Put your Contacts from a PC or Mac in your Mercedes
If you need help on how to it drop me an email, I'll run you thru it, Good Luck.
Step 2 copy the newly created file into the root directory of your media card, and insert the card into your PCMCIA slot in your mercedes. Then goto phone menu, then scroll all the way to down to the bottom left corner and select "Phone" menu, then select "Address Book" then select "Import Vcard" then Select "PCMCIA Card" and it will import the file you just created.
Note this will only work on cars with either UMI or Command Package as you need a PCMCIA slot. If you do not have a PCMCIA slot you can select the "Bluetooth" option and send the files from a Vista laptop(requires Vista to do it for free as OBEX FTP is built in to Vista, If you have an Xp laptop you will need something like http://www.brothersoft.com/medieval-...fer-57305.html to do it) to your car as well using the same file you created in the Step 1.
