c300 aux
Old 02-26-2011, 09:16 PM
Anh1's Avatar
2015 Mase Ghibli SQ4. 2013 Range Rover Supercharged
thanks. I was sober, but still tho. now im just trying to get a lawyer. gonna b worse for me cuz im not US citizen, holding F1 (full time student) visa.
Old 02-26-2011, 10:53 PM
kev647's Avatar
C300 4-Matic
Ah, sorry dude. Well, in my short time on this, I would recommend getting the best legal representative your money can buy. Good lawyers, though expensive, may save you money in the long run.
Best of luck man.
Old 02-26-2011, 11:55 PM
Anh1's Avatar
thanks so much man. I wll try to do as you say
Old 02-28-2011, 06:25 PM
kev647's Avatar
C300 4-Matic
Hey all,
I know this isn't the exact topic for the thread, but I did want to mention I did finally get my Ground Loop Isolator and it works amazing!!!! I don't know what that little dumb thing does and why Mercedes doesn't include it between the aux cord and where that travels internally to the sound system/amp in the car, this little thing works wonders. So, anyone considering charging their device and listening to through aux should def get this.
Old 08-21-2011, 10:58 PM
dasinner's Avatar
c300
hi
i cant control ipod via main deck i have to change song via ipod ... any suggestion thanks ...
Old 08-22-2011, 09:04 AM
Acapulco Bill's Avatar
2010 C300 Sport
@dasinner: What do you have - UMI, UMI plus, Ipod Integration Kit? In any case, disconnect the iPod and do a hard reset holding down the center button and Menu for a few seconds. Then plug the iPod back in, see of this helps.
Old 08-22-2011, 10:15 PM
  #32
dasinner's Avatar
c300
center button means the *** says ON ?!?!? and menu where can i find that :S sorry i am lost thanks ...
note: i have regular stock audio 20 ...
Old 07-09-2012, 10:32 AM
  #33
JerseyC350's Avatar
2009 C350
Originally Posted by SuPERSaK
First make sure you on CD and then use your knob and pull/push the knob down and then left. Then press the knob down and you should see the option for AUX
Thanks. Found the hidden 3.5mm behind the glove box but the couldn't find Aux. This worked!
Old 07-09-2012, 11:53 AM
  #34
dasinner's Avatar
c300
plugg your iphone(etc) into 3.5mm jack then press CD on the dash and then use knob push the down on the left side then press the knob u will see option of of them is aux. use knob to go down and then pushdown the knob it will select aux
Old 07-09-2012, 10:59 PM
  #35
JerseyC350's Avatar
2009 C350
Sorry, should've been clearer. I did figure it out thanks to your post. Prior to that, I was doubting my radio had Aux ability at all. Thank you!
Old 09-13-2013, 11:37 AM
  #36
svongsavanh's Avatar
2010 c300
Hey guys i have a 2010 c300 but theres no aux in the glove box its an empty hole, I have been searching the forums and different sites but no luck :[
Old 09-14-2013, 06:37 PM
  #37
2010 C300 Sport
Could be the previous owner had an iPod Integration kit, removed it, and didnt replace the original Aux cable. Did you check by pulling out the glove box liner and making sure it isnt behind the radio headunit?
Old 09-14-2013, 09:23 PM
  #38
irod's Avatar
2010 Mercedes-Benz C300 Sport
http://www.ebay.com/itm/OEM-Mercedes-Benz-C250-C300-2009-2012-iPod-iPhone-Aux-Music-Cable-Adapter-/231053140705?pt=Car_Audio_Video&hash=item35cbd722e1&vxp=mtr
Old 09-15-2013, 12:09 PM
  #39
2010 c300
i dont have the ipod package either so i dont this will be of any use but ty for responding!
Old 03-28-2015, 02:53 PM
  #40
Mersic300's Avatar
2009 Mercedes C300
MERCEDES c300 2009 aux problem fixed
So i was messing around with my 2009 c300 trying to get a good set up going for aux, wasted so much money on ebay iphone conversions cables that didnt work and the quality was horibble until i found something hidden in my passenger glove box panel
i pulled out the old iphone cable slipped in the aux port witch was already installed but hidden inside my panel
Old 06-14-2015, 10:05 AM
  #41
rohitvasu@hotma's Avatar
c300
Originally Posted by Mixedfruits
first do you have an extension cable? heres how I do it
Glove bock I plug in a male to male aux cord one side in glove box aux and one to my phone aux then turn on phone to max sound, then click disc on your dash board then go bottom left change to aux. If this still doesn't work then try turning up the volume from the car sometimes devices are very quite
Hi Mixed fruits -- when you connect your Aux Cable can you change songs using Dashboard controls ? And do you see list of songs on car Music system display ?
If I connect my iphone/ipod using Aux to change songs I have to change in phone , I cant change through the car music controls of next and previous. Do you know solution to this ?
Old 08-08-2015, 12:18 PM
  #42
givanthaid's Avatar
C300
Thank you
THANK YOU SO MUCH! YOU ARE A HERO! had the car for 3 years, read so many threads online about connecting a simple aux cable instead of the ipod connection but had no luck.. Decided to search again and found your response!! Now I'm Rollin!!
Quick Reply: c300 aux
