How to change front fog lamp bulbs on 204 Sport?
Old Apr 9, 2010 | 11:36 PM
S204HONGKONG's Avatar
W212 E250 AV
Hi all, I need some help on how to change the front fog light bulb on my 204 Sport (the bulb blew). Do I need to pry open the front circular clear cover, or need to take it out from behind the front bumper?
Old Apr 9, 2010 | 11:38 PM
snarlingchicken's Avatar
2009 C350
Use a torx screw to unscrew the three screws that are securing the mesh around the fog lamp. As soon as you remove the mesh you can replace the bulbs from behind. Then do the process in reverse.
Old Apr 10, 2010 | 09:41 AM
AkaSigFreak's Avatar
E350 Sport/ML350RWD
Oh My God! Hopefully you didn't "pry" anything. It scared me just thinking about it.
Old Mar 21, 2012 | 02:20 AM
silkynitro's Avatar
C220CDI 2009
Removing Foglight cover
Hi first time on here, how do take off the front fog light cover to replace a bulb.
I have 2009 C220CDI Clasic I don't have the 3 torx screws you have mentioned however there's is about 1" recess hole just above the light can't see if there is a torx screw there or not can you or anyone help me out here thanks.
Phil
Old Mar 21, 2012 | 03:58 AM
2009 C350
Do you have the Sport/AMG model or the luxury/avantgarde model?
Old Mar 21, 2012 | 07:56 AM
silkynitro's Avatar
C220CDI 2009
I have the W204 C220 CDI Clasic modle 2009.
Right hand drive, I live in Australia
can you help thanks
Old Jan 10, 2013 | 08:16 PM
solid85's Avatar
s 204 2012
Thumbs up
can you help thanks
Yes I can help, you have the model where the grill has no screws only one hole with an allen key, do not mess with it because it aligns the light.
If you want to only remove the bulb you need to lie under the car remove the clips that holds the wing liner to the bumper and sneek your hand between the liner and bumper and rotate the bulb firmly till it dismantles u can see it through the lens of the fog light.
If you want to remove the whole thing it is kept in place by 4 plastic clips that hold it to the bumper similar to the clips that hold the front grill. You need to sneek your hand to the back of the lamp and press each clips gently one at a time pushing the housing forward as u push the clips to dislodge it from the bumper you press on the clips towards the centre of the lamp be careful not to break the clips...
Old Jan 10, 2013 | 09:32 PM
MBSebas87's Avatar
C300 Sport 4Matic
Haha I wondered the same thing when I had my 2009 c300
Old Jan 11, 2013 | 05:07 AM
silkynitro's Avatar
C220CDI 2009
Thanks for the info, I was going to replace them but haven't had a chance as yet, now I know how I'll take another look at doing so.
Thanks once again
Phil
Old Jan 11, 2013 | 09:57 AM
RickP330's Avatar
2019 GLA 250 - I am in purgatory right now...
you can't just replace the bulb. You have to replace the entire lenze assembly. Correct me if I am wrong...
RP
Old Jan 11, 2013 | 11:26 AM
itsLoonie's Avatar
2012 E350 RWD
RP
The bulb only can be replaced. Assembly does not have to replaced each time.
Old Jan 11, 2013 | 02:31 PM
solid85's Avatar
s 204 2012
RP
I am sorry to say you are wrong, you can change the bulb only without the lens, it is a H11 halogen 55 watt bulb, it comes in different colours and makes you can change it without removing the assembly, and definitely do not remove the circular trim around the lens, you need to access the back of the lamp which is easier on the right hand side than the left because of the windscreen washing fluid reservoir. You need to lie on the ground and remove the pin clips that holds the wing liner (the front end) with the underneath part of the bumper. And after removing the clips force your hand between the bumper and wing liner and rotate the back end of the bulb anti-clockwise you can see through the lens till the spokes disengage from the bulb housing. You can then remove the plug from the bulb from under the bumper. Fitting is reversal of dismantling.
