Polisher for W204?
Old Jul 17, 2010 | 09:24 PM
wanchu83's Avatar
C300 Sport LOADED
Polisher for W204?
Ok, since you guys talked about waxing and polishing, I decided to go ahead and bought some products. I have purchased Poorboy's diamonds and wolfgang sealant 3.0
Now.
I am planning to purchase porter cable 7242xp for the better polishing.
What else do I have to buy to apply the polisher and sealant?
for instant, what pad...etc
Ican't wait for the porter cable so I am going to apply it with hand first.
Then, when it comes with all the right tool, I will wash car with car detergent and little bit of dishwash detergent and redo the whole thing with porter cable. Any other advice?
Thank you all~
p.s: my car is artic white.
Old Jul 17, 2010 | 09:36 PM
Arcoril's Avatar
991 C2S, AP2 S2000, E400 Coupe
Personally, I remove light swirls with Menzerna PO106FA on a black pad. This is a very fine polish that's specially designed to work with our ceramic clearcoat. If you've got heavier swirls, you may need to step it up to Menzerna PO85RD with a white or orange pad. This is a heavier polish that's also designed for ceramic clearcoats. The general rule of thumb is to start with the least aggressive compound and then move to a heavier one if the lighter one doesn't give you the correction you want. Also make sure to clay your car before starting any polishing job.
Old Jul 17, 2010 | 10:04 PM
wanchu83's Avatar
C300 Sport LOADED
I am planning on getting this kit
http://www.autogeek.net/porter-cable-flat-pad-kit.html
which 5pad ofmy choice shouldbe?(they are also throwing in 2 red soft wax pad)
Old Jul 18, 2010 | 03:31 AM
AZN Optics's Avatar
SPONSOR/MBworld Guru
poorboys white diamond is a glaze, so you're not doing any paint correction. If you're applying glaze and sealant with a polisher, stick with jeweling pads like Lake Country blue or black pads. If you plan on doing any form of paint correction, can't go wrong with the Menzerna trio (SIP, PF, 85RD).
Old Jul 18, 2010 | 01:37 PM
wanchu83's Avatar
C300 Sport LOADED
ok what about if I use menzera for paint correction, which color pad should i need?
Old Jul 19, 2010 | 01:26 AM
AZN Optics's Avatar
Have to see condition of your paint, but you always want to start with less aggressive then move up if needed. Try Power Finish with a white or maybe even yellow LC pad...if that doesn't work, you can move up to SIP with a yellow or orange if really needed. Finish off with 85RD with a white or black pad.
Old Jul 19, 2010 | 11:28 AM
Peabody's Avatar
Michael, I have a few spots where the body shop sprayed over a slight piece of dust or something and ended up with a pimple in my finish. How do you correct that? Do I need to wet sand it and then polish it? Should I just take it to a body shop that can fix it?
Old Jul 19, 2010 | 01:40 PM
Azn_C300's Avatar
Mercedes C300 Sport, BMW 745Li, VW Mk6 Golf TDI
If they sprayed over the spec, then wet sanding will probably have to be done. Polishing isn't going to do jack cause it's under the paint.
Old Jul 19, 2010 | 02:13 PM
wanchu83's Avatar
C300 Sport LOADED
I ended up getting the hand polisher kit.(budget issue) I don't have much swirl marks anywhere other than trunk. Some reason there are lots of dirt get on back of the car specially the trunk. I need to clay bar out the debris and dust.
I got polishing pal kit, http://www.detailedimage.com/DI-Pack...ffing-Kit-P454, and the Menzerna PO106FA
I hope I get some good result from all this. I will do Wash, Clay bar, Menzerna PO106FA, Poorboy's diamond glaze, and top it off with wolfgang 3.0 sealant.
It will be long day by doing it with hand, but I will enjoy it. I will post some pictures soon as I get it done. I am waiting for the those items to arrive at my door.
Old Jul 19, 2010 | 04:01 PM
Azn_C300's Avatar
FYI, 10% off and free shipping off DI on orders over $50 so if you didn't take advantage of that, might be worth contacting Todd at DI and seeing if he can apply it.
Old Jul 22, 2010 | 10:11 PM
wanchu83's Avatar
C300 Sport LOADED
The stuff comes and I decided to give it a try.
So, I washed car(my wax are all gone, I haven't waxed in 4month). I clay bar the car, and Hand polished with Menzerna PO106FA(Green pad used), Poorboy's white diamond(black pad used), and Wolfgang 3.0 sealant(blue pad used). It was done by hand and it was hard(my arms killing me). I didn't have swirl makrs or any paint to correct, so it wasn't hard. The car looks very clean and shiny white. The car shows little more bright white but maybe it's just me. The car looks great. I like it alot. I just need the rain to test the sealant but I don't want the rain(luckly cali weather is hot so far this summer and no rain)
Maybe in couple of days, I will put another layer of sealant.
Old Jul 22, 2010 | 10:13 PM
wanchu83's Avatar
C300 Sport LOADED
hmm my nexus one's camera failed to capture the shine.. it loos blurr.. trust me the car looks much better than the pic. I will post another one after applying one more layer(using proper camera)
Old Jul 22, 2010 | 10:26 PM
BlackjackM's Avatar
2018 E300 Lux, 2006 Corvette Z51, 2015 Mercedes ML350 (wife's)
SIP on green is my go-to combo......hasn't let me down yet! If I'm polishing black or some other dark color, I will jewel with 85rd on blue or white. But SIP finishes down nicely with the Flex and some finessing
Nice job.......you must be sore doing it all by hand- I know I couldn't.
