Qustion for manual transmission users.
Old Apr 16, 2011 | 09:07 PM
jl9j's Avatar
2009 C63 AMG
Hey all,
I've driven many MT cars in my life. I learned and have always used engine brakes (shifting down through lower gears rather than putting it in neutral and just using the brakes) when slowing down. The other day, i was driving a friends car and he told me he never uses engine brakes. His reason was that brake pads and rotors are cheaper to replace than over working the engine and transmission. He also said he does't have the car in gear and the clutch down when he is at a stop light. He said when you step on the clutch parts are moving that wears down the clutch.
So I've been thinking. Have I been dring stick the wrong way all this time?
Old Apr 16, 2011 | 10:12 PM
covance's Avatar
2011 C300 Sport
subscribed
Old Apr 16, 2011 | 10:24 PM
iGeorge's Avatar
'12 E550 4M, '14 ML5504M
I've been doing manual transmissions for more then half my life, and always done engine braking. Yes it does increase wear on your clutch plate, but you are balancing that against lower wear on your brakes, as well as keeping your brakes from overheating if you live on hill or mountain roads.
However, the greatest advantage with engine braking is that it's a good, fluid way to maintain car control when driving. If you are on a sweeping for example, instead of shifting momentum around with your brakes, you can bleed it off or shift it over smoothly by letting the engine take up the energy you were carrying into the turn.
Just try not to over rev your Benz, OK?
Old Apr 17, 2011 | 02:30 AM
jl9j's Avatar
2009 C63 AMG
I get that and I prefer engine braking, but does my friends logic stand? Brakes are cheaper to replace than clutch?
Old Apr 17, 2011 | 05:35 AM
JFOUR's Avatar
2008 C300 Sport 6MT X-Pipe
Originally Posted by jl9j
Hey all,
I've been driving manual transmissions for many years too and used to be a big fan of engine braking, it makes the drive so much more engaging and spirited. I read in the Mercedes owners manual that they DO NOT recommend it, so I have been reluctant to do so with this car. A new clutch cost over $2400.00 and a transmission would be silly money... I'd rather wear out the brakes i guess.
Old Apr 17, 2011 | 05:48 AM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
A balance between the two in my opinion is the way to go. ie change down before entering a corner so you can exit in the correct gear.
If you "blip"the throttle before changing down to match engine speed to clutch will avoid wear on the clutch & over working your syncro cones in the gearbox.
My having the clutch depressed for longer than necessary will wear the clutch thrust bearing.
My manual cars have achieved over 300,000 km without clutch repairs. Gear boxes were still strong & original at 450,000km
Old Apr 17, 2011 | 09:04 AM
iGeorge's Avatar
The logic is sound at the from a cost of component replacement perspective, but I don't think you are replacing the whole clutch mechanism, just the friction plate and possibly a thrust bearing. I'm going to dig into this one a bit more. Stay tuned!
Old Apr 17, 2011 | 10:29 AM
jl9j's Avatar
2009 C63 AMG
Yes. While cornering you would have to keep working the stick. I was thinking more when you see a red light and start slowing down.
What fun is a stick if you dont use it in corners
I guess i will have to change my driving habbit a bit and start braking in neutral when coming to a stop at a stop light.
Old Apr 17, 2011 | 09:22 PM
C300S 6MT's Avatar
C300, 330i, MDX
i agree that a balance of both is the way to go. at a stop light, i normally have the clutch depressed and car is in gear. just in case i get "bumped" from the back, the tendency is to loose footing and the engine will die when i release the clutch and the car will not roll forward to the middle of the intersection cause the gear is engaged.
