W204's and offsets of wheels
Stock 18" AMG wheels are
F: 18x8 +50 225/40/18
R: 18x8.5 +54 255/35/18
Remember though, Hankook tends to run a bigger size than most tires.
225/40 will almost run the same as 235/40
255/35 same as 265/35
Okay, Loonie,
The rims are choozen from the website of mandruswheels, so the should fit.....As you know ( i think) those wheels escpecially made for mercedes, working well with the offset....
So you think that at the front 18x8,5 ET 43 fits better by 225/40.
235/40 i might have problems?, when i choos for 225/40there wil be no problem with 8,5 in he font?
As i said before:
Front: 7,5X17 ET 47
Rear: 8,5X17 ET 58
Offset of the new rims are 5mm less, Front 43 Rear 53.
What do you mean by "...Hankook tends to run a bigger size than most tires....."?
Another brand of tire?...recommend.....
Thank you , i'm till looking for information , here is a lot of information in this forum..
Aproxx in 4/5 days the rims will be delivered....
Marc,
Posted from Mbworld.org App for Android
235/35ZR19 Y 19x8.5 front
275/30ZR19 Y 19x9.5 rear
won't the 275's in the rear be to much ... and if so why did such a reparable site give me as the only option for running 19's?
need a bit of help!!!
I just got my new rims and tires put on yesterday on a 2012 C300 4matic. i did a lot of study regarding the proper offsets and sizes. Finally came to a conclusion:
19 x 8.5 and 19 x 9.5 ET45
235/35 and 265/30
Even went for the 'skinny' brand of tires. Falkens 453
Everyone i talked to told me 45 would be fine with stock suspension. But still there is a bit of a rub on the rear passenger side. ANY SUGGESTIONS ON HOW TO FIX THE PROBLEM?
235/35 and 265/30
235/35 and 265/30
I did notice that the rear passenger tire sticks out a little more compared to the drivers side. Will keep you guys posted on the result. Dont understand why w204 has such a high offset!!!
If you are just going to try Michelins or Yoko s drives that's cool too. Hopefully you find a combo that works!
I have heard some bad reviews on Yoko's tread wear specially with German sport sedans but i am willing to take a risk. Will be posting some close up shot very soon. Thanks for all the help guys!
im running megan coilovers with ssr ms3 wheels
still need an alignment and need to pull my rear fenders out more
