7.5" and 8.5" = 8"?
Old 05-16-2011, 10:31 PM
ergon's Avatar
C63
7.5" and 8.5" = 8"?
Let's see, my 2010 C300 Sport is running 17x7.5" up front and 17x8.5" out back. The rims I found are a split, they're 17x8". The tires will work OK won't they? 225x45's front and 240x40's rear. Will this work with straight 17X8's all around?
Old 05-16-2011, 11:10 PM
Sportstick's Avatar
Another round of ICE
Exactly what I did and it works very well...actually, unnoticeable.
https://mbworld.org/forums/c-class-w...g-17-reps.html
Old 05-16-2011, 11:11 PM
Richie999's Avatar
2011_C350
try tires.com or tire rack for max wheel width for tires.
Old 05-16-2011, 11:22 PM
Sportstick's Avatar
Typo? Rears are 245/40-17, not 240?
Old 05-16-2011, 11:30 PM
chicolonga's Avatar
2009 c300 sports
Where did you get those rims sportsTick? I have a 2009 c300 sport. Will it fit my car too?
Old 05-16-2011, 11:33 PM
Sportstick's Avatar
Yes, we have the same car....
http://www.powerwheelspro.com/shop/p...products_id=47
Note they now carry 17" with staggered widths, just like the original size, with 44 offset. When I bought mine, all they had was 17x8", but as the earlier thread shows, that worked just fine!
Old 05-16-2011, 11:43 PM
chicolonga's Avatar
2009 c300 sports
**Will need spacers for AMG Brakes**
What does this mean? Does it mean I need to buy spacers?
Old 05-17-2011, 12:44 AM
itsLoonie's Avatar
2012 E350 RWD
If you have done a big brake kit like from brembo or have the C63 AMG brakes then you need spacers. Doubt you swapped your original brakes for any of those so no, you do not need spacers. I could be wrong though.
Old 05-17-2011, 08:53 AM
Sportstick's Avatar
No.
Old 05-17-2011, 10:54 AM
dcjwlee's Avatar
2013 GLK 350 4M (Iridium Silver), 2010 E350 Coupe (Iridium Silver)
Is that the price per set!!!!! Ohhh nooo, think I know my next mod.
Is there any way to get MBZ center caps though?
Are these "quality" rims? (Not sure what the industry standards are)
Old 05-17-2011, 10:58 AM
Sportstick's Avatar
Yes, per set. TUV, JWL, and ISO9001 certified sources. My set took very little weight to balance, and indication of good processes.
Old 05-17-2011, 11:07 AM
dcjwlee's Avatar
http://www.powerwheelspro.com/shop/p...roducts_id=531
Those look smoking... $500 shipped
I wonder if they would look terrible in 17"....
Where could I find mbz center caps?
Old 05-17-2011, 11:10 AM
Sportstick's Avatar
Would I be able to swap my stock tires onto them? That would be huge (for saving $$).
Go back to post #2 and check my link. I have 17x8 at all four corners. I think they look fine, but that is personal taste. 18" doesn't strike my eye as much as it does for some others here. I had already upgraded my tires to Michelin Pilot Sport A/S Plus, but in the OE size, so yes, stock tires can swap right on.
Quick Reply: 7.5" and 8.5" = 8"?
