AZN Optics 5W5 Canbus LEDs
Old Mar 1, 2014 | 12:48 AM
  #851
AZN Optics's Avatar
SPONSOR/MBworld Guru
Originally Posted by c350nubie
Oh do you have any recommendation for D1S bulb 8000K? I was looking at some Philips ones but they only get up to 6000K
There are other HID vendors on the forum that you can check with who carry different brands and I'd advocate supporting forum vendors here first. They'll typically take better care of you.
Old Mar 1, 2014 | 05:02 PM
  #852
c350nubie's Avatar
'08 C350 Sport
Thanks Michael! I will take a look around. Trying to stay way from HID kit but I may have to give in this time
Old Mar 5, 2014 | 11:04 PM
  #853
CMC-63's Avatar
C63 P31
Hey AZN,
Which bulb do you recommend for the side markers?
P.S. I do have the Xenon package from merc.
Old Mar 6, 2014 | 12:21 AM
  #854
AZN Optics's Avatar
Originally Posted by CMC-63
Hey AZN,
194 wedge LEDs for your sidemarker. Generally I'd suggest our V4 model, but I do know there's one variant of the clear sidemarkers that are floating around that have a thicker clear lens where the V4 don't fit. If you want to play it safe, you can use our V3 model.
Old Mar 7, 2014 | 01:49 AM
  #855
Steeezy's Avatar
C300 Sports RWD
one of a led light broke inside the LED housing and I guess it fell inside the housing is there a way to remove it? I've seen someone take apart a headlight apart but does the eyebrow come out too? if not I'm not going to bother with taking the head light apart I was able to put a new led inside with no space issues and everything is working fine.. its just the fact i know it roaming around in the eyebrow makes me want it out.
Old Mar 7, 2014 | 01:59 AM
  #856
a1rh3adsz's Avatar
'06 mz3, '12 R6, '09 W204, '02 A4 B6, '14 IS350
samething happen to mine. my led complete fell inside while i was installing it did not want to push it in too tight so it was loose. i end up taking the whole headlight housing unit out. and shack it until it can off out of any socket. for me it fell out the turn signal socket.
Old Mar 7, 2014 | 02:04 AM
  #857
AZN Optics's Avatar
We've had a few issues on some vehicles of the solder weakening on the head from surge events. Our current units have a higher grade solder which should mitigate this somewhat, but we've already got our fully covered gel substrate V4 currently being live tested by some test users and forum mods. We're hoping to release these in a month or so. The high temp gel holds the components in place on surge events till it passes and solder resolidifies. Also reduces ambient heat transfer through encapsulation.
Old Mar 7, 2014 | 02:16 AM
  #858
Steeezy's Avatar
C300 Sports RWD
Wasn't sure if the eyebrow had a drop hole for the for the Bulb to fall into to fall out of another hole in the head light. figured my last resort was to take the headlight out and unseal it to get access to the eyebrow. since you said shaking it helped get the bulb out i'll try that tomorrow.
Old Mar 7, 2014 | 02:18 AM
  #859
Steeezy's Avatar
C300 Sports RWD
These maybe better then the other ones I purchased.
Old Mar 7, 2014 | 11:57 AM
  #860
AZN Optics's Avatar
Those are our old v2 design which the v4 was built off of. You can try our v3 design though. We haven't had any solder issues with that model at all.
Old Mar 27, 2014 | 09:29 AM
  #861
SuitUp's Avatar
2009 C63 AMG
Hello AZN, would you beso kind a list once again all possible light sources that can be replaced withyour LED solution (inside and outside) and with which particular model? I’m still not sure if I got everything and I only want to order once and get it done.
I would actuallysuggest to add that list to your first post, as it will be useful for futurecustomers as well! Thanks!
Old Mar 27, 2014 | 08:36 PM
  #862
AZN Optics's Avatar
Unfortunately the way these forums are set up, I no longer have access to modify and update the first post. If ever anyone has questions, feel free to PM me. I may not seem as active on threads here as I used to be, but I'm constantly lurking and sending PMs whenever I see I can help.
