W204's and offsets of wheels
#1201
Probably go ET42 in the rear and it should fit a 265/30 without rubbing. At least it was what I was told. That's with Hankook tires, not sure about the walls on other brands
#1202
1986 560SL
problem is I cant't. He said they could only go as hi as 40. Am I SOL?
#1203
That's weird. I am waiting for a set of the GF9 in 19x8.5" ET40 & 19x9.5" ET42. Sounds odd if they can't make the GF7 in ET42 if they can with the GF9. Try and talk to Tiko or have Alex talk to Tiko as MRR confirmed those numbers.
#1204
I'm no expert, but I think you need to be somewhere in the ET50s on 10" wide in the back. I'm sure other people got experience with it?
#1205
I have an 012 Sport and I bought a set of Ground Force GF07's from Need For Speed.
19 X 8.5 and 19 X 9.5. The ad was marked ET45's F&B.
Alex from Need 4 Speed claimed it was "mislabeled" and said it had to be ET40 F&B according to the wheel manufacturer to fit a W204.
I told him he was nuts and that I wanted 45 and 50 and he said I was wrong and not happening. I even referenced this thread as those specs are all over it and he's a sponsor.
He maintains "I'm wrong bro"...
Seems ET40 will be fine up front but ET40 in the back is too aggressive right? I want flush back there, no poke and no rub with 2 adults in the back seat. Will ET40 work back there with a 265 or 255?
Thoughts? Help!!!
Thoughts? Help!!!
I hope someone answers this because I am looking into similar wheel and tire specs and can't seem to get a solid answer either!
#1206
Yea lower the offset the more it stick out. I'd say low 40's front and mid 40's rear if u want it to be flush with the fender
#1207
Thoughts? Help!!!
Thoughts? Help!!!
#1208
Hey guys new here. Had a quick question. I just got some 19x8.5 et42 fronts and some 19x9.5 et50 rears. What would be a good tire setup for stock suspension with these specs. Also what would be the specs if I were to get some h&r ss?
Thanks in advance
Thanks in advance
#1209
I'm waiting for my set of 19x8.5" ET40 & 19x9.5" ET42 wrapped in 235/35 & 265/30. Should be flush without rubbing and I'm on H&R Super Sports. Should be here during next week and will be on by next Saturday.
Hope that helps!
Hope that helps!
#1210
1 Post
2013 C250 Sport
First I want to say nice work to everyone that has posted, lots of nice setups in here..
Now I just picked up a 2013 C250 and I'm looking to get some rims. I would like them it be a nice stance staggered but not sticking way out. I will be getting my super sports or coilovers first. Most likely coilovers since I had super sports on my 2008. I think 18's or 19's since the 20's were to big on my 2008 and the rears were 20x10 so I had to roll the rear fenders a little when I put the super sports on and it would still rub on bumps.
What are some good sites and or brands to look at. Also trying to decide if I want deep lips or go with a concave setup this time. So when looking at 18x8.5 F 18x9.5 R, and 19x8.5 F 19x9.5 R what would be the ideal offsets? Lower 40's for the front and high 40's in the rear? Thanks a lot I just don't want to buy rims then not be happy and end up buying new ones again down the road.
#1211
Just got mine today, I'll mount them once I get home from work. I can throw up a pic or 2 if I can find decent light somewhere close by. Mine are 19x 8.5" ET40 front and 19x9.5" ET42 rear
#1213
1 Post
2013 C250 Sport
Concept One RS-8 rims
5x112
HUB 66.5
Front: 20x8.5 et 38 (2in. lip)
Rear: 20x10 et 43 (3 in. lip)
Would these fit? What size tires would I need? Want to drop it also coilovers or super sports.
5x112
HUB 66.5
#1214
1 Post
2013 C250 Sport
Think I'm going to go with Niche Essen rims. Specs below will these work and I will also be getting H&R coilovers.
19x8.5 ET 42
19x10 ET 55
Will this be a nice aggressive staggers stance? Thanks.
19x8.5 ET 42
19x10 ET 55
#1216
lm
I am about to get some summer rims and want opinions on this setup.
-Bbs lm reps 8,5/18" ET 45 front and 9,5/18" ET 43 rear.
I got already some tires, 225/40r18 front and 255/35r18 rear. What do you guys think, does tires fit well and a good set for getting it low with coilovers?
#1219
Hehe, they are flush, but yeah on the picture it looks like a poke. You should be safe with your setup, you probably want at least ET45 in the back to be 100% safe. I have scraped once during a sharp turn, so I'll probably roll the fenders to avoid issues with it loaded.
Def don't run more than a 265/30/19 in the back as you'll be rubbing.
#1220
2010 Mars Red C300 Sport
Looks great btw.
#1221
1 Post
2013 C250 Sport
Sweet! Im on stock ride height right now. H&R coils will be on order soon. And I should be find on lowering since im a ET47 rear and you are ET42 rear with minor rubbing.
#1222
@McLovinggood - Thanks! - I have only rubbed once on this set up and I was going into a corner with a decent speed, so it doesn't rub with regular driving.
@dudeitsmattx - Yeah, you should be good, but you also have the freedom with coils to adjust
#1223
@becksan Went ahead and ordered the same tire size you recommended after doing a lil more research and seeing a few others running the same sizes. Thanks for all the help man. Really appreciate it!
Car looks 👍👍👍👍👍👍👍👍👍
Car looks 👍👍👍👍👍👍👍👍👍
#1224
Anytime! Happy to help!! Thanks 😁. Happy new year!
#1225
Do rub? I'm running 3sdm 0.01 19x8.5 et 40 225/35/19 and 19x9.5 et42 245/35/19 and I rub when I 2 person in the back seat and I'm not even lowered yet.
