hub diameter?
Old Dec 11, 2010 | 11:51 AM
BET530's Avatar
2008 C300
hub diameter?
Hello Members, I did the search and i wanted to confirm, is the center hub diameter on our vehicles 66.5mm?
there is a set of after market wheels im interested in but the hub diameter is 66.1mm.
Old Dec 11, 2010 | 05:36 PM
Derspeed's Avatar
X3 and 2012 C coming soon
Center bore 66.5
Bolt pattern 5/112
Lug bolt size 14x1.5
Old Dec 11, 2010 | 06:13 PM
BoostedThrills's Avatar
C300 Sport/G35S
A good machine shop should be able to hone out those hub bores to fit your C300.
Old Dec 11, 2010 | 06:46 PM
BET530's Avatar
2008 C300
THANKS guys
Old Dec 12, 2010 | 11:14 AM
mr inkredibul's Avatar
'17 GTR, '17 GLC43, '14 Panigale 899, '20 V4
Make sure the center caps fit. Our hubs also stick out a lot.
Old Dec 13, 2010 | 02:02 AM
Mtl20v's Avatar
2013 E350 4M, 997 Turbo, MK3 GTI
They are actually 66.4mm. Measured with a faro gauge on 2 w204 and 2 glks.
Old Dec 13, 2010 | 07:44 AM
You still need to drill to 66.5 or the wheel won't slide on the hub. If the wheel and hub are the exact same bore, the wheel is not going to slide on. Sounds funny but you can put two circles of the same into another. One has to be a little bigger.
Old Dec 13, 2010 | 12:51 PM
C300 Sport/G35S
^This.
Old Jan 7, 2011 | 02:41 AM
andy_c63's Avatar
2009 C63 AMG
So is it 66.4? 66.6 (66.56) hub centric rings feel loose, 66.1 (66.06) won't fit and there is no size available in between...
Old Dec 20, 2011 | 05:05 PM
RicheeThree's Avatar
Vehicle
___
Old Dec 20, 2011 | 06:19 PM
andy_c63's Avatar
2009 C63 AMG
I ended up getting a set of 66.1 (66.06) and working on them with a sand paper until they fit.
If the ones you have fit snug, what's the problem?
Old Dec 20, 2011 | 06:35 PM
Vehicle
___
Old Dec 20, 2011 | 06:52 PM
andy_c63's Avatar
2009 C63 AMG
Are those plastic?
Try these http://www.ebay.com/itm/230477064802
If they feel loose, do what I did, get these http://www.ebay.com/itm/230477089714 and work on them with a sand paper...
DiscounTire have the same rings for $15 with free shipping, but you have to call to order
http://www.discounttiredirect.com/di...riesWheels.jsp
Old Dec 20, 2011 | 07:44 PM
Vehicle
___
