Old Jun 10, 2015, 02:55 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Guides
Print Wikipost
how often oil change c300??
Old Jun 24, 2010 | 07:16 PM
blueacc333's Avatar
C300
my ride only has 12000 miles.. for almost 2 years.. I only had one oil change since then.. how often do u guys change the oil on this c class??
Old Jun 24, 2010 | 07:33 PM
I am Jeff's Avatar
Steel Grey Metallic C63!!
once a year if you don't meet the mileage requirements.
Old Jun 24, 2010 | 07:36 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Don't worry about your oil. Change it whenever you want to. And while you are at it, you can save more money by using regular gas instead of premium. Another saving tip is to not wash it. Dirt accumulation will make it heavier. This will have the benefit of lowering your car and thereby assisting your tires with providing added traction during inclimate weather.
$0.02
HTH
Old Jun 24, 2010 | 08:24 PM
bulletspec's Avatar
'08 C350, '05 Mazda 3 HB, '07 330i
^^ That's harsh
about not changing your oil.......
You should know better
Old Jun 25, 2010 | 12:42 AM
blueacc333's Avatar
C300
Originally Posted by bulletspec
^^ That's harsh
hahhaa.. that doesn't make any sense.... lolz.. I will not treat my ride that way... I heard that just change the oil filter every 6000miles, not the motor oil... Do u think its a good idea???
Old Jun 25, 2010 | 01:08 AM
justthinking's Avatar
2008 C300 Sport, 2010 RX350 AWD
don't cheap out, if you can't afford service A and service B once a yr, you don't deserve to own the car period...
Old Jun 25, 2010 | 01:34 AM
blueacc333's Avatar
C300
hahhaa not planning to do that.. just wondering??? lolx.. oh well.. I think oil change at every 8000 miles is okay.. not cheap out?? lolx.. u got any pixs of your ride?? any mods... share...
Old Jun 25, 2010 | 01:40 AM
the problem is oil degrade over time, after sitting in your engine for a year, even if you only drive let's say 5,000 miles, the oil would still degrade to a point that it can no longer get the job done due to reasons such as oxidation, deposits, thermal degration & corrosion...
Old Jun 25, 2010 | 01:48 AM
blueacc333's Avatar
C300
yup.. its true.. but why dealers set at 13000miles?? r they stupid?? lolz I think 13000miles is over killed.. 8000 miles for me is okay
Old Jun 25, 2010 | 02:03 AM
the synthetic oil MB use actually is rated for 15k miles OR 12 month depend on which ever came up first...so just follow the schedule and change your oil either every 13k miles or every yr..since you are in so cal, there should be tons of coupon and you should have no problem get service A at around $200 and service B at around $300..
Old Jun 25, 2010 | 02:09 AM
blueacc333's Avatar
C300
thanks.. but I always do all the oil change myself for all my rides.. what color your c300? mine is White.. any mods on lightings interiors?
Old Jun 25, 2010 | 02:13 AM
blueacc333's Avatar
C300
that what I did for the last oil change.. actual one year.. with only 6500 miles.. this time maybe 8000 miles.. how does it feel driving in the snow in NY??? Tire chains all time?? or like driftings all time.. haha.. Does the C class handle well in snow??
Old Jun 25, 2010 | 02:23 AM
not a whole lot of mods, just added rear trunk spoiler, change side marker to clear & stealth bulb, changed the license plate bulb to white led & will get my window tinted this weekend..
Old Jun 25, 2010 | 03:39 PM
I am Jeff's Avatar
I changed my oil at 3800 miles (that was after 1 year). It's not the car, it's the driver when you're dealing with snow. I don't chain anything up, I have Z-rated summer tires. It handles fine in the snow for me, the traction control lights up like a christmas tree. I have other cars for the winter use. This was a spur of the moment purchase.
Old Jun 25, 2010 | 04:01 PM
blueacc333's Avatar
C300
I see.. A very good driver.. ahahha low mileage.. huh.. yea. I don't drive with this car often either.. very low mileage...
Old Jun 25, 2010 | 05:35 PM
RLE's Avatar
RLE
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
Filter only?
It's a dumb idea. Where do these things come from?
Old Jun 25, 2010 | 05:51 PM
Sportstick's Avatar
Another round of ICE
After reading this thread, I am astounded at the unsubstantiated "conventional wisdom". Open the owner's manual, look for the maintenance section, and do what it says, whether at a dealer or other competent shop. The oil change concept is simple, time or mileage, whichever comes FIRST. The intervals were developed by the company who designed the engine. Why is this so difficult?
Old Jun 26, 2010 | 01:47 AM
blueacc333's Avatar
C300
how often for the transmission service?
Old Jun 26, 2010 | 03:49 AM
every 2 yrs for brake fluid flash and every 3 yrs for transmission service I believe..
Old Jun 26, 2010 | 09:18 AM
Sportstick's Avatar
What does the owner's manual show? When you ask us, you risk one of us getting it wrong. Read the book!!
Old Jun 26, 2010 | 10:13 AM
Will38's Avatar
2008 C300
The dealer made me change transmission oil when my car had 40,000 mile (2 years) Charge me 300 for it... felt kinda expensive...
Old Jun 26, 2010 | 07:43 PM
RLE's Avatar
RLE
Trans change
That is the correct mileage and has been since 2005. Yes, it's expensive but a transmission replacement due to neglect would be "slightly" more.
Old Jun 27, 2010 | 12:16 AM
blueacc333's Avatar
C300
300?? did they flush the system?? if flushed.. then i think it was a good price... probably they just changed the fluids... wtf,,, I'm on Probation!
Old Jun 27, 2010 | 02:34 AM
A Service - $99 to $199
B Service - $229 to $299
brake fluid flush - $99 to $129
coolant flush - $99 to $129
power steering flush - $99 to $129
transmission drain & flush - $299 to $349
4-wheel alignment - $99 - $129
these are from my past experiences servicing 04 c240, 06 c230 & 08 c300..
most of the time I will servey and see what service special other northern california dealers have & let my dealer price match it..
if I really need to get the service done and no good coupon available, then look for dollar off coupons will work too..
Old Jun 27, 2010 | 03:49 PM
Will38's Avatar
2008 C300
ya I saw them flush everything, it was 300 for oil change and transmission oil change. I guess it wasn't that bad of a deal.
You have already rated this thread Rating: Thread Rating: 1 votes, 3.00 average.
