headlight bulb replacement - which H7 to use?
Old Dec 13, 2010 | 07:43 PM
nyca's Avatar
Within a weeks time, each of my original H7 low beam headlight bulbs failed. I replaced them with the standard Sylvania H7 bulb from an auto parts store. The lighting from the car is terrible now - no distance, too much side illumination. The stock bulb was a GE H7A, but of course the auto parts store didn't have that one.
Which bulb should I be using? Sylvania makes 4 different levels of H7 bulbs, should I try one of the "higher" level ones? Or is there something about the OEM H7 (H7A as marked) bulb that is different, should I buy new bulbs at the dealer?
Old Dec 13, 2010 | 08:28 PM
GateKeeper's Avatar
GLA45 AMG, GLC43 AMG
Different bulbs could give you different patterns and light output, perhaps you could try to get the bulbs from the dealership ?
Also check they are in properly, correct orientation, and seated in the socket correctly.
Old Dec 13, 2010 | 08:38 PM
Sportstick's Avatar
Another round of ICE
I've been very satisfied with Phillips X-treme H7. I got them here:
http://www.powerbulbs.com/product_de...FYa7Kgod9xabng
Old Dec 13, 2010 | 08:41 PM
nyca's Avatar
They bulb doesn't seem to "twist lock" in place, just sits flush againt the mount and then held in with the clip. I will check again, but I don't think they are installed incorrectly.
Old Dec 13, 2010 | 09:48 PM
justthinking's Avatar
2008 C300 Sport, 2010 RX350 AWD
http://www.bulbs.com/results.aspx?Ntt=h7
I use Philips Vision Plus, brighter than stock or regular H7 bulb..
X-Treme power would be brighter, but I am worried about the longevity of them
Old Dec 13, 2010 | 10:53 PM
ZeroSeVen's Avatar
Mercedes Benz C300 Sport
I have Philips Diamond Vision 5000K for both my low beams and fog lamps. I have been using this for several months with no problem. It also matches AZN's LEDs perfectly
Got it from here: http://www.ipmart.com/main/browse/Ca...6.php?cat=5356
Old Dec 13, 2010 | 11:03 PM
nyca's Avatar
The Sylvania "bright" bulbs seem to get very poor reviews for longevity, but that's the only brand the local auto parts stores seem to sell. Can't get the Philips or the GE Nighthawks locally, I have to call the dealer and see what make the bulb sold there is.
Old Dec 13, 2010 | 11:15 PM
if you are in the states...order from bulbs.com or amazon...
I had a pair of the GE Nighthawks from amazon and they are pretty good..on par w/ Philips Vision Plus..
