doh broke seat belt buckle please help
Old Feb 23, 2011 | 05:10 AM
amowolves's Avatar
c200k se
Hi guys,
The mrs has managed to break the seat belt buckle and now the seat belt doesnt clip in. I have sourced a replacement from merc dealer but was wondering if anyone knew how to go about removing the front seat to do so?
any ideas please?
Old Feb 23, 2011 | 01:54 PM
theinmoe's Avatar
C350
Normally seat belt problem are covered under lifetime warrenty since it is safety item. Dealer should fix it under warrenty.
Old Feb 25, 2011 | 05:01 AM
amowolves's Avatar
c200k se
Thanks for that. I rang merc uk and they did say i could ask my local dealer to put a good will application in for the repair (as the car is out of warrantee).
However, it turns out it wasnt covered. ohwel. thanks for the info though i didnt even know that a goodwill application procedure existed! The dealer did not even inform me...they just went on to quote me £140 for the repair.
anyhow i have sourced the part, and it doesnt look to difficult to fit...just one bolt. But i will have to remove the seat.
But.....The seat bolts are star shaped....does anyone know what tool i'll need for removing them?
Old Feb 25, 2011 | 09:44 AM
jctevere's Avatar
2012 C250 Coupe
Bolts with stars on the end are generally Torx bits (which are very common on this car). Try a T15 or T20 torx bit.
Old Feb 25, 2011 | 11:22 AM
amowolves's Avatar
c200k se
thanks it is indeed a torx but not the usual t15 t20....its a female or inverse torx bolt..i think they have an 'e' designation.
Old Feb 25, 2011 | 03:19 PM
amowolves's Avatar
c200k se
ok ive replaced the broken seat buckle...but now i have an airbag malfunction as i had to unplug the seat module.
can i reset this myself or will it require a trip to the dealership and wallet being raped.
car is a c200k. i dont have the ok and call buttons on the steering wheel so cant do that trick.
Old Feb 25, 2011 | 07:49 PM
RLE's Avatar
RLE
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
Let it go for a day or two. These warnings sometime resolve themselves after a few starts since the system goes through a self check on every start.
As you now know, the seat belt buckles are part of the SRS.
Old Feb 26, 2011 | 08:15 AM
amowolves's Avatar
c200k se
ok thanks will do....
i know it might sound stupid...but where is the battery on a c200?
Old Feb 26, 2011 | 09:31 AM
C300Sport's Avatar
2008 C300 Sport 6 Speed Manual, 1953 Chevy Bel-Air, 2015 Audi allroad, 1963 Chevy Apache
Just curious, how did the Mrs. end up breaking a seat belt latch??? Just thinking I may want to know to avoid the same fate.
Old Feb 26, 2011 | 07:21 PM
RLE's Avatar
RLE
Batt
It's at the right rear of the engine compartment, looking forward. Under the heater air intake water trap.
If it's a diesel, it's in the trunk.
Old Feb 27, 2011 | 01:44 PM
amowolves's Avatar
c200k se
thanks RLE...if it doesnt clear in a few days i'll try disconnecting the battery...unless that will throw up other problems?
c300sport she was cleaning the car and got a bit of cotton string stuck in the buckle. but rather than pressing the button to release the string she pulled it and off came a bit of plastic from inside the buckle that pushes the retaining pin out of the way as you push the seat belt in.
Old Sep 6, 2012 | 11:45 AM
cxesar's Avatar
2009 c300 sport
srs light
did the light clear after a few days? or you had to bring to the dealer for reset?
