W204's and offsets of wheels
I've been reading through this thread and noticed different setups for the W204.
I installed a set with the following specs for a 2013 C250 Sport:
19x8.0 ET45 235/35/19
19x9.0 ET45 265/30/19
The problem is that the tire rubs with the fender when entering driveways or some dips in the highway (only one in the car). I've seen 275 rear tires with no problem.
Any suggestions? Thanks
Front: 18x8.5 +34.5 225/40ZR18 BFG
Rear: 18x9.5 +48 255/35ZR18 BFG
Fitment is spot on IMO. Lots of posts about the 8.5+34.5 FRONT being too aggressive and rubbing, but with these tire sizes and stock ride height, it drives fine and no rubbing even under full load. It would look a bit better lower, but it is the old man's DD so I want to keep stock drivability.
Rear fitment.
Front fitment.
Front fitment. TOP of FENDER VIEW.
I need some help!
im currently running 245/30/20 with 8,5 all around. ET 45 infront and 38 in the back. Ive lowered my car 25-30mm with h&r springs, now my car is rubbing. Ive fixed the rubbing issue by rollig the fender (i know not the best idea but i love my rims) but my car still rubs in the wheel arch linnear in the wheel housing. So sadly i need to get down in size, going with 8,5x19 ET 42 all around, do you think this would fix my rubbing issue, considering the ET infront is a bit lower than before? Im gonna run with a bit of tire stretch.
I just got a c300 2012 came with 20" on wheels with 225/30/20 on 4 of em.
Now i have one tire need to replace . So im thinking to get the right size on widht for the front n the rear ones . So can u guys tell me ur idea whats the good spec or offset ,
N how i can tell the specs on the wheels ryt now?
Rear
Front
I just got 2012 c300 n comes with 20 " on the wheels which is looks good but all the tires has same spec n width which is 225/35/20 .
N the fronts one has rubbing n i dont know becouse the fender or something else. Im thinking to get a new tires but i dont know what the spec or width is fit for my wheels ryt now .
Rear
Front
Tires, you'd wanna go super low profile with 20's.
I looked into it, but couldn't because of 4Matic
.But yeah, you have to seriously consider the tires you put on, you don't have much room in there atm.
I have been reading through this entire thread and am unsure what wheel offset I can safely use. No lowering ect will be all stock.
It has 17" staggered on there right now, which have some scuffs ect so I want to use them for winter wheels and buy 18" AMG wheels for summer use.
Any help would be much appreciated.
OEM Merecedes rims off a new E550. wrapped in Yokohama YK58 near-new rubber.235/40R18 fronts and rears 255/35R18 with offsets ET45 and ET48.
Any help would be very much appreciated as I need to act fast on the wheels.
I don't want to deal with poke or stretch or any of that nonsense.
car is stock, no drop and will stay that way. I just want 18" staggered wheels to replace the 17" on there.
Just looking for your thoughts/suggestions on 3 piece Weds Wheels that I just picked up online.
Front - 18x8 +43
Rear - 18x9 + 38
Will this work? And what tires would be recommended.
I am not lowered at the moment. Possibly in the future with H&R.
These offsets seem so high when compared to my past show car. I had a 350z that was running 19x12 rear wheels with +0.
Front - 18x8 +43
Rear - 18x9 + 38
Hope this helps.
Hope this helps.
I was hoping to avoid stretching but based on some of the examples I have seen, I feel the rears might have to be.
What style 19's are you going to get?
I'm looking to run Work CR Kai Ultimate Kiwami's or Work VS-KF I think. I'm still debating. I miss my CR Kai's from my old RSX.
Here's my past project.
And to get back on topic, these are the wheels I picked up for the W204.
I got a C350 coupe 2013. I was looking to buy some new wheels (I have the 18" staggered AMG option now). I found some that I really like, the speces for them are 18x8.5 ET45 for the front and 18x9.5 ET 45 for the rear.
I will run OEM Tires (staggered obvsly) as I just bought the car and they are brand new.
From what I read here, maybe it will rub or maybe not right? I don't want any rub in any situation, bumps or 4 people in the car. Are these wheels specs too tight?
Thanks all!
