W204's and offsets of wheels
Rating: Thread Rating: 14 votes, 4.64 average.
Old Feb 2, 2012 | 03:46 PM
  #376
mlandingin177's Avatar
W204
Originally Posted by itsLoonie
If any of you remember, I was redoing my LMs reverse mounted (wheel face mounted through the back) Reverse mounting also changes the offset by 15mm. Found a lot of corrosion behind where the face was sitting on so I had the lips redone as well as weld one of them which had a small hole like crater. Just picked them up today and installed gold bolts plus red bbs caps. Sending the fronts back tomorrow to shave off 3mm off the hub.
Here's the wheels before:
FRONT: 18x9 +42
REAR: 18x10 +50
FRONT BEFORE
FRONT AFTER
REAR BEFORE
REAR AFTER
FINAL PRODUCT
FRONT: 18x9 +27 (going to shave 3mm off hub to make it +30)
REAR: 18x10 +35 (might be able to fit 3-5mm spacers to make it +30mm-32mm)
Hey Loon, may I ask what shop your using to shave the hub? Thanks
Old Feb 2, 2012 | 03:55 PM
  #377
Matt_Eurojerks's Avatar
w204 C300
if you could see what I am doing under the table right now...
I need to see 200+ pics of many angles of these wheels on the car!!!
Old Feb 2, 2012 | 04:12 PM
  #378
itsLoonie's Avatar
2012 E350 RWD
Same place I got my wheel lips redone. Shop is wheel techniques in San Jose. If you're in the north bay. Memoryfab in Fremont does wheels too. Might charge more though since they do a lot of aftermarket wheels.
At least a teaser pic?
Old Feb 2, 2012 | 04:45 PM
  #379
jimmythegreek's Avatar
'11 C350 '13 F150 lariat
loonie wheels is looking good. What i wanna know is what tires are u gonna run on those wheels? I could barely clear on my old 2008C350 w 18x9.5 +35mm running falken 452s at 245/35/18 out back, on supersports. Ur going w 18x10 which is like 4mm wider on BOTH sides of wheel and your slammed out I remember? I guess ur gonna try a 225 or 235 w crazy stretch? ur F-in sick bro, hope it works for you, I love it man. Props for doing your thing man
I just re-read your fronts and your at 9" w a +27 trying to do +30? I dont see how u will clear front or back, but hell it may work. People told me in 2008 I was crazy runnin +35mm staggered on a W204 and I did it and I cleared w a creditcard space, and dropped it and cleared too, so go for it man!
Old Feb 3, 2012 | 11:31 PM
  #380
eliteskill's Avatar
W204 09' C350
^ I love to hear this. You and loonie have helped me with finding real "flush" offsets. The forums scared me when I kept reading +45 +55 offsets. Im sure my setup will work =D I cant wait til my rims are on.
Old Feb 6, 2012 | 11:31 AM
  #381
nkc's Avatar
nkc
2012 C63 Coupe P31 CF Trim - Eurocharged V7, 2012 RangeRover Autobiography, 2017 GLS 63 Amg
goodday, please can i run 235 x 35 x 19 (8.5) front and 265 x 30 x 19 (9.5) rear with HR coilovers.
ET for both tires is 50?
Old Feb 6, 2012 | 04:21 PM
  #382
nkc's Avatar
nkc
19" Brabus Monoblock F Titanium
Old Feb 6, 2012 | 04:55 PM
  #383
eliteskill's Avatar
W204 09' C350
Yes you can run fine with that whole setup, however your front 2 rims will be a little bit sunk. The correct offset you need is around 45~. You can get a 5mm spacer if you want fix that.
Old Feb 6, 2012 | 05:36 PM
  #384
nkc's Avatar
nkc
thank you very much
Old Feb 6, 2012 | 05:39 PM
  #385
nkc's Avatar
nkc
so 45 and 50 will make it look flush?
Old Feb 6, 2012 | 05:45 PM
  #386
Frnakito71's Avatar
C300, 93tt RX7, 88RX7 Vet, 83RX7
[QUOTE=nkc;5040384]so 45 and 50 will make it look flush?[/QUOTE
That will be perfect
Old Feb 6, 2012 | 05:47 PM
  #387
nkc's Avatar
nkc
thanks so very much, trying to rep the car here in nigeria, when am done installing the hr coilovers and rims will post pix, thanks so much
Old Feb 6, 2012 | 06:09 PM
  #388
nkc's Avatar
nkc
what would be the best height for the front and rear on hr coilovers to be low as possible without any issues?
Old Feb 6, 2012 | 06:17 PM
  #389
If you have HR coilovers just slam it all the way down
Old Feb 6, 2012 | 06:27 PM
  #390
Frnakito71's Avatar
I’m ¼” from the lowest setting you can go and is fine now but I tried it at the lowest and it rub in all corners. Let me go into detail. I’m running 20’s and in the rear I got camber arms and now the camber is set at factory setting so the 275/25 rubs a bit and in the front it only rub taking turns.
Look the picture below that was at the lowest
Old Feb 6, 2012 | 06:50 PM
  #391
nkc's Avatar
nkc
woow, thats dead low.... i guess since mine is 19, it may not rub at the lowest setting, as jimmy said
will sure try and see
Old Feb 7, 2012 | 01:20 AM
  #392
nkc's Avatar
nkc
must i do an alignment after coilover installation?
Old Feb 7, 2012 | 05:14 AM
  #393
Frnakito71's Avatar
Yes you do.
Old Feb 7, 2012 | 11:12 AM
  #394
nkc's Avatar
nkc
ok, thank you
Old Feb 7, 2012 | 02:11 PM
  #395
eliteskill's Avatar
W204 09' C350
The 18s I bought I got ripped off, one had a crack that was covered with tons of break dust and I didnt catch it =(
Looking at these now.. I ran into a set of 5x114.3 19" Volk TE37s i might wanna run with wobble bolts.
19x8.5 +43 235/35/19
19x9.5 +43 265/30/19
lowering on H&R sports springs. advice?
Old Feb 7, 2012 | 02:25 PM
  #396
itsLoonie's Avatar
2012 E350 RWD
Sad to hear elite. As for the wheels, if you are just on sports and not super sports then you should be able to clear with no rubbing in the back since they don't give you a big significant drop. If it were to to rub but I don't think it will then going with 255 should clear. I think you are good with those tire sizes though. TE37? I say doooo eeeet
Old Feb 7, 2012 | 02:45 PM
  #397
eliteskill's Avatar
W204 09' C350
^ yeah.. Its my fault for not inspecting the wheels better.
Only thing about the TE37 is the concaveness on the 8.5 is nothing at all. 9.5 a little bit =(. I really wanted my BBS to work tho. The TE37 design might not look right on a W204 (might not flow with the car). Ill ponder on it while photoshopping. I have to get them redrilled or use wobble bolts as well.
Old Feb 7, 2012 | 03:00 PM
  #398
itsLoonie's Avatar
2012 E350 RWD
5x114.3? I say save your money and just use wobble bolts. It'll be easier to resell with them being 5x114.3 since most cars runs on these PCD.
Old Feb 7, 2012 | 04:54 PM
  #399
w204 C300
Make sure the center bore is 66.6!!
Old Feb 7, 2012 | 05:16 PM
  #400
eliteskill's Avatar
W204 09' C350
Im checkign them out tonight! I will remember =D
You have already rated this thread Rating: Thread Rating: 14 votes, 4.64 average.
