Wrapped the window trim myself. I bought 3m electrical tape if you think about it its basically "precut" as in width =]
Old Mar 14, 2010 | 11:16 AM
NJBNZ's Avatar
HaHa that's one way of doing it. How is it holding up? Any peeling?
So you just laid the vinyl strip on with the chrome strips still on the car? Could that be why the edges are peeling...because it's not wrapped around the trim?
And yes how do you take the trim off? Do you pull them off, slide them off, etc?
Old Mar 14, 2010 | 03:54 PM
alexlev's Avatar
C204
Exactly. I haven't done the upper chrome trim but it looks a lot easier being that you can wrap the vinyl around the edge.
Old Mar 16, 2010 | 02:36 PM
cvkatigbak's Avatar
C300 MT, 350Z
Trimbrite Blackout Tape
http://www.amazon.com/BLACK-OUT-TAPE.../dp/B00029XD62
The four chrome pieces on the door are easy to pop off. Just use a small flat head, wrap it in a towel, and push the pieces out. The long stretch from front to back is the hard part. I didn't attempt to pop it off. I just constantly wet it and applied. It took a lot of patience to get it on right, left a few air bubbles but they eventually went away after being in the sun for about a week.
By the way, you're gonna want to buy two of those rolls of black out tape just in case you screw up.
Old Mar 16, 2010 | 02:38 PM
cvkatigbak's Avatar
C300 MT, 350Z
How often do you have to reapply a new piece of tape?
Use trimbrite. It's weather proof. Installed a year ago and haven't had any peeling or anything on it since.
Old Mar 16, 2010 | 03:17 PM
BerBer63's Avatar
2009 C63
Is it matte/flat black or gloss black?
Old Mar 16, 2010 | 04:36 PM
Richard2011's Avatar
2015 BMW M235i 6MT
cvkatigbak, what is that front lip in your sig?
Old Mar 16, 2010 | 05:00 PM
cvkatigbak's Avatar
C300 MT, 350Z
matte black
RevoZport lip
Old Mar 16, 2010 | 06:14 PM
NJBNZ's Avatar
Did you remove the chrome strips or did you apply the trimbrite while the chrome trim was still on the car?
Old Mar 16, 2010 | 06:51 PM
alexlev's Avatar
C204
I was trying to "slide" it out and during the process broke the plastic cap on one side, at which point I realized that "sliding" it out wasn't the proper way of doing it.
Thanks for the clarification and link for the rolls of tape
Old Mar 16, 2010 | 07:07 PM
BerBer63's Avatar
2009 C63
The way I've seen it done on cars at shops is with the chrome strips attached. They just use a plastic squeegee or vinyl spatula to roll it around the curves and in the gaps.
Old Mar 16, 2010 | 07:48 PM
alexlev's Avatar
C204
I did exactly that with the chrome trunk piece but the bottom side pieces have little to no space for the vinyl to wrap around without peeling off after a while. The top chrome pieces on the other hand, look like they're easy to deal with.
Old Mar 16, 2010 | 08:24 PM
2015 BMW M235i 6MT
RevoZport lip
Oh. Now that I look at it, it does look like that lip. You just painted the top part.
Old Mar 16, 2010 | 08:45 PM
NJBNZ's Avatar
Oh okay...I see what your saying...but wouldn't the tape/vinyl fold or crease when rolling it over the edges and around the bends?
Old Mar 30, 2010 | 01:09 PM
mbgonz's Avatar
c-350
door trim
Just did the window/door and license plate trim in black matte. The car is steel gray and it looks much sportier. I had already removed the lower door trim. Love the way the car looks. I had it done at a shop for $80.00 dollars.
Old Mar 31, 2010 | 07:48 PM
NJBNZ's Avatar
Okay so for those of you who wrapped your window trim in black vinyl...how in the world did you do it??? I decided to just do the top piece (that curves over the windows) but couldn't get it on right because of the curve of the trim. No matter what I tried it either wouldn't go on straight or would fold and crease.
Any tips/help is greatly appreciated!
Old Mar 31, 2010 | 11:36 PM
Sentosa's Avatar
C200 Estate Kompressor W204, 2018 GLA 220d
Thanks...
You can probably buy the bottom pieces and just swap them out. Probably just as cheap. My car came that way.
