A5 Service due in 180 days
WTH is an A5 service? All I know is that it dosent' sound good and I can't find any reference to what the number indicates after the A.
TIA
Rick
PS I have 50K miles.
RickP
RickP
I honestly don't know. I wouldn't worry too much. They (my dealer) always tell me that they really don't pay attention to the indicator in the U.S. They just base everything on miles.
But now i am thinking, did i make a mistake and should have asked him to do service B, the reason i took the car to the dealer in the first place, or did the Sales guy just save me a couple of hundred buck ?
Also he didnt say anything about my tyres, from most of the other post it appears my conti should be near retiring, but no one said anything to me.
Advise will be appreciated.
My Conti pro's lasted 35K miles, you should have a bit left yet - I drive hard. When I go to the dealer, the first thing they do is measure the tire tread.
RP
Oh and you didn't get a brake fluid change which is extra over service b anyway, but suppose to be at year 2.
Put your fingers in grooves of rear tires and check. Is there still some tread before the warning bars? You can compare it to the front too and the fronts should have more tread left.
- Replace Wiper Blades
- Rotate Tires ( excluded in vehicles with staggered wheels )
- Replace heating and ventilation dust filter
- Inspect front axle ball joints, check steering play and power steering clutch and rear differential levels
- Inspect poly V-Belt for condition
- Inspect starting and charging system and service battery
- Inspect climate control refrigerant
So I agree with mac911, the only thing you didn't get effectively was a new cabin dust filter.
Nick
The service guy said that you should do the A/B service annually for every 10K - 13K miles, which lines up with your oil changes. He also said that sometimes you'll get a C-F service, which is essentially an A/B service with something additional (Brake Fluid Flush, etc.).
RickP
MY ADVICE IS TO JUST FOLLOW YOUR MAINT. MANUAL...EVERY 13K MILES YOU NEED AN OIL CHANGE, ABOUT EVERY OTHER TIME YOU NEED AIR FILTERS CHANGED, AND ABOUT EVERY 2 YEARS YOU NEED BRAKE SYSTEM FLUSHED. Other than that you only need the 39k mile transmission service. I am only going to the dealer now for oil changes, those A and B services are nothing more than a glorified oil change and a total waste of money. They do a 27 pt. inspection with an oil change anyway and my dealer only charges $80 for an oil change. If other things go wrong with the Benz you will know because you'll hear your brakes going bad or anything else will show up as a warning in your instrument panel. I think MB has got quite the scam going with their A/B services. Think about all the other brands you've owned and no one else charges so much for a frickin' oil change...some brands have special high cost services at 30K, 50K miles, etc. but not every damn service appt. THEY ARE JUST OIL CHANGES PEOPLE
