AZN Optics 5W5 Canbus LEDs
Old Jan 14, 2011 | 08:28 AM
  #326
ultimatefelix's Avatar
C200 CGI
Payment Sent (Unique Transaction ID #34X58380CW093381A)
Thanks man~
Old Jan 14, 2011 | 10:22 PM
  #327
stogge's Avatar
2014 e350 Luxury
Mike, got the lights today and LOVE them!! Thanks for the great customer service! Here are a couple pics... Let me know when the Turn Signals and Reverse lights are ready!!
Old Jan 15, 2011 | 05:32 AM
  #328
xXHotelCrazyXx's Avatar
2008 W204 Sport
How many leds are in each headlight assembly?
1)I am interested in the leds for the headlights (Eyebrow and turn signal)
2)Front bumper leds
3)license plate leds
am i missing any other exterior bulbs i will need? Sorry for the noob ?'s, i just bought a C300 for the wife
Old Jan 15, 2011 | 12:06 PM
  #329
AZN Optics's Avatar
SPONSOR/MBworld Guru
2 LEDs (1 set) per headlight assembly. So you'll need 2 sets for your eyebrows, 1 set for your bumper sidemarkers, 1 set for your rear plates. If you want to get into interior, these LEDs work great for interior front footwell ambient lighting and interior trunk lighting. I'd highly recommend the footwell lighting as it looks pretty amazing sitting inside.
Old Jan 15, 2011 | 01:38 PM
  #330
2008 W204 Sport
I will do the interior later...but for now i need the ones you mentioned (did you include turn signal bulbs?)
Old Jan 15, 2011 | 03:37 PM
  #331
2008 W204 Sport
Can i get a quote for
1) both eyebrows
2) turn signal lights in the headlights
3) bumper lights
4) rear license plate lights
am i missing any other exterior? Thanks!
Old Jan 15, 2011 | 08:06 PM
  #332
C300 EPM's Avatar
C300 BLACK Sport
Any idea why this is happening
Hi Mike,
This problem just started a few weeks ago. The left side are fine.
Only the right eyelid did not shut completely off when the light switch is off. but when i turn the switch to on, the eyelid turn brighter. Do you think is a defect on the circuitry of the leds?
I attached 2 picture, one with the power off and the brighter ones are with the power on.
Attached Thumbnails AZN Optics 5W5 Canbus LEDs-img00191-20110115-1650.jpg   AZN Optics 5W5 Canbus LEDs-img00192-20110115-1651.jpg
Old Jan 15, 2011 | 10:30 PM
  #333
2008 W204 Sport
Do you have to completely remove the headlights to install the bulbs or can you get to them by opening the hood and doing it from the engine bay?
Old Jan 15, 2011 | 11:29 PM
  #334
AZN Optics's Avatar
1) both eyebrows
3) bumper lights
Answers to these questions can be found in first post
Search the forum. There's a DIY.
Old Jan 15, 2011 | 11:30 PM
  #335
AZN Optics's Avatar
Originally Posted by C300 EPM
Hi Mike,
Try swapping the left and the right side to see if the issue follows the LED. If so, might be something odd with those and we can deal with warranty. If it stays with the socket, then you might have some wiring issue where voltage is bleeding through even though should be off. Let me know once you test it out.
Old Jan 16, 2011 | 01:05 AM
  #336
2008 W204 Sport
I would like to order all hyper white (what ever color that is) LEDS for:
1)Rear license plate
2)Both head light eyebrows
3)Headlight turn signals
4)Front bumper lights
PM me a quote AZN paypal is rdy! thanks!
Old Jan 16, 2011 | 02:13 AM
  #337
AZN Optics's Avatar
No turn signals are available yet, but looks like you want 4 sets for your plate, brows, and sidemarkers. Prices are as follows:
4 sets of 5000K LEDs will be $65
4 sets of 8000K LEDs will be $70
Unfortunately, Hyper white isn't a actual color range, so you'll need to determine if you want 5000K or 8000K. If you're on factory bi-xenons, those are rated 4300K and my 5000K will be a better match. 5000K is more of a pure white while 8000K is more of a cool/glacier white with a tinge of blue.