As for your specific vehicle, assuming you don't have lighting package....
Eyebrows: 2 sets of 194 wedge LEDs (V3 or V4)
Sidemarkers: 1 set of 194 wedge LEDs (V3 or V4)
Rear Plates: 1 set of 194 wedge LEDs (V3)
Front Signals: 1 set of 3457 super wedge LEDs
Rear Signals: 1 set of 7507 bayonet LEDs
Rear Reverse: 1 set of 1156 bayonet LEDs
Rear Tail/Brake: 3 sets of 1156 bayonet LEDs
Rear Sidemarkers: 1 set of 194 wedge LEDs (V3 or V4)
Interior Footwell: 1 set of 194 wedge LEDs (V3 or V4)
Interior Front Map Light: 1 set of 194 wedge LEDs (V3)
Interior Vanity Mirror: 1 set of 194 wedge LEDs (V3 or V4)
Interior Front Dome Light: 1 set of 194 wedge LED (V3 or Plasma Panel)
Rear Dome Light: 1 unit 41mm festoon LED
Rear Map Light: 1 set 194 wedge LED (V3)
Interior Trunk: 1 unit 194 wedge LED (V3 or V4)
Interior Glove Box: 1 unit 194 wedge LED (V3 or V4)
Old Apr 1, 2014 | 10:14 AM
  #863
Dazzagt's Avatar
C63 AMG - PP+
Just found this thread, but thanks to Matt I had been given the details of AZN, and after receiving my LED's yesterday, now fully installed.
Cracking service and product and when you get great service you need to let everyone know, so just wanted to post up with a big
Old Apr 1, 2014 | 12:59 PM
  #864
Project C's Avatar
MB C250
I'm looking forward for those Gel V4 version , I had V3 gel been using them for over 18 months with no issue
Old May 4, 2014 | 04:18 PM
  #865
Project C's Avatar
MB C250
Awesome
Arrived today and installed
Break in process...
Nice package from Azn Mike
Old May 4, 2014 | 04:51 PM
  #866
black lavender's Avatar
R8, C63, C300
Got mine a few days ago, already put in Lickity split service
Old May 5, 2014 | 02:10 PM
  #867
bcmakesiteasy's Avatar
2014 C250 Sport
Received the wedge bulbs this past weekend for the parking/city lights. I took out the bulb from the headlight housing, then couldn't figure out how to put the LED's in place of the oem lightbulb. Can anyone help me out?
Old May 5, 2014 | 03:19 PM
  #868
Project C's Avatar
MB C250
remove the OEM bulb then insert back the led, test them before install back to that headlamp
Old May 5, 2014 | 03:26 PM
  #869
2014 C250 Sport
how do I remove the OEM bulb from the socket? Do I just pull on the bulb? I tried pulling on it, but I didnt want to squeeze and pull on the bulb too hard cause i dont want to break it.
Old May 5, 2014 | 03:49 PM
  #870
Project C's Avatar
MB C250
yes just pull them out
use fibre cloth or tissue to remove them or you may prefer thin plastic glove
Old May 6, 2014 | 03:39 AM
  #871
959drew's Avatar
c300
Can you put LED bulbs to replace the fog lights?
Old May 6, 2014 | 03:44 AM
  #872
AZN Optics's Avatar
We do have some new plasma LED H7 bulbs coming in our next shipment in a couple weeks which we're excited about. Will need external canbus harness though.
Old May 6, 2014 | 04:07 AM
  #873
959drew's Avatar
c300
Cool, will you have the harness as well or can you recommend one? How much will the bulbs cost?
Old May 6, 2014 | 12:23 PM
  #874
AZN Optics's Avatar
We'll have pricing after we get our hands on first batch to run through tests and confirm they meet our expectations before we allow into our lineup.
Old May 6, 2014 | 02:01 PM
  #875
c350nubie's Avatar
'08 C350 Sport
Do you have the plasma LED H11 bulbs? Mine is corner illuminating fogs so I think its H11
