DIY: Backup camera for 25$ (with pictures)
Old Jun 1, 2013 | 12:27 AM
  #76
TheBenzAddict's Avatar
C300
Just did the rear view camera install..
Super easy! My command had a green fakra already attached to the command, but I found out what it was...
Also, removing the vents were bad! But I found an easy way to do it if anyone wants to know just ask.
Old Jun 1, 2013 | 03:16 PM
  #77
Carlos.33193's Avatar
C250 2012
Does the 2012 C250 have the cable already somewhere? maybe in the trunk?
Old Jun 1, 2013 | 03:31 PM
  #78
C300
No, it doesn't come pre-wired. Do you have the multimedia ipod package? If so, then your command may already have the green fakra video cable attached ..but that is not for the rear view camera. It's for the iPod video aux. you gotta remove it and use your own fakra to RCA cable.
Old Jun 13, 2013 | 04:42 PM
  #79
lapd1989's Avatar
C63 AMG
Is there a way you can connect both? If I can recall it the fully loaded ones have both cam and iPod to work. If someone have one that comes with both can take the HU out to see how it connected that would be great. I remembering seeing one HU that 2012-2013 there's a two fakra slots. I will taking mines apart in a few more days to do the install and see. Oooo the one That I saw was on this site but I forgot. He had both to work can and iPod. He took a picture of the HU and it have two fakra next to eachother.
Old Jun 14, 2013 | 08:45 AM
  #80
Drazil's Avatar
There's another thread where it was mentioned that you need the NTG4.5 COMAND in order to have two FAKRA inputs. The older version I guess only had one. IIR, In the manual it says that if you have the backup camera, you cannot use the multimedia input for video so that seems to indicate at some point there was only one aux video in. You can tell if you have the newer COMAND HU if it has an SD slot, or go to the engineering menu to see the version.
Old Jun 14, 2013 | 10:21 AM
  #81
lapd1989's Avatar
C63 AMG
Yes i have the new one. So I should be able to do it. Is there anyone that you know have any info on this and how to link it with the HU? Thanks
Old Sep 15, 2013 | 01:33 AM
  #82
Zakaria103's Avatar
E63S
I have an 08 and I am not understanding what happens to the "green" plug that is already plugged in the HU from factory. I read that it goes to the Aux in the glove box but not really sure where... Just to clarify, I can still use my Phone or Ipod using the 3.5mm wire correct ?
Also, Will this Fakra wire work ?
http://www.ebay.com/itm/RCA-female-to-Fakra-E-female-in-green-pigtail-cable-RG174-at-10-15-20-30cm-/330856972774?pt=US_Radio_Comm_Coaxial_Cables_Connectors&hash=item4d089cc1e6
Thank you for the help!!
Old Sep 15, 2013 | 12:54 PM
  #83
Doa's Avatar
Doa
W205
my cams costed 140$ combined.
here's the front cam view with the distance indicators badly visible on the pics
rear view (in any mode except reverse)
and when in reverse mode (with distance bars and in a downward angle)
Old Sep 15, 2013 | 01:00 PM
  #84
Zakaria103's Avatar
E63S
That looks really good!
Old Sep 15, 2013 | 07:27 PM
  #85
Zakaria103's Avatar
E63S
RCA Female to Fakra E Female in Green Pigtail Cable RG174 at 10 15 20 30cm | eBay
Anyone ?
Thanks!
Old Sep 17, 2013 | 02:42 AM
  #86
AmeyStune's Avatar
09 Mercedes C300
Can someone provide me a list(links amazon/ebay) of the items I need to buy. I don't care if it being shipping from china.
All I know is I need some sort of Fakra Cable, Camera, etc?
Old Sep 17, 2013 | 02:47 AM
  #87
vic viper's Avatar
S213
IMO its better to see part of the bumper when looking at the display, this way you get a much better depth view.
Old Sep 17, 2013 | 09:59 AM
  #88
Doa's Avatar
Doa
W205
that is way there are lines on the screen?
if i get to the red line i have about 2cm left before it bumps into my bumper
Old Sep 17, 2013 | 03:20 PM
  #89
gwai_jai's Avatar
2010 C300 4MATIC
Anyone ?
Thanks!
Here is a link to my post which has links to the parts for my 2010
https://mbworld.org/forums/5548557-post59.html
Old Sep 18, 2013 | 03:21 AM
  #90
AmeyStune's Avatar
09 Mercedes C300
Has anyone tried this type of camera?
http://www.ebay.com/itm/Benz-E-class-W212-C-Class-W204-CMOS-NTSC-Car-Backup-Reverse-Rear-View-Camera-/390659693250?pt=Motors_Car_Truck_Parts_Accessories&hash=item5af521dac2&vxp=mtr
If so, is there a difference it the output of the light. I mean is one side dim compared to the other.
Thanks in advance.
Old Jan 16, 2014 | 04:11 AM
  #91
lsj711's Avatar
2010 C 300 4MATIC
i would like to know this as well
Old Jan 28, 2014 | 10:41 PM
  #92
Zakaria103's Avatar
E63S
Benz E Class W212 C Class W204 CMOS NTSC Car Backup Reverse Rear View Camera | eBay
Thanks in advance.
That is the one I am currently using right now. I had another one but was really visible. This one is hidden, replaces one of your license plate light but you are still able to put your bulb in it.. Light is not as strong as the other side but still there.. The view on the screen is pretty good and you can see a little bit of the bumper which really makes it easier parking if you're trying to get close to something..
Old Dec 24, 2015 | 11:44 AM
  #93
Xev's Avatar
Xev
2009 c63, 2004 e320, 2006 s430, 2011 e350 4matic
Hi there everyone, new to the forum, finally got around to doing this rear camera install, seemed pretty straight forward but I can't get the camera image to appear on the comand monitor, I tested the camera on my tv's aux video port and the image is great, not sure if it's a coding issue or another cause. Any help would be great, thanks
Old Dec 26, 2015 | 12:12 PM
  #94
Xev's Avatar
Xev
Hope everyone had a great holiday, any suggestions on why my camera will not work?
Old Jan 26, 2016 | 06:13 PM
  #95
jamieh64's Avatar
2009 C63
I think you need to have the Video Aux set to OFF, let me know if that worked.
I'm installing mine next week.
-j
Old Jan 29, 2016 | 06:48 PM
  #96
Xev's Avatar
Xev
-j
Nope as shown in the picture video aux is on, turns out camera was bad,
Old Feb 8, 2016 | 08:43 AM
  #97
ca-lurker's Avatar
B200
Do I also have to use fuse 71 to wire backup camera on a B-class (W245)?
Old Mar 21, 2017 | 08:09 AM
  #98
Rob the bank's Avatar
2012 GLK
Originally Posted by Cartronics
You might want to look at a good camera snarlingshicken. I don't want to rain on the OP parade, but we have tested MANY CMOS cameras, and posted lengthy reviews elsewhere in the forums. You only want to install a camera once because of the labor involved. Buy a good CCD camera with a GLASS lens. Don't ever install a CMOS camera. You won't find a good CCD under $100 though.
We offer the ones that Mercedes, Porsche, BMW, Audi, VW, and Lambo use at the factory. Not cheap, but not one has ever failed. Even if you don't buy one of ours, buy a good CCD with low lux, wide angle, glass lens.... you won't be disappointed a few months down the road.
hello there.. Please send me the link where I can purchase the CCD camera with the glass. The one used in Mercedes Benz. I have a 2012 GLK and have the option in the engineering menu to switch to rear view camera on R. Also if you have professional installers in NJ area so I can have it professionally installed.
PM me if you want with the info ..
thanks
