First full C63 AMG front & rear brakes BBK retroft to w204 with only original parts
Old May 7, 2010 | 04:48 PM
perdikoula888's Avatar
Arrow First full C63 AMG front & rear brakes BBK retroft to w204 with only original parts
First full C63 AMG front & rear brakes BBK retrofit to normal w204 with only original parts
Everything fits perfect and performs excellent!!
I have just completed a full C63 AMG front & rear brakes BBK retrofit to my non-c63 w204. I am posting some photos and I have compiled a complete list of the parts used. Everything original MB OEM parts. No aftermarket parts and taiwanese brackets. I think this is the first retrofit ever attampted with no aftermarket parts at all. I hope this helps!!!
FRONT BRAKES
A2044214798 x1 CALIPER - PARTS KIT, LEFT
A2044214898 x1 CALIPER - PARTS KIT, RIGHT
A0004214765 x2 BLEEDER VALVE - WITH DUST CAP
A0014210991 x2 SPRING
A0004215174 x2 TS BOLTS PARTS KIT
A2214210014 x2 PULL ROD
A0169900601 x2 BOLT
A0044208920 x1 BRAKE LINING/TS DISK BRAKE PAD - PARTS KIT
A0019900814 x4 BOLT - CALIPER TO STEERING KNUCKLE M14x32
A1715400617 x1 BRAKE WEAR SENSOR - BRAKE LINING WEAR INDICATOR
A2194210212 (or A2124210512) x2 BRAKE DISC - FRONT
A2044211320 x1 PROTECTIVE PLATE - LEFT
A2044211420 x1 PROTECTIVE PLATE - RIGHT
A2094280135 x2 BRAKE HOSE - FRONT LEFT AND RIGHT
A2043321901 x1 STEERING KNUCKLE - LEFT
A2043322001 x1 STEERING KNUCKLE - RIGHT
A2043220122 x2 PIVOT PIN
A2119810227 x2 ANGULAR CONTACT BEARING
A2113570508 x2 FLANGE
A1403570572 x2 NUT
A0019904203 x8 BOLT - BEARING AT STEERING KNUCKLE
A2113331114 x2 BEARING - STRUT
A2043304911 x1 CROSS STRUT - LEFT
A2043304911 x1 CROSS STRUT - RIGHT
A2045401817 x2 SENSOR - RPM SENSOR, FRONT
A2044013902/B66030098 x2 DISC WHEEL-5SPOKE WHEEL FRONT AXLE 8Jx18 H2 ET45
A0035400217 x2 (optional) TIRE PRESSURE SENSOR - TPMS CHECK 433.92MHZ
REAR BRAKES
A2044234198 x1 CALIPER - PARTS SET, LEFT
A2044234298 x1 CALIPER - PARTS SET, RIGHT
A0014210791 x2 SPRING
A0004214274 x2 PIN - PARTS KIT
A0189900001 x4 BOLT - CALIPER TO WHEEL BEARING
A0054202520 x BRAKE LINING/TS DISK BRAKE PAD - PARTS KIT
A1715400617 x1 BRAKE WEAR SENSON - BRAKE LINE WEAR INDICATOR
A2044230412 x2 BRAKE DISC - REAR
A2044014002/B66030099 x2 DISC WHEEL-5SPOKE WHEEL FRONT AXLE 9Jx18 H2 ET54
Attached Thumbnails First full C63 AMG front & rear brakes BBK retroft to w204 with only original parts-20100416_001.jpg   First full C63 AMG front & rear brakes BBK retroft to w204 with only original parts-20100416_006.jpg   First full C63 AMG front & rear brakes BBK retroft to w204 with only original parts-20100507_009.jpg   First full C63 AMG front & rear brakes BBK retroft to w204 with only original parts-20100507_010.jpg   First full C63 AMG front & rear brakes BBK retroft to w204 with only original parts-20100507_011.jpg
First full C63 AMG front & rear brakes BBK retroft to w204 with only original parts-20100507_012.jpg
Old May 7, 2010 | 04:50 PM
more photos:
Attached Thumbnails First full C63 AMG front & rear brakes BBK retroft to w204 with only original parts-20100507_014.jpg   First full C63 AMG front & rear brakes BBK retroft to w204 with only original parts-20100507_015.jpg   First full C63 AMG front & rear brakes BBK retroft to w204 with only original parts-20100507_016a.jpg
Old May 7, 2010 | 04:58 PM
omgitselaine's Avatar
Lexus IS 350 F Sport
Looks greaat !!!
