Installing Bolt on CF Front Lip Instuction
( http://cgi.ebay.com/ebaymotors/ws/eB...#ht_6953wt_941 ).
It got here today and it fits flawlessly but im definitely on my own here no markings or anything. I drove to a body shop earlier and they quoted me 3 hours of labor which adds up to the same price I payed for the part itself which is crazy!
Seems to me like it should be a quick install I'm trying avoiding the auto shops at all costs.
Seems to me like it should be a quick install I'm trying avoiding the auto shops at all costs.Trending Topics
Tools needed
Cordless drill
¼” drill bit
3/8 wrench
Hardware needed
3M double side tape
6 ¼” bolts and nuts ½” long with washers
find a spot w a high curb like a parking lot or ur driveway, preferebly concrete so car doesnt settle. Bring a friend.
Just like above 3m double sided tape and the hardware listed. Park your car up on the sidewalk w ur buddy watching so the front end hangs as much over as possilbe onto street or lower walkway. Now you have tons of room to drill and work on it. Install as posted above. Or use car ramps w a block of wood for support so no roll back. really simple. 3m double sided tape is key
You can also try what my friend did on the cheap, use 2x4 blocks. Home Depot will let you cut blocks with their tools so all you need are two step blocks (one longer base block and one shorter one on top in the middle). Nail the two blocks together with the base block extending past the top step block on both ends allowing for a kind of pyramid step. This way you can drive up over it, install your lip, then continue driving forward once done so you won't risk damaging your new lip. Just make sure the height of the block steps is not higher than your sideskirts
When you did the install, did you have to drill through both layers of plastic or did you find a clever way to drill the holes?
I am referring to the area behind the carbon fiber where its hollow, seems like the only way to drill a hole is go through both.
