Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Specifications and General Maintenance
- Mercedes-Benz C-Class: How to Jack up Your Car
Step by step instructions for do-it-yourself repairs
how to jack up car?
C300
how to jack up car?
how do you guys jack up your cars? are there any special spots to put the jack? i want to take my tires off, and i just see a ton of plastic covers under there.. i dont really want to jack it up not knowing whats under the plastic.
any pics or strong spots woudl be appreciated.
2008 C300 Sport, RWD, US
I was looking at jacks yesterday and noticed that some are designed to go under cars that are low to the ground.
If you haven't bought your jack yet, you might want to go measure the clearance first.
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
how do you guys jack up your cars? are there any special spots to put the jack? i want to take my tires off, and i just see a ton of plastic covers under there.. i don't really want to jack it up not knowing whats under the plastic.
any pics or strong spots would be appreciated.
Looking under the rocker panels, you will see a pad behind the front wheels and another forward of the rear wheel. You may also lift the rear by jacking under the differential.
Also, you can buy a metal device that fits a hydraulic jack pad and the body jack pad location precisely. About 35 bucks or so. See them at
www.reverselogic.us
Also, when reinstalling your wheels, you must use a torque wrench for the final tightening of the lug bolts. Further, it's a good idea to keep impact wrenches several hundred feet from the car.
I am surprised no one ever answered this question. I can think of a few good reasons to use a torque wrench.
1) Without the torque wrench the lug bolts may not be secured adequately. At the track inspection for one of the MBCA National Events, I remember checking the lug bolts on an R129 and they were torqued to about 60 pounds, well under the recommended torque.
2) Using a torque wrench ensures that all five bolts are torqued evenly so that the rotor is not warped.
3) A torque wrench prevents overtightening the bolts which could damage the bolts or the hubs.
This is done on all cars with alloy wheels although I suppose the average Hertz rental's wheels have never been torqued on properly.
I have asked this before without success but maybe someone can help me out this time around. I want to put the car up on four jack stands for a day or two but can't find good placement points for my jack stands. Of course I can't use the jack pad points as the jack is using that area to get the car up.
Is there a designated point somewhere or should I just look for the "hardest" point I can find and hope for the best?
I bought a couple of trolley jacks & welded blocks of steel on to their cups to fit the MB jacking points. These jacks only cost about $35.
2008 C300 6speed, 2015 GLK 250 2017 E400 wagon
I noticed if you jack the front or rear the car raises pretty evenly. So i put a jack stand on the opposite front/back same side. Than lower Jack. Car should stay even. After, i replace the same corner where i removed the jack with a jack stand. Same thing for the other side. But i leave the jack itself on one corner. and put a jack stand somewhere else. to support the jack. Hope it helped. Always use the blocks to lift car. never from the body.
