Eyelid LED and Foglights
C350
What Eyelid LEDs' and foglights are you guys using? I am looking for 8000k color and i was wondering which brand is good and doesnt have any problems
C350
I did a search but im confused on which one is the best in the market right now, it seems like some LED's like iJDMtoy are giving problems like melting the socket and stuff..
To be honest there is no LEDs that I know of which doesn't cause problems. Most of the members have chosen to go with the polarg m4s which are normal halogen bulbs are tinted. As for the foglights you have alot of options to choose from. You can choose to go HIDs or once again tinted halogen bulbs.
C350
Yeap there is only one colour. I'm using the Diamond Visions with is rated at 5000k for my fogs. Might be switching over to HIDs in the future I think.
2012 C250 Coupe
LED's will either burn or turn color over time due to amperage differences while driving.
Go with tinted halogens, you barely lose any light output. I have GP Thunders, 7500k, and I love them, they also have a 8500k bulb. I have them in the headlights and fogs, and have Polarg M4's in the eyelids, looks great and matches pretty well... Only complaint is that the eyelids are not very bright (but not darker than OEM lights, just didn't get brighter) But the fact is that when the headlights are on you barely see them anyway...
To your question, Polarg M4's are Super White, which means it has a blue hue to it, its not white white, so it matches a 6400k-7500k light pretty well, 8500k might appear much more blue than the polarg. I believe that headlight and Fogs take H7 blubs, and the eyelids takes 194's? I am 90% sure, maybe someone can confirm?
Also, I am going to put on Lamin-X tints on both as well, and I doubt that even then I will have brightness problems... I did however, adjust my headlights to aim higher than OEM, because with OEM I could barely see 10 feet in front of the car, now it is much better (and no, I am not blinding people, only about 4" higher on the wall on both sides, still lower than my escalade headlights.
I'm still using the iJDMtoy LED eyelids. They haven't shown any signs of significant burn or damage to the socket. Nor have they changed color over the span of what has now become 5 months. Eyelid bulbs are W5W.
That's what I thought as well but another member just posted that the iJDM LEDs melted his housing =x I was initially planning to switch them until I saw his post.
2009 C350
I've been using iJDMtoy LED eyelids for over 7 months without any issues. Wonder why some people got their LEDs burnt so frequently.
I think I'll go check mine out again.....and yeah Royce, I just saw the post. Anywhoo. To those who have used iJDM, did you guys use the multi-directional ones that were $28 or the ones that just had one SMD on each side? (The $26 ones?) Maybe we can somewhat narrow the choices down..
2009 C350
How do I remove the fog light bulb after removing the mesh grille? Do I just pull the bulb out from the front or I need to remove the fog light housing to install the new bulb?
I have led eyelids for a month now, and still working.
I also have 8000K HID, and my led eyelids are almost the same collor.
I have both form Pilot Xenon, but i think it isnt availlable in the US.
2012 C250 Coupe
The official and correct way would be to remove the foglight housing via the front wheel wells and removing the plastic protectors. However, if you are careful and have small hands it is possible to pull the light out front the front mesh by reaching behind...
LED car light manufacturer
We are a manufacturer of LED car lights in China.If you need any LED car lights,pls contact with me.I will glad to serve for you.
Our website is http://www.dgruidi.com
And you can contact with me at any time.
Sincerely yours,
Linda
Dongguan Nordy Electron Co.,Ltd.
MSN:ywlednordy@hotmail.com, tjlinda@live.cn
Skype:linda19881021
Yahoo Messenger:moira1988@yahoo.com
Linda
Skype:linda19881021
Email:nordy@dgruidi.com
Mobile phone:+86-13532717137
Website :http://www.dgruidi.com
Mercedes C300 Sport, BMW 745Li, VW Mk6 Golf TDI
Sincerely yours,
Linda
Skype:linda19881021
Linda
Skype:linda19881021
Usually,the Voltage is 12V or 24V.
You can add my MSN: ywlednordy@hotmail.com
So we can talk about this.
You say you're the manufacturer? Would it be possible for you to test your LED on a w204 test vehicle? I've worked with other manufacturers in the past and organized group buys here on MBWorld...all claim their LEDs will work just fine with our model but due to unique nature in shifting voltages, all have prematurely burned out at best, or melted and damaged sockets at worse. Their LEDs work fine when idle, but not after driving. If you can prove that your LED can handle this condition...well, congratulations, you've just created a monopoly and will get orders pouring in
Yes,we can promise the LED quality.Because the raw material of LEDs we produce,and all LEDS have tested by our engineer.
For the lights you said,could you send me a picture or futher information?We can send you a sample,let you try.And check the qulity.If you think it is ok,you can consider the next step.
My email is nordy@dgruidi.com
email sent.
For reference, here's the last two group buys I tried to organize
https://mbworld.org/forums/c-class-w...anbus-led.html
https://mbworld.org/forums/c-class-w...round-2-a.html
2012 C250 Coupe
If this works out I would be interested in a group buy. My car is a lease though, so I am thinking of just going with Polargs for safety reasons of not wanting to mess up my wiring and stuff.
For those of you that have burnt their harnesses and cables, how much did the repairs cost you?
2009 C350
"Check right parking light" message came up on my dashboard while I was driving this morning, the light was still on when I checked it though. I've been using iJDMtoy LED eyelids for over 7 months without any issues. Wonder if the bulb is about to burn out or something else.
