Will they replace this stuff under warranty?
I just bought an 08 C300 from a used car dealership and I have a couple things that I would like to be fixed and am wondering if they could be replaced under warranty. I car is still in the valid time period, but is the warranty automatically transferrable?
Here are some of my problems and could you tell me if the service advisor would fix them or not?
-First and mainly, at low driveway/parking lot speeds, when I turn the wheels I feel a vibration, roughness or very slight resistance in the steering wheel. It is really the first AWD car I have driven and am wondering if it is normal for AWD. My dads S550's steering is buttery smooth every speed, mine is a bit rough, but fine when moving fast.
-It seems that my exterior temperature gauge runs a bit high, it always seems like its 4 or 5 degrees past what it should be based on how it feels out side to me and other car's thermometers. Anyone else have this problem? The problem here is proving it...
-My gas sport pedal is missing some of its little black dots (I think they are just worn down), I could see them saying this is due to wear, but at the same time maybe replacing it if it seems like they fell out?
-I am missing the metal clip that holds down the back of the air filter box, it just isn't there, any possibility of it being replaced with the idea that it fell off while driving?
-I'm guessing this is a no, but before I ask the SA and sound stupid and **** him off, my middle lower mesh grill in broken in the middle, most likely from a rock skipping up and banging through, would they replace this? Their part did fail to hold up against a rock
-Lastly and again most likely a no, while removing the grill I broke off one of the clips from the fan shroud that holds it on, could it be replaced?
Obviously, the above are just my opinions based on the experiences I've had with my MB dealer (which for the most part have been positive- on a couple occasions, they have gone above and beyond to accommodate my requests).
Good luck!
Can't tell you cuz I've never owned an MB 4MATIC.
I've noticed that my car's gauge exaggerates the outside temperature a little but, but I've come to terms with it. Personally, when it's hot outside or cold, I usually already know before I step into my vehicle
As I was once told, if a piece of trim is peeling, then they will cover / replace it under factory warranty. I think they may be willing to work with you on this unless the cost to replace it is rather high.
I think they'll probably do that for you.
When I had a small crack that caused moisture to seep into one of my side-view mirror's turn signals, the SA noticed it (I hadn't), he said as long as it is not caused by someone trying to pry it off, they would replace it at no cost, and they did. It might work the same way with your mesh? Also, folks with damaged fog lights have had varying experiences when trying to get the dealer to replace it for free. Again, ymmv.
I highly doubt you'll have luck with this last one - if something broke as a result of you trying to remove the grille, it's not really the manufacturer's fault. It seems like a part that wouldn't break from normal usage / wear-tear.
Good luck!
As far as the power steering goes, mine was like yours, I complained about it and it turns out my fluid was a bit low. They topped it up and all whining and stiffness went away. These cars are very sensitive to the fluid levels.
The only things I would imagine them giving you a hard time on are the grill fan clip and the lower mesh. But I know that the lower mesh there is a DIY in the stickied thread for how to replace it cheaply.
Can any other 08-09 owners confirm this? The funny thing about it is Merc put the two plastic studs there for the clip, just not the clip.
Literally just today my "A3 Service Due" came up, basically an oil change and I 100% want to do it my self and not actually give money to the dealer (just warranty repairs), so now when I go in tomorrow they will ask me and I will have to say "no, I am doing it my self." They probably won't like me for using them only for warranty repairs and not serve me as well.
Also, is my warranty voided if the car is serviced by its owner?
I am thinking of reseting the service light without changing the oil, and changing the oil right when I get the car back, or moving my appointment forward. Reseting the light without changing the oil bothers me, do you think its a problem?
I am going to Rallye motors and am just wondering if they supply you with Mercs as loaners, and what model?
The ones I go to will give you an MB loaner if you bought your car from them and are under an MB warranty. If you didn't buy from them but are under warranty, they give you a free rental. They have a Hertz on premises, but if it's closed at the time of your appointment (late afternoon or weekends), then the dealership will give you one of their loaners. Most of their loaners are C and GLK Class, but I think they have an M and an E as well. As you would expect, they'll give you a loaner in the same class as your car, but on occasion, you might be given a choice.
If you're out of warranty but you get a certain dollar amount of service work done, they'll set you up with a replacement vehicle as well, but I think that's a rental.
If what you're taking your car in for takes an hour or two, they're more likely to encourage you to wait it out.
Overall, compared to my 08 C300 everything feels a bit tighter, but nothing I would really miss when getting back into my 08, as they are all bound to be worn in eventually.
The steering wheel seems to have Mercedes premium leather on it, it is extremely smooth compared to my 08 wheel, maybe mine is just less smooth because it is worn, but the grain is still not nearly as fine as 2011's.
It's made in South Africa, and I am not blaming this directly on South Africa building, but the car has 600 miles on it, and the front bumper has a bigger gap on one of the joints between the hood and front bumper than the other, it looks like one of the side hood latches isn't latched, reminds me of one of my dads old S's when it came back from the body shop.
The chime in the dash board is different, a little less obnoxious, but I don't mind mine. The 2011 also has instant mpg which is cool. I don't like how the car automatically goes in E mode every time you start it.
I like and prefer the new key, as well as the new mirrors, I have the 2011 covers, but I really like the squareness of the new ones.
The LED DRLs are a bit of a waste when it come to nighttime use, you can barely tell they are LED's as they are so dim, and when you unlock the car at night you no longer have the bright fog lights lightening your path, but the LEDs in dim mode.
Two things that jump out to me as Benz cutting costs for the 2011s -
the 2011 uses its horn to chime three times when locking it and it also uses the horn for its alarm, like an old American car, as opposed to the 08 which has the beep beep beep when you lock it and the high pitch beep for the alarm. I really don't like the fact that it uses the horn for the lock feedback, again, it sounds like an old Chevy. I guess they figured it was a waste to put in a second chime device when they could just use the horn.
also, on my 08 and all the other Benzes I seen after MY 2004, on the sticker on the door jam with the vin, build date and paint code, there is a "C" before the paint code. I have learned that this indicates a special process that Mercedes uses on there clear coat, it involves a ceramic based clear coat which is a lot stronger than normal. It requires a special process at the factory where the car has to sit in high temperature to cure the ceramic. Well this 2011 did not have that C meaning the clear coat is not ceramic as my 08 or other Benzes built in Germany are. I guess they are not set up for this process in South Africa, which is a shame, other 2011 Benzes have the "C."
At the end of the day, the final product is about the same, and I guess only real car nuts like me would notice the differences in what seems like Mercedes cutting corners. It's fun to enjoy a fresh Mercedes for a couple days, but when it all comes down to it, I have no problem getting back into my German built, straight-bumpered, 2008!
Someone else on this forum pointed out the lock chime/horn thing just yesterday. I think they also added an option accessible from the instrument cluster to turn off the audible cue altogether in MY11.
I also noticed the steering wheel difference - every '11 loaner I got had the very basic options (no bells and whistles) but the steering wheel had a smooth leather feel to it, while my fully loaded '09 has a less smooth textured feel to it. It's either from usage (but it looks in very good shape) or that's just how the texture of the steering wheel was for '09 (and from what you're saying, '08 as well).
Ah, yup it must be either the palladium silver, or just that they stopped the Ceramic for MY2011.
I didn't know they made 09's in SA, and yes, you must have the same steering wheel as my 08, I guess Merc decided to go to a smoother texture in 10 or 11. Does your 09 beep or honk?
You'll need to call ahead and discuss this as you don't want to be stranded at the dealership.
As a general rule, most dealer insurance companies won't allow a rental to someone who is 17.
