check front right parking light warning..
However, when I re-start the car after the meeting, the msg has disappeared and both bulbs on the front right parking lights were working..
Today, the error msg appeared again and I was able to verify one of the front right parking light is indeed out..however, the warning msg disappeared and both bulbs were working again after I drove back from autozone and was ready to replace the bulb..
What do you guys think? Simply a bulb problem or is it possible a more serious electrical problem?
Replaced with new Sylvania bulb, did not fix. Took bulb out, sprayed socket with electronic tuner cleaner, carefully pulled the bulb prongs slightly away from bulb and put back in socket. Problem fixed.
Hope this helps.
I've also noticed that error messages can pop up for the parking/sidemarker bulbs because of the way they're wired. The parking bulb can go out/error out because of an issue with the adjacent sidemarker bulb (I believe the outer eyebrow bulb is the "sidemarker" one), voltage and current measurements in the front SAM unit detect an "error" and will power off the "failing" bulb until the car is powered off and started up again. It's very annoying and finicky. Sometimes you can replace a dead bulb and it still won't turn on until you've left the car off for a bit.
So far I've only found two solutions to this
1. Replace both bulbs at the same time, or all four (both sides)
2. Variant coding tweaks + optional LED bulb upgrade. I've turned off PWM clocking and disabled the "open load recognition" parameters so the bulbs will always light up until they are truly dead. I'd probably not do this tweak with standard incandescent bulbs though, if anything goes wrong and they heat up a lot, they can partially melt the bulb housing. Another thing I did for the LED bulbs was lowered the voltage regulation from 13.2 volts to 12V, LED bulbs are happy with 12V anyway, and I assume the lower voltage/current output will reduce heat in the housing as well.
The eyebrow bulbs were a constant source of irritation until I figured this out, I was going through incandescent AND LED bulbs almost every two months..
I use leds in my c300 eyelids and this happens (sometimes) when they are old and start to burn out. (also, winter makes old leds cry. Use better solder my china peeps?
Before you do anything check the insulation on the wires.