Old Jan 16, 2011 | 03:39 AM
  #338
2008 W204 Sport
Thanks for the quick reply, so I will take 4 sets of the 5000k please paypal ready
Old Jan 16, 2011 | 06:54 AM
  #339
2008 W204 Sport
I just sent payment for 4 sets of 5000k LEDs, thanks!
Old Jan 16, 2011 | 09:55 PM
  #340
C300 EPM's Avatar
C300 BLACK Sport
Unhappy
I followed your instruction [Try swapping the left and the right side to see if the issue follows the LED. If so, might be something odd with those and we can deal with warranty. If it stays with the socket, then you might have some wiring issue where voltage is bleeding through even though should be off. Let me know once you test it out.]
The car's wiring is good. it did not leak. The problem is the leds.
i remove the right side and found out that the circuitry of the leds are brownish in color and some melting/shifting of the white square. In curiosity, i remove the left side as to test it out and found that the left side also have the same issue with the right side. so i might as well remove it and take a picture to show you. so 4 leds are damaged.
Attached Thumbnails AZN Optics 5W5 Canbus LEDs-img00199-20110116-1844.jpg   AZN Optics 5W5 Canbus LEDs-img00200-20110116-1845.jpg
Old Jan 17, 2011 | 01:56 AM
  #341
AZN Optics's Avatar
Burn off is normal, but if you have resistors shifting like that, that means the voltage plate touched the first set of resistors and they were plugged in too far. This happens with all open circuitry LED and is the number one install issue. Powered on normally, there's absolutely no way the unit would heat up past the melting point of the solder, but when the unit touches the resistor, all bets are off and the unit super heats. For those with soldering skills, this can actually be fixed by resoldering the resistor back on as none of the components actually burned out.
Even though this is an install issue, I'll warranty these and send you another set. The other side with the burn off is fine, just make sure when you plug it in, to not push it in all the way. As soon as you feel any slight resistance when inserting, pull it out to give you buffer space. Then as you go to plug it back into the socket, grip the LED and socket 50/50 to prevent accidentally jamming the LED back in too far as you ferret out the housing hole.
PM me your info and I'll take care of you.
Old Jan 17, 2011 | 04:13 AM
  #342
2008 W204 Sport
Mike, you got my payment right?
Old Jan 17, 2011 | 04:48 AM
  #343
AESCAR's Avatar
Payment
Payment made + $4 delivery. Please check
Old Jan 17, 2011 | 11:30 AM
  #344
AZN Optics's Avatar
Got em both. Will be shipped out tuesday morning. Today is US Post Office holiday.
Old Jan 17, 2011 | 01:07 PM
  #345
soldier2304's Avatar
C63 AMG(sold), 2009 CL550, 2010 S550 Majestic Black, 2010 ML550, 2006 C230, 2009 Venza
Bump for the best LEDs in the market! Mike when is the turn signal LEDs going to be released? Also anything for the side mirrors so far?
Old Jan 17, 2011 | 01:30 PM
  #346
2008 W204 Sport
Thanks mike! You are the man! And word on some No error turn signal LEDS or do you know where to purchase them?
Old Jan 19, 2011 | 03:15 PM
  #347
BET530's Avatar
2008 C300
my brother-in-law got his headlight and forg hids from HMS, i believe there 6000k, not sure but which color leds would best match the hids?
would like to order eyebrows and license plate light leds, how many sets would i need? Thanks, pm sent
Old Jan 19, 2011 | 04:03 PM
  #348
AZN Optics's Avatar
PM replies.
Old Jan 19, 2011 | 08:36 PM
  #349
johnlk25's Avatar
2016 E400 4Matic
Does the footwell lighting dim like it does with the stock bulbs? I tried Polarg bulbs in the footwells, but to me they did not look any different than the stock bulbs, so I just put the stock bulbs back in. I want something brighter than stock, but no so bright that its intrusive. How much are the footwell lights?
Old Jan 20, 2011 | 11:30 AM
  #350
Badblackfolife's Avatar
BENZ 550
got mine in mail looking good!
