Will 2007 E63 wheels fit a W204?
'11 C350 '13 F150 lariat
Doc whats the exact size and offsets of F and R on those. If theyre same all 4 size they will fit at 38mm. I ran 9.5 38mm in back w 255 no probs in 35/18s on my 2008 for a year im running 235/35/19 with 40mm up front on 8.5 now no prob, so those are prob 8.5 or even 8 up front. I ran 35mm 225/40/18 up front on the 2008 so u should be good to go but not by much
It will fit, but wont look the same in sidewall size. The 225 is perfect for 8" wheel but a 255 is for a 9" wheel. You will have a fat rear and a straight front sidewall. a 245 is the right size, you usually go 3 sizes for an inch of rim. like my last 18s were 8.5 and 9.5 staggered, and 225F and 255R were evenly stretched slightly, i couldnt go 265 rear cause they rubbed so I downgraded fornts from 235 which I wanted to 225 so it would match. You probably can understand it that way. currently im 8.5 w a 235 front and 275 w a 10" rear for comparison. But essentially all that say 35mm offsets wont work on w204 havent tried it, they just repeat what others say on here. I tried it and ran with it 2 different sets for almost 3 years, you just gotta go 255 max w a 9.5 rear. if your rears are 9 or even less your good. I will tell you that they are aggressive looking and stick out, but thats the look you're probably going for. lemme know if you need more help or post links to rims your thinking of and Ill tell you which way Id go...........jimmy
1 Post
2011 C300 Sport
Ideally these-
http://cgi.ebay.com/ebaymotors/ws/eB...m=270722225236
I like the 5-spoke, the price is right, and if the factory tires will fit them (I don't mind if the rears look a bit beefier) then I'd be a happy man.
I checked the link, the numbers work. Im basing this on the fact I ran 2 sets of 35mm offsets as I posted above. As long as you are aware they will sit flush to your fenders, they will clear. The one thing I will tell you is that I ran sumitomo tires on both sets and they didnt rub w a 9.5 rear and 255/35/18. I got a flat and was in a bind and couldnt find rear tires in that size other than Nexens. I said hell with it and threw 2 on cause teh other side was almost toast anyway. That brand in same size rubbed on a bad bottom out slightly on the inner fabric but left no marks or damage of any kind, you had to listen carefully to know it even happened. I later found out sumitomo and falken and others are a narrow brand tire, the way the treads are and such makes them slightly diff in size and contour. For instance the Nexens have more tread up to the edge of the sidewall, my current falkens do not. Anyway with a 8.5 rear you will not rub, even w 255, but will be a little fat but you said you are aware of that. You can also have wheels machined at any machine shop, I have a set of BRABUS wheels that cost 4k new that were 25mm offset. They are now close to a 40mm offset, it was 75 a wheel to machine at a local machine shop. But those wheels will fit and I do like them, I have a sweet spot for factory looking wheels, its a classier look
1 Post
2011 C300 Sport
I don't mind if they sit flush with the fenders, as long as looking at it from the front or back doesn't look too strange. Do you have a picture from when you ran the 35 offset wheels? I assume it handles better from the wider stance...
No its not gonna stick out, those wheels are only a few MM larger than stock wheels I beleive. The offset is gonna push them out about a half inch, they will look better and it will corner better
1 Post
2011 C300 Sport
Huh. Well then why does everyone say 35 offset wheels won't work? It seems like they'd work fine, they'll just stick out a bit more. I hate to be the test dummy here but my ordering finger is getting really itchy...
http://www.1010tires.com/wheeloffsetcalculator.asp
1 Post
2011 C300 Sport
Thanks Matt, I calc'd going from a 50 offset to a 35 offset for an 8" wheel (says it sticks out 15mm more as I expected) and from a 54 offset on a 9" wheel to a 35 offset on a 8.5" wheel and it said 13mm more out. This is approximately half an inch on both front and rear, I still don't get why certain places say you can't run a 35 offset?
1 Post
2011 C300 Sport
UGH. Now I have to be the test dummy. Jimmy, do you have a pic from when you ran the 35 offset wheels? I'd really love to get a ballpark for how far the front ones stick out...
Thanks again for the help guys!
2011 C300 4matic, 2015 Porsche Macan S, 2006 R500 (sold)
![](https://a7.sphotos.ak.fbcdn.net/hphotos-ak-snc6/179684_488832161129_577791129_6071697_2681102_n.jpg)
![](http://i660.photobucket.com/albums/uu324/w204driver/1195.jpg)
1 Post
2011 C300 Sport
Not sure I'm digging the sticking out look... That is a 9.5" up front tho, I'd have an 8" rim, and 8.5" in the back, with a higher offset than both of those and 225 front 255 rear...
![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
