C250CDI FUEL FILTER
Old Aug 20, 2011 | 06:12 AM
sakura's Avatar
C250 sport estate
C250CDI FUEL FILTER
Hi,
Does anybody know how to bleed water from the diesel fuel filter on a 2010 C250? I've looked on WIS but my fuel filter does not have the water bleed screw they show. Filter is located on top of engine, 2 pipes in/out and an electrical connector block.
Old Aug 20, 2011 | 06:36 AM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
I have looked at my Wis for the 220CDI . It mentions 'loosening' a screw at the water separator & turning on the ignition to bleed the system with the fuel p/p running. Bleed into suitable container until fuel is clear.
Might be best to replace the filter with a new one.
Are you doing preventative maintenance or have you water in the system. ?
Old Aug 20, 2011 | 01:52 PM
sakura's Avatar
C250 sport estate
Carsy,
Thanks for the reply. I suspect there may be water in fuel after other reports regarding local filling station. Just want to check. I too looked at the WIS and got a picture of the fuel filter. However mine is not like the one shown - there is no bleed screw on mine. unlike the one shown. Perhaps they have eliminated it on later models?
Anybody know how the dealers do it?
Old Aug 21, 2011 | 09:45 AM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
Some are fitted with a water seperator (if it has wires running from the filter) and some don't. If it has a seperator then it will show on the dash if there is water in the fuel, if it doesn't have a seperator then there is no bleed point on the filter.
