AZNOptics.com Storefront - W204
Old Dec 4, 2013 | 03:31 PM
  #351
AZN Optics's Avatar
SPONSOR/MBworld Guru
The LEDs we carry are 2 staged units, meaning there is an ambient mode which you'd typically see in footwells, but they are not multi-staged to the point where it gradually dims. The associated cost for this setup would be much more expensive for LED type lighting.
Old Dec 19, 2013 | 04:46 PM
  #352
benzdude's Avatar
Top Answer: 1
2015 C300 4Matic Sport
Angry Help! Hid kit issues
Hello,
I just installed a Morimoto H7 HID kit + Canbus harness into my 2011 C300 and I am experiencing some DRL, eyelid led flicker and passenger side hid ignition delay.
I was under the impression that this kit was solid for W204's. Do I have a bad ballast, bulb or canbus harness?
Here is a video, Can anyone tell me what is going on?
The first attempt is with DRL's off in the dash option. The second attempt (00:55) is with DRL's on.
https://docs.google.com/file/d/0B5M9...amM/edit?pli=1
Old Dec 19, 2013 | 05:05 PM
  #353
TX21's Avatar
Ford
Got the same set up (HID's and all) you did for my 2010. My LED's last about a day or a little longer then burn out. My Xenon's work for the most of the time only a few times I had delayed light ups just like you do. Customer service is outstanding but I don't have much buy in for the LED's and if I lose a Xenon bulb I will feel the same way. Had all this installed lest than a month now.
Old Dec 19, 2013 | 05:10 PM
  #354
benzdude's Avatar
Top Answer: 1
Unhappy
Disclaimer : I got my HID kit from theretrofitsource.com not AZN. I am just asking advice via this forum.
Old Dec 19, 2013 | 05:17 PM
  #355
TX21's Avatar
Ford
My kit is a Miromoto (sp?) H7 as well. Same product. Mine works most of the time though. But when it does not its the right side just like yours and I cycle the key then it works.
Old Dec 19, 2013 | 06:00 PM
  #356
AZN Optics's Avatar
Latest batch of Morimoto ballasts had a bad igniter. I'd talk to whomever you purchased the HID kit from to get a warranty. Morimoto is producing a new updated ballast with large Siemens igniters which should help with misfire issues that appear to be occurring in cold weather.
Old Dec 20, 2013 | 04:49 PM
  #357
benzdude's Avatar
Top Answer: 1
Smile
Well, I swapped canbus harnesses and ballasts (left with right) yesterday and everything seems to work fine now. I will continue to monitor it, but its working!
Old Dec 20, 2013 | 06:27 PM
  #358
wabs2013's Avatar
c350 4MATIC
I'm also having issues with my HIDs. most days when I unlock the car only the drivers side HID fog will ignite and then after awhile the passenger side will come on. I've noticed some flickering/pulsing from the fogs lately. It gets fairly cold where I live, would the weather be to blame?
Old Dec 20, 2013 | 08:05 PM
  #359
AZN Optics's Avatar
Weather is to blame for the misfire issue on the last batch of Morimoto units from what they've explained to us. They told me that typically only one side will exhibit issues on initial cold start, but as the vehicle quickly warms up, turning them off and on should ignite them properly. Morimoto has acknowledged this defect in the igniters so the new larger Siemens igniters should resolve this issue for those in colder climates.
Old Dec 21, 2013 | 12:51 AM
  #360
l.harris2012's Avatar
2013 C250 Sport
I had the same issue. Morimoto is requesting that a photo of the ballasts with cut wires be submitted and they will send your vendor a replacement to send to you. I'm working with Mike from AZN who has done a great job working through the situation. My upgraded ballasts should be delivered in the next couple of weeks.
Old Dec 21, 2013 | 02:59 PM
  #361
benzdude's Avatar
Top Answer: 1
Angry
I spoke too soon, the issue is not fixed. Sent the bad can-bus harness and ballast back to retrofitsource.
Old Dec 21, 2013 | 06:36 PM
  #362
wabs2013's Avatar
c350 4MATIC
So in order to receive new ballasts I have to make my current ones unusable?
Old Dec 21, 2013 | 06:39 PM
  #363
wabs2013's Avatar
c350 4MATIC
Im not sure if that would be realistic for me seeing as i have them installed in my highs, lows, and fogs
Old Dec 21, 2013 | 07:19 PM
  #364
benzdude's Avatar
Top Answer: 1
Not sure what you mean by make them unusable. I bought my kit, one side is defective on arrival, so I sent it back for a replacement.
Old Dec 21, 2013 | 07:21 PM
  #365
benzdude's Avatar
Top Answer: 1
You have hids in high low and fogs? :/ you must be made of money.
Old Dec 21, 2013 | 07:23 PM
  #366
benzdude's Avatar
Top Answer: 1
Oh you were responding to harris2012.
Old Dec 21, 2013 | 07:30 PM
  #367
AZN Optics's Avatar
Yeah, that's Morimoto policy to cut pretty much all cords and submit picture with barcode. You'd have to revert back to oem for the time being. Depending on your vendor, you might be able to work out a deal with them though... for my trusted repeat customers, I'm spotting them in advance replacement parts from my inventory and back fill after with warranty pics to reduce downtime for them.
Old Dec 21, 2013 | 07:32 PM
  #368
AZN Optics's Avatar
Unfortunately in this case with the faulty ballasts though, we don't have the updated ones in stock yet. We should by hopefully end of this week.
Old Dec 21, 2013 | 08:58 PM
  #369
wabs2013's Avatar
c350 4MATIC
Would i be considered a "trusted customer" since i've purchased from you a few times?, not trying to put you in the spot you can pm me the answer
Old Dec 21, 2013 | 11:14 PM
  #370
AZN Optics's Avatar
Sure, not a problem. Just shoot me an email. As mentioned though, I don't have the updated ballasts yet.
Old Dec 24, 2013 | 10:33 AM
  #371
TX21's Avatar
Ford
Waiting on them to fail again then I am going to decide if I want to cut my wires and wait for new part. Hooray.
Old Dec 25, 2013 | 10:56 PM
  #372
Das Benzo's Avatar
2009 C300 4MATIC
When will the 7507 rear LED red turn signals be back in stock?
Old Dec 26, 2013 | 12:56 AM
  #373
AZN Optics's Avatar
We're scheduled to get those in mid January. There were some delays with CREE getting those components back in stock for our manufacturer.
Old Dec 29, 2013 | 07:27 PM
  #374
2nice4me's Avatar
2011 E350 4 Matic
are these: 194/ 168/ T10/ 2825/ 2821/ W5W LED (4500K) V3
$17.00
suitable for E350 license plate lighting?
Old Dec 29, 2013 | 08:11 PM
  #375
AZN Optics's Avatar
$17.00
W211 or W212?
edit: nevermind, I see in your profile you have a 2011. Yes, those will fit.
