LEDs installed in Interior and trunk
However, after installing them in the Benz, it seems they are not drawing enough power (since LEDs use less I think) and they will come ON bright for a couple of seconds and then go DIM for another 3 seconds........then BRIGHT for 3 seconds...etc.
I'm new here and remember reading something about certain lights that are replaced causing computer error codes or something like that (for the headlamp).
Any idea if I can plug in an LED? I doubt they are defective because the one I plugged into the trunk worked great!
The lights are: White 5050 6LED 1.2W 12V Inverted LED Light Wedge Bulb
here's a pic of the light I am talking about:
Alex T.
Here's what I did:
https://mbworld.org/forums/c-class-w...installed.html
For the front dome, use the led bulb, they are fine.
When I foot rear led dome(festoon) they started to blink like you said. So I have purchased polarg for the rear dome. I still used same led for the reading light in rear.
for the foot light, I try to use led, but they started to blink, so put the polarg instead.
Here are the lights I used.
http://www.superbrightleds.com/cgi-b...%2FWLED-x5.htm
I used WLED x5
Then, for the trunk I have used.
http://www.superbrightleds.com/cgi-b...iversalPCB.htm
This is what everyone should use for our trunk light. They fit perfectly, without any adhesive. Only thing is they need resistor. They sell plug in resistor for 194 wedge bulbs online. I purchased them long ago, and they looks like this .
http://www.phoenixautobulbs.co.uk/pr...-resistor-kit/
I will post some pictures tonight with my interior lights and trunk lights.
enjoy.
pardon the mess in trunk