Dare I ask how much the total expense was .... including labor ?? I am sure it costs a lot more than the red caliper paint I'll be getting soon !!!!
Old May 7, 2010 | 05:36 PM
It was quite expensive, I lost count after a while because I bought many different parts for various retrofits and also exchanged some more parts, however it cost me less than expected. The end result was well worth it though. Great looks and superb braking power. Difference is very noticeable.
Old May 7, 2010 | 05:46 PM
YYZ-E55's Avatar
MY17 E43 Matte Selenite/Macchiato Beige, MY16 GLE350d Tenorite/Crystal Grey, MY17 B250
Great post with part #s!
Here's the first:
https://mbworld.org/forums/c-class-w...e-amg-bbk.html
Old May 7, 2010 | 06:04 PM
Here's the first:
Not actually, as they used aftermarket wheels and taiwanese mounting bracket adapters, and aftermarket wheel spacers to compensate for the incorrect offset. My post states first ever retrofit with only original MB parts! everything bolt-on without voiding original warranty. I hope this clears up any ambiguity.
Old May 7, 2010 | 06:13 PM
YYZ-E55's Avatar
I believe he replaced the entire steering knuckle (as required), and not the "taiwanese mouting bracket adapters" you keep referring to.
Old May 7, 2010 | 06:25 PM
Still aftermarket wheels and adapters as far as I can tell from the photos he posted, I don't know what is behind as there are only photos with the wheels mounted. Full list of parts required has been provided above. Still not clear if he changed all these parts.
Old May 8, 2010 | 06:20 PM
I am attaching some photos of the end result.
Attached Thumbnails First full C63 AMG front & rear brakes BBK retroft to w204 with only original parts-20100508_001.jpg   First full C63 AMG front & rear brakes BBK retroft to w204 with only original parts-20100508_002.jpg   First full C63 AMG front & rear brakes BBK retroft to w204 with only original parts-20100508_003.jpg   First full C63 AMG front & rear brakes BBK retroft to w204 with only original parts-20100508_004.jpg
Old May 8, 2010 | 06:26 PM
more photos:
Attached Thumbnails First full C63 AMG front & rear brakes BBK retroft to w204 with only original parts-20100508_005b.jpg   First full C63 AMG front & rear brakes BBK retroft to w204 with only original parts-20100508_006a.jpg   First full C63 AMG front & rear brakes BBK retroft to w204 with only original parts-20100508_008.jpg   First full C63 AMG front & rear brakes BBK retroft to w204 with only original parts-20100508_009.jpg
Old Aug 31, 2010 | 04:40 PM
larseu's Avatar
S204 2008 C 320T CDI 4MATIC AMG sp - R172 SLK 200 AMG
more photos:
Are These part numbers equal to the red Performance pack brakes
for the C63 ?
and is ther anybody who know the partnumber for the red calipers ?
Old Aug 31, 2010 | 07:37 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
looks good. congrats
Old Nov 26, 2015 | 03:57 PM
w204maniac's Avatar
c200 kompressor
amazing!!!congrats my friend.(labisnik from mbclub)
i d like the same project but the cost is too high i suppose!
Old Nov 29, 2015 | 06:35 AM
yacoub.alyacoub's Avatar
2012 C200 CGI AMG Sport,2011 SLK 200 Komprs R171 2000 Toyota Land Cruiser GXR, 2007 Jeep Wrangler JK
less than expected can you give us either the expected number
or the approximate number to what you’ve paid to reach this amazing result
Old Mar 20, 2026 | 11:35 AM
Yurii204w's Avatar
c250cdi w204 coupe
Hi, what about the shock absorber struts? Didn't you have to change them on the AMG?
