vibrating shifter
Old Apr 4, 2010 | 06:08 PM
RKMA86's Avatar
C300
vibrating shifter
When in neutral, the shifter is shaking/vibrating a bit at idle...is this normal? (The car is a 6MT)
Old Apr 4, 2010 | 07:02 PM
C300Kid's Avatar
2015 Carrara White Metallic Porsche Cayman
how bad? mine vibrates very slightly, but no more than any other manual car ive driven. none are completely still.
Old Apr 4, 2010 | 08:40 PM
C300Sport's Avatar
2008 C300 Sport 6 Speed Manual, 1953 Chevy Bel-Air, 2015 Audi allroad, 1963 Chevy Apache
Same here, I get a bit of wobble but nothing worrisome. Sometimes it seems more prounounced than others...I can simply slide it over a bit and return it to center and it often stops or at least reduces its little dance.
Old Apr 4, 2010 | 08:47 PM
mat2hu's Avatar
C350
my vibrator starts shaking depending on how high my revvs are at and im auto. towardss like 5,000 rpm if i hold it there, the shifter is shaking a lot.
Old Apr 4, 2010 | 08:56 PM
C300Sport's Avatar
Did you really just say your "vibrator"...
If you have an Automatic, I wouldn't think you should have any shaking and very little vibration.
Old Apr 4, 2010 | 09:21 PM
C300Kid's Avatar
I'm driving now and when in neutral it doesn't shake at all...I couldve sworn it usually shakes a bit...I guess it's not all the time.
jctevere's Avatar
2012 C250 Coupe
LOL! @ Original topic... Some vibration is expected. Especially on start, or cold starts. Do you use regular gas or premium octane? If you can gently place your hand on top and you can see your fingers shake, it could be a bit excessive. If your worried you can take it in for service.
Old Apr 5, 2010 | 01:45 AM
joshg1001's Avatar
2017 E300
the gear shifter is the only part of the car that really vibrates at idle.
Old Apr 5, 2010 | 11:19 AM
Distalero's Avatar
C 300
First MT, or developed a new habit of keeping your hand on the shifter knob?
All car engines (internal combustion) vibrate a bit in the mounts (rotate a tiny bit against the mounts), and because the shifter/linkage arrangement is firmly mounted on the trans, it rotates a tiny bit as well. It's a function of torque.
Torque is you friend. No biggie
Old Apr 5, 2010 | 02:48 PM
Sportstick's Avatar
Another round of ICE
Barely perceptible tremor in shift knob at idle ~750 rpm, which completely disappears if idle is raised to ~900 rpm.
Old Apr 5, 2010 | 05:01 PM
Peabody's Avatar
My auto is as dead as the night. No vibes at all.
