hid question..adjuster
Old Mar 22, 2010 | 11:46 PM
tbuix3's Avatar
c350
i have a c350 2008 p1 package. when i installed the hid, the driver side, the hid is not pointing straight, it is pointing downward. is there a way i can adjust the direction? is there any adjusting i could do? help plz
Old Mar 22, 2010 | 11:54 PM
Normandie4life's Avatar
Black C300
maybe u havent placed the bulb right on the spot i had the same problem just mess around the bulb be careful with it and u should get the position u want it to be in
Old Mar 22, 2010 | 11:58 PM
tbuix3's Avatar
c350
the bulb is seated perfectly. its aligned with the holder and everything.
Old Mar 23, 2010 | 12:16 AM
Black C300
just try to reposition it
Old Mar 23, 2010 | 12:18 AM
tbuix3's Avatar
c350
tried many ways. any help guys? where are the screws to adjust the headlight? any pictures?
Old Mar 23, 2010 | 05:20 PM
JoeVal's Avatar
C350 Elegance
Are you doing it with the steering and the wheels pointed straight ahead? Don't forget they are self aligning, so what I first would do is to start the car, put the low beam on, and make sure the car is pointing straight ahead and the steering wheel is in the same position. Then I'd verify the correct beam aim, switch the car and light off and install the HIDs.
Old Mar 23, 2010 | 08:26 PM
Richard2011's Avatar
2015 BMW M235i 6MT
The bulbs only go in one way. I've tried.
Also, the screw to adjust the height is the white knob just above the low beam cap.
Old Mar 24, 2010 | 12:27 AM
Spec_Davis's Avatar
W204 Color: 090 / 1999 Honda Civic EX / 2003 Acura TL
its a white knob that requires a hex bit to adjust it
