Lug nuts rusting
Old Sep 2, 2011 | 01:15 PM
sudhanshu3's Avatar
c300
Lug nuts rusting
The other day i noticed few of my lug nuts rusting.
My car is still under warranty do you think it would be covered?
Old Sep 2, 2011 | 01:20 PM
dcjwlee's Avatar
2013 GLK 350 4M (Iridium Silver), 2010 E350 Coupe (Iridium Silver)
If your SA tries to charge you for them under warranty, ask to see someone else or go to another stealership.
My SA commented on them once, but said unfortunately they couldn't cover it out of warranty.
Mine are rusting badly and I'm worried they might get stuck when I have a flat.
I saw a member had put up a set of chrome lug nuts F/S. I think it's only been a few days.
Old Sep 2, 2011 | 01:22 PM
sudhanshu3's Avatar
c300
is'nt it a safety issue?
Old Sep 2, 2011 | 01:29 PM
dcjwlee's Avatar
It might make it a bit harder to take off, but I highly doubt the rust will eat away at an entire five lug nuts to cause the wheel to fall off and cause an accident in my lifetime.
Old Sep 2, 2011 | 01:46 PM
xXHotelCrazyXx's Avatar
2008 W204 Sport
I am selling some brand new chrome ones, pm me if interested
https://mbworld.org/forums/exterior-...lug-bolts.html
Old Sep 2, 2011 | 01:58 PM
sudhanshu3's Avatar
c300
sorry these won't go with my OEM double spoke wheels.
Old Sep 2, 2011 | 02:07 PM
2008 W204 Sport
Neither does rust :P
Old Sep 2, 2011 | 04:27 PM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
Take them off , clean them up then apply a little clearcoat spray paint.
Old Sep 2, 2011 | 06:02 PM
ucfbeta92's Avatar
2009 C300 Sport, ex 2007 C230 Sport
Speaking from personal experience, the dealership changed the rusty lug nuts on my old MB (which was under factory warranty at the time).
Ask nicely if they will do it for you as a courtesy since your vehicle is still under factory warranty.
Old Sep 2, 2011 | 08:01 PM
grane's Avatar
GLK350, SL63 AMG
Then put a tad of lithium grease on the threads and the face between the bolt and the wheel. Torque to specs and retorque at 100 miles or so.
You have two different metals in the bolts and the alloy wheels so you are getting rust and electrolytic corrosion. The grease makes it easier to remove the wheels when you rotate or replace the tires since it reduces elec corrosion.
An alternative is to take all the bolts off clean them up, degrease them, then spray them with the Rustoleum color of your wont, let dry and do the lithium bop.
Old Sep 2, 2011 | 08:04 PM
LawRens's Avatar
43
Just for future reference, lug nuts and lug bolts are not interchangeable words as they are completely different things (even though they more or less have the same function). And Mercedes (along with most German automakers) uses lug bolts.
Lug Nuts:
Lug Bolts:
Just thought i'd let you know.
Old Sep 2, 2011 | 09:52 PM
Carsy's Avatar
I do grease the threads & faces against some opinion & then under torque a little to compensate for the lack of friction.
Nothing worse than a siezed wheel bolt on a black wet night on a country road.
It little less torque also helps the female population change a tyre.
